Depuis quelques jours mes notes ne sont plus récupérées par le plugin.
J’ai l’erreur :
[2023-12-09 08:48:31]DEBUG : synchronize : début
[2023-12-09 08:48:31]DEBUG : getNotes : début &
[2023-12-09 08:48:31]DEBUG : Commande envoyée : sudo /var/www/html/plugins/gkeep/core/class/../../resources/venv/bin/python3 /var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py --username sebxain@xxxl.com --token "aas_et/AKppINxxxxxU_ezYv-cecQR677yb06c=" get_notes
[2023-12-09 08:48:32]DEBUG : Résultat brut Traceback (most recent call last): File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 291, in _load self._title = raw['webLink']['title'] KeyError: 'title' The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 902, in main() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 792, in main manager.get_notes() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 180, in get_notes success = keep.resume(self.username, master_token) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 722, in resume self.load(auth, state, sync) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 749, in load self.sync(True) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1024, in sync self._sync_notes(resync) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1074, in _sync_notes self._parseNodes(changes["nodes"]) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1110, in _parseNodes node = _node.from_json(raw_node) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1930, in from_json node.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1191, in _load super(TopLevelNode, self)._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1046, in _load self.annotations.load(raw['annotationsGroup']) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 524, in _load annotation = self.from_json(raw_annotation) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 505, in from_json annotation.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 450, in _load self._entries[key] = NodeAnnotations.from_json({key: entry}) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 505, in from_json annotation.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 216, in load raise_from(exception.ParseException('Parse error in %s' % (type(self)), raw), e) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/future/utils/__init__.py", line 406, in raise_from exec(execstr, myglobals, mylocals) File "", line 1, in gkeepapi.exception.ParseException: Parse error in
[2023-12-09 08:48:32]DEBUG : sendCmdAndFormatResult : Résultat brut Traceback (most recent call last): File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 291, in _load self._title = raw['webLink']['title'] KeyError: 'title' The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 902, in main() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 792, in main manager.get_notes() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 180, in get_notes success = keep.resume(self.username, master_token) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 722, in resume self.load(auth, state, sync) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 749, in load self.sync(True) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1024, in sync self._sync_notes(resync) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1074, in _sync_notes self._parseNodes(changes["nodes"]) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/__init__.py", line 1110, in _parseNodes node = _node.from_json(raw_node) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1930, in from_json node.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1191, in _load super(TopLevelNode, self)._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 1046, in _load self.annotations.load(raw['annotationsGroup']) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 524, in _load annotation = self.from_json(raw_annotation) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 505, in from_json annotation.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 214, in load self._load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 450, in _load self._entries[key] = NodeAnnotations.from_json({key: entry}) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 505, in from_json annotation.load(raw) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/gkeepapi/node.py", line 216, in load raise_from(exception.ParseException('Parse error in %s' % (type(self)), raw), e) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages/future/utils/__init__.py", line 406, in raise_from exec(execstr, myglobals, mylocals) File "", line 1, in gkeepapi.exception.ParseException: Parse error in
[2023-12-09 08:48:32]INFO : sendCmdAndFormatResult : Résultat array null
[2023-12-09 08:48:32]WARNING : Erreur lors de l'exécution de la commande : --username sxxxxxin@xxxx.com --token "aas_et/AKppINZcRmxxxLGLU4KHU_ezYv-cecQR677yb06c=" get_notes
[2023-12-09 08:48:32]DEBUG : synchronize : fin
Rien de plus comme erreur.
Google a changé quelque chose ou c’est le plugin (ou les deux
