Mince pourquoi c’est proposé en version stable alors ?
D’autre part j’ai reussi à trouver le bon log j’ai l’impression :
> zigbee2mqtt@2.0.0 start /opt/zigbee2mqtt
> node index.js
Starting Zigbee2MQTT without watchdog.
[2025-01-13 18:55:56] e[34mdebuge[39m: z2m: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2025-01-13.18-32-46'
[2025-01-13 18:55:56] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-01-13 18:55:56] e[34mdebuge[39m: z2m: Can't load state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json (doesn't exist)
[2025-01-13 18:55:56] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #060ae99c)
[2025-01-13 18:55:56] e[34mdebuge[39m: z2m: sd-notify loaded
[2025-01-13 18:55:56] e[32minfoe[39m: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-13 18:55:56] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":18900,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[20],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0\",\"adapter\":\"zigate\"},\"adapter\":{\"disableLED\":false}}"'
[2025-01-13 18:55:56] e[34mdebuge[39m: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyACM0","manufacturer":"0658","pnpId":"usb-0658_0200-if00","vendorId":"0658","productId":"0200"},{"path":"/dev/ttyAMA0"}]
[2025-01-13 18:55:56] e[34mdebuge[39m: zh:adapter:discovery: Unable to match USB adapter: zigate | /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
[2025-01-13 18:55:56] e[34mdebuge[39m: zh:zigate: Adapter concurrent: 2
[2025-01-13 18:55:56] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":18900,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"path":"/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0","adapter":"zigate"},"adapter":{"disableLED":false},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json"}'
[2025-01-13 18:55:56] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-01-13 18:55:56] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-01-13 18:55:56] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-13 18:55:56] e[31merrore[39m: z2m: Exiting...
[2025-01-13 18:55:57] e[31merrore[39m: z2m: Error: failed to connect to zigate adapter Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
at ZiGateAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:99:19)
at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:142:13)
at start (/opt/zigbee2mqtt/index.js:161:5)
ELIFECYCLE Command failed with exit code 1.
Il n’arrive à se connecter à l’adaptateur. Je n’ai pas fait d’upgrade du firmware pour le moment . Je vais d’abord voir ce soucis de version dont tu me parles.
