Hello
Jeedom en 4.2.14, system à jour
Enocean
* Installation des dépendances *
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python-enum' is not installed, so not removed
The following packages were automatically installed and are no longer required:
python-pyicu python3-asn1crypto python3-cffi-backend python3-configargparse
python3-configobj python3-entrypoints python3-future python3-mock
python3-parsedatetime python3-pbr python3-pyparsing
python3-requests-toolbelt python3-rfc3339 python3-tz python3-zope.component
python3-zope.event python3-zope.hookable python3-zope.interface
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
build-essential is already the newest version (12.6).
python-serial is already the newest version (3.4-4).
python-dev is already the newest version (2.7.16-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Requirement already satisfied: setuptools in /usr/lib/python2.7/dist-packages (40.8.0)
Requirement already satisfied: wheel in /usr/lib/python2.7/dist-packages (0.32.3)
Requirement already satisfied: enum-compat in /usr/local/lib/python2.7/dist-packages (0.0.3)
Requirement already satisfied: enum34; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from enum-compat) (1.1.6)
Package 'python-bs4' is not installed, so not removed
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python2.7/dist-packages (4.9.3)
Requirement already satisfied: soupsieve<2.0,>1.2; python_version < "3.0" in /usr/local/lib/python2.7/dist-packages (from beautifulsoup4) (1.9.6)
Requirement already satisfied: backports.functools-lru-cache; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from soupsieve<2.0,>1.2; python_version < "3.0"->beautifulsoup4) (1.6.4)
* Installation terminée *
Log brut
Rechercher
/usr/local/lib/python2.7/dist-packages/bs4/element.py:16: UserWarning: The soupsieve package is not installed. CSS selectors cannot be used.
'The soupsieve package is not installed. CSS selectors cannot be used.'
[2022-03-11 15:19:25][INFO] : Lancement démon openenocean : sudo /usr/bin/python /var/www/html/plugins/openenocean/resources/openenoceand/openenoceand.py --device /dev/ttyUSB1 --loglevel debug --socketport 55006 --callback http://127.0.0.1:81/plugins/openenocean/core/php/jeeOpenEnOcean.php --apikey 8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5 --cycle 0.3 --pid /tmp/jeedom/openenocean/deamon.pid
[2022-03-11 15:19:26][INFO] : Start openenoceand
[2022-03-11 15:19:26][INFO] : Log level : debug
[2022-03-11 15:19:26][INFO] : Socket port : 55006
[2022-03-11 15:19:26][INFO] : Socket host : 127.0.0.1
[2022-03-11 15:19:26][INFO] : PID file : /tmp/jeedom/openenocean/deamon.pid
[2022-03-11 15:19:26][INFO] : Apikey : 8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5
[2022-03-11 15:19:26][INFO] : Callback : http://127.0.0.1:81/plugins/openenocean/core/php/jeeOpenEnOcean.php
[2022-03-11 15:19:26][INFO] : Cycle : 0.3
[2022-03-11 15:19:26][INFO] : Loading profile file : D5-00-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-32-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-32-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-32-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-14-41.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-14-30.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0C.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-04.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0E.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-06.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-12.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0A.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-11.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-05.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-07.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0D.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-10.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0B.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-09.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-08.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-01-0F.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-04-08.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-15-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-05-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-03-0A.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D2-06-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-05-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-04-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-03-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-10-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-02-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-02-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-02-04.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : F6-02-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-08-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-10-06.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-10-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-10-04.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-10-12.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-10-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-09.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-0B.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-1A.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-14.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-19.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-08.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-17.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-07.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-06.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-15.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-30.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-10.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-0A.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-18.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-16.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-05.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-12.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-13.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-1B.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-04.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-11.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-02-20.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-38-08.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-12-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-12-10.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-12-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-04-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-04-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-04-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-30-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-06-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-06-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-06-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-11-02.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-20-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-13-11.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-3F-7F.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-14-05.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-14-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-09-0c.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-09-05.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-09-07.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-09-06.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-09-04.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-07-03.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : A5-07-01.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D1079-00-00.xml
[2022-03-11 15:19:26][INFO] : Loading profile file : D1079-01-00.xml
[2022-03-11 15:19:26][INFO] : Successfully loaded 95 profiles !
[2022-03-11 15:19:26][DEBUG] : Writing PID 4613 to /tmp/jeedom/openenocean/deamon.pid
[2022-03-11 15:19:26][DEBUG] : Init request module v2.21.0
[2022-03-11 15:19:26][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:81
[2022-03-11 15:19:26][DEBUG] : http://127.0.0.1:81 "GET /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5 HTTP/1.1" 200 0
[2022-03-11 15:19:26][DEBUG] : Socket interface started
[2022-03-11 15:19:26][DEBUG] : LoopNetServer Thread started
[2022-03-11 15:19:26][DEBUG] : Start listening...
[2022-03-11 15:19:26][DEBUG] : Listening on: [127.0.0.1:55006]
[2022-03-11 15:19:26][INFO] : SerialCommunicator started
[2022-03-11 15:19:26][DEBUG] : Replacing Packet.optional with default value.
[2022-03-11 15:19:26][INFO] : Sending packet
[2022-03-11 15:19:26][DEBUG] : 0x05 ['0x8'] [] OrderedDict()
[2022-03-11 15:19:26][DEBUG] : [85, 0, 5, 1, 2, 219, 0, 255, 234, 209, 0, 10, 179]
[2022-03-11 15:19:26][DEBUG] : 0x02 ['0x0', '0xff', '0xea', '0xd1', '0x0'] ['0xa'] OrderedDict()
[2022-03-11 15:19:26][INFO] : The Base ID of your controler is FFEAD100.
[2022-03-11 15:19:26][DEBUG] : Send to jeedom : {'baseid': 'FFEAD100'}
[2022-03-11 15:19:26][DEBUG] : Read Socket Thread Launched
[2022-03-11 15:19:26][DEBUG] : Read Device Thread Launched
[2022-03-11 15:19:26][DEBUG] : Send to jeedom : {'started': 1}
[2022-03-11 15:19:26][DEBUG] : Receive response packet : 2
[2022-03-11 15:19:26][DEBUG] : Response is : OK
[2022-03-11 15:19:26][DEBUG] : http://127.0.0.1:81 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5 HTTP/1.1" 200 0
[2022-03-11 15:19:26][INFO] : Daemon alive sending known devices
[2022-03-11 15:19:26][DEBUG] : Client connected to [127.0.0.1:45252]
[2022-03-11 15:19:26][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"04120D4E","profils":[{"func":"01","type":"0c","rorg":"d2","ignoreRelease":"","allButtons":""}]}}
[2022-03-11 15:19:26][DEBUG] : Client disconnected from [127.0.0.1:45252]
[2022-03-11 15:19:26][DEBUG] : Client connected to [127.0.0.1:45254]
[2022-03-11 15:19:26][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"0590A2A7","profils":[{"func":"01","type":"0f","rorg":"d2","ignoreRelease":1,"allButtons":""}]}}
[2022-03-11 15:19:26][DEBUG] : Client disconnected from [127.0.0.1:45254]
[2022-03-11 15:19:26][DEBUG] : Client connected to [127.0.0.1:45256]
[2022-03-11 15:19:26][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"05082B75","profils":[{"func":"01","type":"12","rorg":"d2","ignoreRelease":1,"allButtons":""}]}}
[2022-03-11 15:19:26][DEBUG] : Client disconnected from [127.0.0.1:45256]
[2022-03-11 15:19:26][DEBUG] : Client connected to [127.0.0.1:45258]
[2022-03-11 15:19:26][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"04120E61","profils":[{"func":"01","type":"0c","rorg":"d2","ignoreRelease":"","allButtons":""}]}}
[2022-03-11 15:19:26][DEBUG] : Client disconnected from [127.0.0.1:45258]
[2022-03-11 15:19:26][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-03-11 15:19:26][DEBUG] : Received command from jeedom : add
[2022-03-11 15:19:26][DEBUG] : Add device : {u'id': u'04120D4E', u'profils': [{u'rorg': u'd2', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'0c', u'func': u'01'}]}
[2022-03-11 15:19:27][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-03-11 15:19:27][DEBUG] : Received command from jeedom : add
[2022-03-11 15:19:27][DEBUG] : Add device : {u'id': u'0590A2A7', u'profils': [{u'rorg': u'd2', u'ignoreRelease': 1, u'allButtons': u'', u'type': u'0f', u'func': u'01'}]}
[2022-03-11 15:19:27][DEBUG] : Add device : {u'id': u'05082B75', u'profils': [{u'rorg': u'd2', u'ignoreRelease': 1, u'allButtons': u'', u'type': u'12', u'func': u'01'}]}
[2022-03-11 15:19:27][DEBUG] : Add device : {u'id': u'04120E61', u'profils': [{u'rorg': u'd2', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'0c', u'func': u'01'}]}
[2022-03-11 15:19:27][DEBUG] : [85, 0, 5, 1, 2, 219, 0, 255, 234, 209, 0, 10, 179]
[2022-03-11 15:19:27][DEBUG] : 0x02 ['0x0', '0xff', '0xea', '0xd1', '0x0'] ['0xa'] OrderedDict()
[2022-03-11 15:19:27][INFO] : Sending packet
[2022-03-11 15:19:27][DEBUG] : 0x05 ['0x3'] [] OrderedDict()
[2022-03-11 15:19:27][DEBUG] : Receive response packet : 2
[2022-03-11 15:19:27][DEBUG] : Response is : OK
[2022-03-11 15:19:27][DEBUG] : [85, 0, 33, 0, 2, 38, 0, 2, 15, 0, 0, 2, 6, 9, 0, 5, 145, 213, 162, 69, 79, 1, 3, 71, 65, 84, 69, 87, 65, 89, 67, 84, 82, 76, 0, 0, 0, 0, 0, 70]
[2022-03-11 15:19:27][DEBUG] : 0x02 ['0x0', '0x2', '0xf', '0x0', '0x0', '0x2', '0x6', '0x9', '0x0', '0x5', '0x91', '0xd5', '0xa2', '0x45', '0x4f', '0x1', '0x3', '0x47', '0x41', '0x54', '0x45', '0x57', '0x41', '0x59', '0x43', '0x54', '0x52', '0x4c', '0x0', '0x0', '0x0', '0x0', '0x0'] [] OrderedDict()
[2022-03-11 15:19:27][DEBUG] : Send to jeedom : {'app_description': 'GATEWAYCTRL\x00\x00\x00\x00\x00', 'app_version': u'02:0F:00:00', 'return_code': u'00', 'api_version': u'02:06:09:00', 'chip_version': u'45:4F:01:03'}
[2022-03-11 15:19:27][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:81
[2022-03-11 15:19:27][DEBUG] : http://127.0.0.1:81 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5 HTTP/1.1" 200 0
[2022-03-11 15:19:28][DEBUG] : Client connected to [127.0.0.1:45278]
[2022-03-11 15:19:28][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"04120D4E","profils":[{"func":"01","type":"0c","rorg":"d2","ignoreRelease":"","allButtons":""}]}}
[2022-03-11 15:19:28][DEBUG] : Client disconnected from [127.0.0.1:45278]
[2022-03-11 15:19:28][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-03-11 15:19:28][DEBUG] : Received command from jeedom : add
[2022-03-11 15:19:28][DEBUG] : Add device : {u'id': u'04120D4E', u'profils': [{u'rorg': u'd2', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'0c', u'func': u'01'}]}
[2022-03-11 15:19:28][DEBUG] : Client connected to [127.0.0.1:45280]
[2022-03-11 15:19:28][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"0590A2A7","profils":[{"func":"01","type":"0f","rorg":"d2","ignoreRelease":1,"allButtons":""}]}}
[2022-03-11 15:19:28][DEBUG] : Client disconnected from [127.0.0.1:45280]
[2022-03-11 15:19:28][DEBUG] : Client connected to [127.0.0.1:45282]
[2022-03-11 15:19:28][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"05082B75","profils":[{"func":"01","type":"12","rorg":"d2","ignoreRelease":1,"allButtons":""}]}}
[2022-03-11 15:19:28][DEBUG] : Client disconnected from [127.0.0.1:45282]
[2022-03-11 15:19:28][DEBUG] : Client connected to [127.0.0.1:45284]
[2022-03-11 15:19:28][DEBUG] : Message read from socket: {"apikey":"8MYFVpg7AOUCWCGWqFdgrhJ4OZnCjDfhC5l4VLlYaEhfvVPX5kk3LaRTSE06ZWC5","cmd":"add","device":{"id":"04120E61","profils":[{"func":"01","type":"0c","rorg":"d2","ignoreRelease":"","allButtons":""}]}}
[2022-03-11 15:19:28][DEBUG] : Client disconnected from [127.0.0.1:45284]
[2022-03-11 15:19:28][DEBUG] : Add device : {u'id': u'0590A2A7', u'profils': [{u'rorg': u'd2', u'ignoreRelease': 1, u'allButtons': u'', u'type': u'0f', u'func': u'01'}]}
[2022-03-11 15:19:28][DEBUG] : Add device : {u'id': u'05082B75', u'profils': [{u'rorg': u'd2', u'ignoreRelease': 1, u'allButtons': u'', u'type': u'12', u'func': u'01'}]}
[2022-03-11 15:19:28][DEBUG] : Add device : {u'id': u'04120E61', u'profils': [{u'rorg': u'd2', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'0c', u'func': u'01'}]}
[2022-03-11 15:19:35][DEBUG] : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 1, 4, 18, 14, 152, 0, 0, 255, 255, 255, 255, 45, 0, 38]
[2022-03-11 15:19:35][DEBUG] : 04:12:0E:98->FF:FF:FF:FF (-45 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x1', '0x4', '0x12', '0xe', '0x98', '0x0'] ['0x0', '0xff', '0xff', '0xff', '0xff', '0x2d', '0x0'] OrderedDict()
[2022-03-11 15:19:35][DEBUG] : Message is repeated 0 times
[2022-03-11 15:19:35][DEBUG] : {'repeat': '0', 'dBm': '-45', 'rorg': 'd2', 'destination': 'FFFFFFFF', 'cmd': 7, 'packet_type': '1', 'func': '01', 'type': '01', 'id': '04120E98', 'manufacturer': '000'}
[2022-03-11 15:19:35][DEBUG] : Not decode because it's an unknown device or I'am not in learn mode or telegram is not a learn telegram 04120E98 packet learn is True
Depuis quelque temps j’ai une remonté de consommation en watt sur certain de mes radiateurs Alors que ceci son sur OFF…
J’ai interverti certain module pour voir , mes résultat sont toujourss identique, une fois les module inversé cela fait pareil
J’ai déplacé ma clé Enocean même a 1 mètre du module le problème persiste.
Ma clé est une Enocean USB300
