C’est aussi des messages que je retrouve dans mes log
De nouveau le phénomène vu ce matin mais je crois à la vue des log que cela a démarré hier mais j’étais dans le jardin donc j’ai pas fait attention.
[3/29/2021, 07:00:20][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"10"},{"command":"speak","value":"L'alarme de la Maison est désactivée"},{"command":"volume","value":"37"}] Query: {"text":"L'alarme de la Maison est désactivée","volume":"10","lastvolume":"37","device":"G091EV0805261NSQ","value":"L'alarme de la Maison est désactivée"}
[3/29/2021, 07:00:28][ERROR] : Alexa-API: Error: no body Command: volume Query: {"replay":"1","text":"L'alarme de la Maison est désactivée","volume":"10","lastvolume":"37","device":"G091EV0805261NSQ","value":"10"}
[3/29/2021, 07:00:28][] : {API}: Alexa.DeviceControls.Volume: no body
[3/29/2021, 07:00:28][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"10"},{"command":"speak","value":"L'alarme de la Maison est désactivée"},{"command":"volume","value":"37"}] Query: {"replay":"1","text":"L'alarme de la Maison est désactivée","volume":"10","lastvolume":"37","device":"G091EV0805261NSQ","value":"L'alarme de la Maison est désactivée"}
[3/29/2021, 08:14:46][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"Ouverture de la porte de l'atelier"},{"command":"volume","value":"37"}] Query: {"text":"Ouverture de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"Ouverture de la porte de l'atelier"}
[3/29/2021, 08:14:54][ERROR] : Alexa-API: Error: no body Command: volume Query: {"replay":"1","text":"Ouverture de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"30"}
[3/29/2021, 08:14:54][] : {API}: Alexa.DeviceControls.Volume: no body
[3/29/2021, 08:14:55][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"Ouverture de la porte de l'atelier"},{"command":"volume","value":"37"}] Query: {"replay":"1","text":"Ouverture de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"Ouverture de la porte de l'atelier"}
[3/29/2021, 08:14:55][ERROR] : Alexa-API: Error: no body Command: volume Query: {"replay":"1","text":"Ouverture de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"30"}
[3/29/2021, 08:14:55][] : {API}: Alexa.DeviceControls.Volume: no body
[3/29/2021, 08:15:15][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"FERMETURE de la porte de l'atelier"},{"command":"volume","value":"37"}] Query: {"text":"FERMETURE de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"FERMETURE de la porte de l'atelier"}
[3/29/2021, 08:15:23][ERROR] : Alexa-API: Error: no body Command: volume Query: {"replay":"1","text":"FERMETURE de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"30"}
[3/29/2021, 08:15:23][] : {API}: Alexa.DeviceControls.Volume: no body
[3/29/2021, 08:15:23][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"FERMETURE de la porte de l'atelier"},{"command":"volume","value":"37"}] Query: {"replay":"1","text":"FERMETURE de la porte de l'atelier","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"FERMETURE de la porte de l'atelier"}
[3/29/2021, 08:22:01][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"Hello Comment ça va ce matin ?"},{"command":"volume","value":"37"}] Query: {"text":"Hello Comment ça va ce matin ?","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"Hello Comment ça va ce matin ?"}
[3/29/2021, 08:22:09][ERROR] : Alexa-API: Error: no body Command: volume Query: {"replay":"1","text":"Hello Comment ça va ce matin ?","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"30"}
[3/29/2021, 08:22:09][] : {API}: Alexa.DeviceControls.Volume: no body
[3/29/2021, 08:22:09][ERROR] : Alexa-API: Error: no body Commands: [{"command":"volume","value":"30"},{"command":"speak","value":"Hello Comment ça va ce matin ?"},{"command":"volume","value":"37"}] Query: {"replay":"1","text":"Hello Comment ça va ce matin ?","volume":"30","lastvolume":"37","device":"G091EV0805261NSQ","value":"Hello Comment ça va ce matin ?"}
Relance du démon ensuite et cela fonctionne à nouveau
ok, on ne sait pas ce qui s’est passé puisque cela semble aléatoire
Cochez svp « résolu » si le sujet est clos
Le sujet est pas clos mais cela se produit très régulièrements et franchement je ne sais pas quoi dire non plus
On a mis des logs et pas de retour sur les erreurs qui sont indiquées …
Oui je sais mais j’ai pas mieux pour aiguiller sur ce qu’il se passe
Votre souci est aléatoire ? qu’est ce qui déclenche les erreurs ?
un scénario demande de faire parler Alexa.
Tout marche bien puis a un moment plus rien alexa ne parle plus et si on regarde le log il y a ces erreurs.
On relance le démon
Cela revient dans l’ordre.
Puis au bout de quelques jours cela recommence et ainsi de suite.
Ensuite si on n’arrive pas à se comprendre un audio pour expliquer peut se faire j’ai pas de soucis avec ça
Bonjour Jérôme,
Avez vous réinstallé les dépendances car depuis la dernière béta il y a eu des changements en autre sur la partie nodejs qui est désormais en version 14.16.0.
Bonjour @iPapy
Alors les dépendances date du 17 mars 2021.
Mais je veux bien les relancer cela ne mange pas de pain comme on dit
Relance effectuée et j’ai vu qu’il y avait une mise à jour en plus aujourd’hui donc mise à jour faite aussi
OK, tiens nous au courant
Oui dès que cela déraille je vous le dis.
Je vais supprimer le log d’ailleurs pour partir avec des balles neuves
par curiosité, tu peux montrer le scenario qui fait planter
Bon de nouveau le soucis ce matin malgré l’installation de la dernière béta avec résinstallation des dépendances … J’ai mis en place un redémarrage automatique pour compenser ce problème.
Salut essai d’installer la dernière version du plugin
SVP, 1 discussion = 1 problème !!! C’est la base du fonctionnement de Community…
Si vous n’arrivez pas à avoir de réponse, c’est parce que vous noyez tous vos questions au milieu d’autres.
@jerome6994 tu peux cocher résolu, cette discussion dérive et plus personne ne suit plus rien. Merci
