il semblerai que je ne récupère pas toutes les informations…
Cordialement
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_myaudi
0003|+ echo 1
0004|+ echo 2
0005|+ sudo apt update
0006|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0007|Hit:1 http://deb.debian.org/debian bullseye InRelease
0008|Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
0009|Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
0010|Hit:4 https://download.docker.com/linux/debian bullseye InRelease
0011|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0012|Get:6 http://security.debian.org/debian-security bullseye-security/main Sources [169 kB]
0013|Get:7 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [269 kB]
0014|Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
0015|Fetched 531 kB in 2s (353 kB/s)
0016|Reading package lists...
0017|Building dependency tree...
0018|Reading state information...
0019|6 packages can be upgraded. Run 'apt list --upgradable' to see them.
0020|+ echo 3
0021|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
0022|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0023|Reading package lists...
0024|Building dependency tree...
0025|Reading state information...
0026|python3-requests is already the newest version (2.25.1+dfsg-2).
0027|The following package was automatically installed and is no longer required:
0028|linux-image-5.10.0-25-amd64
0029|Use 'sudo apt autoremove' to remove it.
0030|0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
0031|+ echo 4
0032|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-bs4
0033|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0034|Reading package lists...
0035|Building dependency tree...
0036|Reading state information...
0037|python3-bs4 is already the newest version (4.9.3-1).
0038|The following package was automatically installed and is no longer required:
0039|linux-image-5.10.0-25-amd64
0040|Use 'sudo apt autoremove' to remove it.
0041|0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
0042|+ echo 5
0043|++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
0044|++ cut -f 2-
0045|++ awk '$1 <= 4'
0046|+ RESULTTODELETE=
0047|++ echo ''
0048|++ sed 's, ,\ ,g'
0049|+ RESULTTODELETE2=
0050|+ echo ''
0051|+ xargs rm -rf
0052|+ echo 6
0053|+ sudo pip3 cache purge
0054|Files removed: 1892
0055|+ echo 7
0056|+ sudo pip3 install --upgrade pip
0057|Requirement already satisfied: pip in /usr/local/lib/python3.9/dist-packages (24.0)
0058|DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
0059|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0060|+ echo 8
0061|+ sudo pip3 install --force-reinstall --upgrade requests
0062|Collecting requests
0063|Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
0064|Collecting charset-normalizer<4,>=2 (from requests)
0065|Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (33 kB)
0066|Collecting idna<4,>=2.5 (from requests)
0067|Downloading idna-3.6-py3-none-any.whl.metadata (9.9 kB)
0068|Collecting urllib3<3,>=1.21.1 (from requests)
0069|Downloading urllib3-2.2.1-py3-none-any.whl.metadata (6.4 kB)
0070|Collecting certifi>=2017.4.17 (from requests)
0071|Downloading certifi-2024.2.2-py3-none-any.whl.metadata (2.2 kB)
0072|Downloading requests-2.31.0-py3-none-any.whl (62 kB)
0073|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 4.9 MB/s eta 0:00:00
0074|Downloading certifi-2024.2.2-py3-none-any.whl (163 kB)
0075|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 163.8/163.8 kB 7.2 MB/s eta 0:00:00
0076|Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
0077|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 142.3/142.3 kB 15.7 MB/s eta 0:00:00
0078|Downloading idna-3.6-py3-none-any.whl (61 kB)
0079|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.6/61.6 kB 7.5 MB/s eta 0:00:00
0080|Downloading urllib3-2.2.1-py3-none-any.whl (121 kB)
0081|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 121.1/121.1 kB 14.1 MB/s eta 0:00:00
0082|DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
0083|Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
0084|Attempting uninstall: urllib3
0085|Found existing installation: urllib3 2.2.1
0086|Uninstalling urllib3-2.2.1:
0087|Successfully uninstalled urllib3-2.2.1
0088|Attempting uninstall: idna
0089|Found existing installation: idna 3.6
0090|Uninstalling idna-3.6:
0091|Successfully uninstalled idna-3.6
0092|Attempting uninstall: charset-normalizer
0093|Found existing installation: charset-normalizer 3.3.2
0094|Uninstalling charset-normalizer-3.3.2:
0095|Successfully uninstalled charset-normalizer-3.3.2
0096|Attempting uninstall: certifi
0097|Found existing installation: certifi 2024.2.2
0098|Uninstalling certifi-2024.2.2:
0099|Successfully uninstalled certifi-2024.2.2
0100|Attempting uninstall: requests
0101|Found existing installation: requests 2.31.0
0102|Uninstalling requests-2.31.0:
0103|Successfully uninstalled requests-2.31.0
0104|ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
0105|gpsoauth 1.0.4 requires urllib3<2.0, but you have urllib3 2.2.1 which is incompatible.
0106|mitmproxy 9.0.1 requires asgiref<3.6,>=3.2.10, but you have asgiref 3.7.2 which is incompatible.
0107|mitmproxy 9.0.1 requires Brotli<1.1,>=1.0, but you have brotli 1.1.0 which is incompatible.
0108|mitmproxy 9.0.1 requires cryptography<38.1,>=38.0, but you have cryptography 42.0.5 which is incompatible.
0109|mitmproxy 9.0.1 requires flask<2.3,>=1.1.1, but you have flask 3.0.2 which is incompatible.
0110|mitmproxy 9.0.1 requires pyOpenSSL<22.2,>=22.1, but you have pyopenssl 24.0.0 which is incompatible.
0111|mitmproxy 9.0.1 requires pyparsing<3.1,>=2.4.2, but you have pyparsing 3.1.1 which is incompatible.
0112|mitmproxy 9.0.1 requires ruamel.yaml<0.18,>=0.16, but you have ruamel-yaml 0.18.6 which is incompatible.
0113|mitmproxy 9.0.1 requires typing-extensions<4.5,>=4.3; python_version < "3.10", but you have typing-extensions 4.10.0 which is incompatible.
0114|mitmproxy 9.0.1 requires urwid<2.2,>=2.1.1, but you have urwid 2.6.6 which is incompatible.
0115|mitmproxy 9.0.1 requires zstandard<0.20,>=0.11, but you have zstandard 0.22.0 which is incompatible.
0116|Successfully installed certifi-2024.2.2 charset-normalizer-3.3.2 idna-3.6 requests-2.31.0 urllib3-2.2.1
0117|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0118|+ echo 9
0119|+ sudo pip3 install --force-reinstall --upgrade voluptuous
0120|Collecting voluptuous
0121|Downloading voluptuous-0.14.2-py3-none-any.whl.metadata (20 kB)
0122|Downloading voluptuous-0.14.2-py3-none-any.whl (31 kB)
0123|DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
0124|Installing collected packages: voluptuous
0125|Attempting uninstall: voluptuous
0126|Found existing installation: voluptuous 0.14.2
0127|Uninstalling voluptuous-0.14.2:
0128|Successfully uninstalled voluptuous-0.14.2
0129|Successfully installed voluptuous-0.14.2
0130|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0131|+ echo 10
0132|+ sudo pip3 install --force-reinstall --upgrade aiohttp
0133|Collecting aiohttp
0134|Downloading aiohttp-3.9.3-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (7.4 kB)
0135|Collecting aiosignal>=1.1.2 (from aiohttp)
0136|Downloading aiosignal-1.3.1-py3-none-any.whl.metadata (4.0 kB)
0137|Collecting attrs>=17.3.0 (from aiohttp)
0138|Downloading attrs-23.2.0-py3-none-any.whl.metadata (9.5 kB)
0139|Collecting frozenlist>=1.1.1 (from aiohttp)
0140|Downloading frozenlist-1.4.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (12 kB)
0141|Collecting multidict<7.0,>=4.5 (from aiohttp)
0142|Downloading multidict-6.0.5-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.2 kB)
0143|Collecting yarl<2.0,>=1.0 (from aiohttp)
0144|Downloading yarl-1.9.4-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (31 kB)
0145|Collecting async-timeout<5.0,>=4.0 (from aiohttp)
0146|Downloading async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
0147|Collecting idna>=2.0 (from yarl<2.0,>=1.0->aiohttp)
0148|Using cached idna-3.6-py3-none-any.whl.metadata (9.9 kB)
0149|Downloading aiohttp-3.9.3-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (1.2 MB)
0150|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 16.4 MB/s eta 0:00:00
0151|Downloading aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
0152|Downloading async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
0153|Downloading attrs-23.2.0-py3-none-any.whl (60 kB)
0154|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 60.8/60.8 kB 9.2 MB/s eta 0:00:00
0155|Downloading frozenlist-1.4.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl (240 kB)
0156|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 240.7/240.7 kB 25.9 MB/s eta 0:00:00
0157|Downloading multidict-6.0.5-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (123 kB)
0158|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 123.8/123.8 kB 14.8 MB/s eta 0:00:00
0159|Downloading yarl-1.9.4-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (304 kB)
0160|━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 304.3/304.3 kB 29.0 MB/s eta 0:00:00
0161|Using cached idna-3.6-py3-none-any.whl (61 kB)
0162|DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
0163|Installing collected packages: multidict, idna, frozenlist, attrs, async-timeout, yarl, aiosignal, aiohttp
0164|Attempting uninstall: multidict
0165|Found existing installation: multidict 6.0.5
0166|Uninstalling multidict-6.0.5:
0167|Successfully uninstalled multidict-6.0.5
0168|Attempting uninstall: idna
0169|Found existing installation: idna 3.6
0170|Uninstalling idna-3.6:
0171|Successfully uninstalled idna-3.6
0172|Attempting uninstall: frozenlist
0173|Found existing installation: frozenlist 1.4.1
0174|Uninstalling frozenlist-1.4.1:
0175|Successfully uninstalled frozenlist-1.4.1
0176|Attempting uninstall: attrs
0177|Found existing installation: attrs 23.2.0
0178|Uninstalling attrs-23.2.0:
0179|Successfully uninstalled attrs-23.2.0
0180|Attempting uninstall: async-timeout
0181|Found existing installation: async-timeout 4.0.3
0182|Uninstalling async-timeout-4.0.3:
0183|Successfully uninstalled async-timeout-4.0.3
0184|Attempting uninstall: yarl
0185|Found existing installation: yarl 1.9.4
0186|Uninstalling yarl-1.9.4:
0187|Successfully uninstalled yarl-1.9.4
0188|Attempting uninstall: aiosignal
0189|Found existing installation: aiosignal 1.3.1
0190|Uninstalling aiosignal-1.3.1:
0191|Successfully uninstalled aiosignal-1.3.1
0192|Attempting uninstall: aiohttp
0193|Found existing installation: aiohttp 3.9.3
0194|Uninstalling aiohttp-3.9.3:
0195|Successfully uninstalled aiohttp-3.9.3
0196|Successfully installed aiohttp-3.9.3 aiosignal-1.3.1 async-timeout-4.0.3 attrs-23.2.0 frozenlist-1.4.1 idna-3.6 multidict-6.0.5 yarl-1.9.4
0197|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0198|+ echo 11
0199|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end myaudi
0200|+ rm /tmp/jeedom_install_in_progress_myaudi
0201|+ echo '*******************End of package installation******************'
0202|*******************End of package installation******************
0000|[2024-03-17 09:12:05.054] INFO : Start daemon
0001|[2024-03-17 09:12:05.055] INFO : Log level : debug
0002|[2024-03-17 09:12:05.055] DEBUG : Socket port : 55066
0003|[2024-03-17 09:12:05.055] DEBUG : PID file : /tmp/jeedom/myaudi/deamon.pid
0004|[2024-03-17 09:12:05.055] DEBUG : country : FR
0005|[2024-03-17 09:12:05.055] DEBUG : Writing PID 691794 to /tmp/jeedom/myaudi/deamon.pid
0006|[2024-03-17 09:12:05.055] DEBUG : Init request module v2.31.0
0007|[2024-03-17 09:12:05.055] DEBUG : Using selector: EpollSelector
0008|[2024-03-17 09:12:08.540] ERROR : support_status_report set to False: 403
0009|[2024-03-17 09:12:08.886] ERROR : Unable to obtain the vehicle longTerm tripdata of WAUZZZFY2L2112593: 204, message='', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WAUZZZFY2L2112593/tripdata/longTerm?type=list&from=1970-01-01T00:00:00Z&to=2024-03-17T09:42:08Z')
0010|[2024-03-17 09:12:09.012] ERROR : support_position set to False: 403
0011|[2024-03-17 09:12:09.308] ERROR : support_charger set to False: 403
0012|[2024-03-17 09:12:09.458] ERROR : support_preheater set to False: 502
0013|[2024-03-17 09:12:09.458] DEBUG : End of Update
0014|[2024-03-17 09:12:09.458] DEBUG : Updating vehicule data for Audi Q5 TFSI e with vin : wauzzzfy2l2112593
0015|[2024-03-17 09:12:09.458] DEBUG : Start listening
0016|[2024-03-17 09:12:09.459] DEBUG : Send to jeedom : {'vehicle': 'wauzzzfy2l2112593', 'csid': '9a91a278750a41c9ad3bc28329fe3b70', 'title': 'Audi Q5 TFSI e', 'model': 'Audi Q5 TFSI e Sport 50 TFSI e quattro S tronic', 'model_year': 2020, 'model_family': '', 'support_status_report': False, 'support_ac': True, 'support_position': False, 'support_preheater': False, 'support_charger': False, 'climatisationState': {}}
0017|[2024-03-17 09:12:09.460] DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0018|[2024-03-17 09:12:09.460] DEBUG : Socket interface started
0019|[2024-03-17 09:12:09.461] DEBUG : LoopNetServer Thread started
0020|[2024-03-17 09:12:09.461] DEBUG : Listening on: [localhost:55066]
0021|[2024-03-17 09:12:09.473] DEBUG : http://127.0.0.1:80 "POST /plugins/myaudi/core/php/jeeMyAudi.php?apikey=qTdiokqcVbM3KubGEmvJ5F9BV77brgjdUnLN0xBEFhAXG7C73DMBMkAZVYS0jp2N HTTP/1.1" 200 0
0022|[2024-03-17 09:12:10.712] DEBUG : Client connected to [127.0.0.1:39158]
0023|[2024-03-17 09:12:10.712] DEBUG : Message read from socket: b'{"method":"getVehicles","apikey":"qTdiokqcVbM3KubGEmvJ5F9BV77brgjdUnLN0xBEFhAXG7C73DMBMkAZVYS0jp2N"}'
0024|[2024-03-17 09:12:10.712] DEBUG : Client disconnected from [127.0.0.1:39158]
0025|[2024-03-17 09:12:10.721] DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
0026|[2024-03-17 09:12:10.721] ERROR : Unclosed client session
0027|client_session: <aiohttp.client.ClientSession object at 0x7f80afc39e80>
0028|[2024-03-17 09:12:10.722] ERROR : Unclosed connector
0029|connections: ['[(<aiohttp.client_proto.ResponseHandler object at 0x7f80b0c7d580>, 567584.29685559)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80af248040>, 567585.546334309)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80af2393a0>, 567585.917372236)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80af1fef40>, 567586.515407637)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80af1fea60>, 567587.147352916)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80afc47700>, 567588.008623528)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7f80af248940>, 567588.580386965)]']
0030|connector: <aiohttp.connector.TCPConnector object at 0x7f80afc39160>
0031|[2024-03-17 09:12:14.022] ERROR : support_status_report set to False: 403
0032|[2024-03-17 09:12:14.390] ERROR : Unable to obtain the vehicle longTerm tripdata of WAUZZZFY2L2112593: 204, message='', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WAUZZZFY2L2112593/tripdata/longTerm?type=list&from=1970-01-01T00:00:00Z&to=2024-03-17T09:42:14Z')
0033|[2024-03-17 09:12:14.481] ERROR : support_position set to False: 403
0034|[2024-03-17 09:12:14.747] ERROR : support_charger set to False: 403
0035|[2024-03-17 09:12:14.896] ERROR : support_preheater set to False: 502
0036|[2024-03-17 09:12:14.896] DEBUG : End of Update
0037|[2024-03-17 09:12:14.896] DEBUG : Updating vehicule data for Audi Q5 TFSI e with vin : wauzzzfy2l2112593
0038|[2024-03-17 09:12:14.896] DEBUG : Send to jeedom : {'vehicle': 'wauzzzfy2l2112593', 'csid': '9a91a278750a41c9ad3bc28329fe3b70', 'title': 'Audi Q5 TFSI e', 'model': 'Audi Q5 TFSI e Sport 50 TFSI e quattro S tronic', 'model_year': 2020, 'model_family': '', 'support_status_report': False, 'support_ac': True, 'support_position': False, 'support_preheater': False, 'support_charger': False, 'climatisationState': {}}
0039|[2024-03-17 09:12:14.897] DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0040|[2024-03-17 09:12:14.909] DEBUG : http://127.0.0.1:80 "POST /plugins/myaudi/core/php/jeeMyAudi.php?apikey=qTdiokqcVbM3KubGEmvJ5F9BV77brgjdUnLN0xBEFhAXG7C73DMBMkAZVYS0jp2N HTTP/1.1" 200 0
0041|[2024-03-17 09:20:04.265] INFO : Start daemon
0042|[2024-03-17 09:20:04.265] INFO : Log level : debug
0043|[2024-03-17 09:20:04.265] DEBUG : Socket port : 55066
0044|[2024-03-17 09:20:04.265] DEBUG : PID file : /tmp/jeedom/myaudi/deamon.pid
0045|[2024-03-17 09:20:04.265] DEBUG : country : FR
0046|[2024-03-17 09:20:04.265] DEBUG : Writing PID 711112 to /tmp/jeedom/myaudi/deamon.pid
0047|[2024-03-17 09:20:04.265] DEBUG : Init request module v2.31.0
0048|[2024-03-17 09:20:04.265] DEBUG : Using selector: EpollSelector
0049|[2024-03-17 09:20:07.514] ERROR : support_status_report set to False: 403
0050|[2024-03-17 09:20:07.851] ERROR : Unable to obtain the vehicle longTerm tripdata of WAUZZZFY2L2112593: 204, message='', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WAUZZZFY2L2112593/tripdata/longTerm?type=list&from=1970-01-01T00:00:00Z&to=2024-03-17T09:50:07Z')
0051|[2024-03-17 09:20:07.934] ERROR : support_position set to False: 403
0052|[2024-03-17 09:20:08.171] ERROR : support_charger set to False: 403
0053|[2024-03-17 09:20:08.280] ERROR : support_preheater set to False: 502
0054|[2024-03-17 09:20:08.280] DEBUG : End of Update
0055|[2024-03-17 09:20:08.280] DEBUG : Updating vehicule data for Audi Q5 TFSI e with vin : wauzzzfy2l2112593
0056|[2024-03-17 09:20:08.281] DEBUG : Start listening
0057|[2024-03-17 09:20:08.281] DEBUG : Send to jeedom : {'vehicle': 'wauzzzfy2l2112593', 'csid': '9a91a278750a41c9ad3bc28329fe3b70', 'title': 'Audi Q5 TFSI e', 'model': 'Audi Q5 TFSI e Sport 50 TFSI e quattro S tronic', 'model_year': 2020, 'model_family': '', 'support_status_report': False, 'support_ac': True, 'support_position': False, 'support_preheater': False, 'support_charger': False, 'climatisationState': {}}
0058|[2024-03-17 09:20:08.282] DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0059|[2024-03-17 09:20:08.283] DEBUG : Socket interface started
0060|[2024-03-17 09:20:08.283] DEBUG : LoopNetServer Thread started
0061|[2024-03-17 09:20:08.283] DEBUG : Listening on: [localhost:55066]
0062|[2024-03-17 09:20:08.295] DEBUG : http://127.0.0.1:80 "POST /plugins/myaudi/core/php/jeeMyAudi.php?apikey=qTdiokqcVbM3KubGEmvJ5F9BV77brgjdUnLN0xBEFhAXG7C73DMBMkAZVYS0jp2N HTTP/1.1" 200 0
