Hello, une fois n’est pas coutume, je trouve des plugins avec des problèmes ![]()
Jeedom 4.4.3
Plugin RAINBIRD beta et stable, meme combat.
Log rainbird Beta
[2024-05-02 21:46:31] DEBUG : Traceback (most recent call last):
[2024-05-02 21:46:31] DEBUG : File "/var/www/html/plugins/rainbird/resources/rainbird_tool.py", line 21, in <module>
[2024-05-02 21:46:31] DEBUG : import aiohttp
[2024-05-02 21:46:31] DEBUG : ModuleNotFoundError: No module named 'aiohttp'
Log rainbird stable
[2024-05-02 21:56:16] DEBUG : Traceback (most recent call last):
[2024-05-02 21:56:16] DEBUG : File "/var/www/html/plugins/rainbird/resources/get_current_date.py", line 2, in <module>
[2024-05-02 21:56:16] DEBUG : from pyrainbird import RainbirdController
[2024-05-02 21:56:16] DEBUG : File "/var/www/html/plugins/rainbird/resources/pyrainbird/__init__.py", line 16, in <module>
[2024-05-02 21:56:16] DEBUG : from .client import RainbirdClient
[2024-05-02 21:56:16] DEBUG : File "/var/www/html/plugins/rainbird/resources/pyrainbird/client.py", line 5, in <module>
[2024-05-02 21:56:16] DEBUG : import requests
[2024-05-02 21:56:16] DEBUG : ModuleNotFoundError: No module named 'requests'
log install
* Launch install of dependencies *
Thu Apr 25 13:17:23 CEST 2024
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 235 not upgraded.
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [376 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [596 kB]
Fetched 1007 kB in 2s (611 kB/s)
Install modules using apt-get
rm: cannot remove 'env': No such file or directory
python3-venv is already the newest version (3.7.3-1).
Install the required python libraries
Cache entry deserialization failed, entry ignored
Collecting pip
Downloading https://files.pythonhosted.org/packages/8a/6a/19e9fe04fca059ccf770861c7d5721ab4c2aebc539889e97c7977528a53b/pip-24.0-py3-none-any.whl (2.1MB)
Installing collected packages: pip
Found existing installation: pip 18.1
Uninstalling pip-18.1:
Successfully uninstalled pip-18.1
Successfully installed pip-24.0
Collecting pyrainbird==2.1.1
Downloading pyrainbird-2.1.1-py3-none-any.whl.metadata (2.3 kB)
Collecting pycryptodome>=3.16.0 (from pyrainbird==2.1.1)
Downloading pycryptodome-3.20.0-cp35-abi3-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (3.4 kB)
Collecting requests>=2.22.0 (from pyrainbird==2.1.1)
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting PyYAML>=5.4 (from pyrainbird==2.1.1)
Downloading PyYAML-6.0.1-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.1 kB)
Collecting pydantic>=1.10.4 (from pyrainbird==2.1.1)
Downloading pydantic-2.5.3-py3-none-any.whl.metadata (65 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 65.6/65.6 kB 1.7 MB/s eta 0:00:00
Collecting python-dateutil>=2.8.2 (from pyrainbird==2.1.1)
Downloading python_dateutil-2.9.0.post0-py2.py3-none-any.whl.metadata (8.4 kB)
INFO: pip is looking at multiple versions of pyrainbird to determine which version is compatible with other requirements. This could take a while.
ERROR: Ignored the following versions that require a different python version: 0.0.1 Requires-Python >=3.9; 0.0.3 Requires-Python >=3.9; 0.0.4 Requires-Python >=3.9; 0.1.0 Requires-Python >=3.9; 0.2.0 Requires-Python >=3.9; 1.0.0 Requires-Python >=3.9; 1.1.0 Requires-Python >=3.9; 1.2.0 Requires-Python >=3.9; 2.0.0 Requires-Python >=3.9; 2.1.0 Requires-Python >=3.9; 2.6.0 Requires-Python >=3.8; 2.6.0b1 Requires-Python >=3.8; 2.6.1 Requires-Python >=3.8; 2.6.2 Requires-Python >=3.8; 2.6.3 Requires-Python >=3.8; 2.6.4 Requires-Python >=3.8; 2.7.0 Requires-Python >=3.8; 2.7.0b1 Requires-Python >=3.8; 2.7.1 Requires-Python >=3.8; 3.0.0 Requires-Python >=3.10; 3.0.0 Requires-Python >=3.9; 3.0.1 Requires-Python >=3.10; 3.0.1 Requires-Python >=3.9; 4.0.0 Requires-Python >=3.10; 4.0.0 Requires-Python >=3.9; 4.0.1 Requires-Python >=3.10; 4.0.1 Requires-Python >=3.9; 4.0.2 Requires-Python >=3.10; 4.1.0 Requires-Python >=3.9; 4.1.1 Requires-Python >=3.9; 4.1.2 Requires-Python >=3.9; 4.2.0 Requires-Python >=3.9; 4.2.1 Requires-Python >=3.9; 4.2.2 Requires-Python >=3.9; 4.2.3 Requires-Python >=3.9; 4.2.4 Requires-Python >=3.9; 4.2.5 Requires-Python >=3.9; 4.2.6 Requires-Python >=3.9; 4.2.7 Requires-Python >=3.9; 4.2.8 Requires-Python >=3.9; 4.2.9 Requires-Python >=3.9; 4.3.0 Requires-Python >=3.9; 4.4.0 Requires-Python >=3.9; 4.5.0 Requires-Python >=3.9; 4.5.1 Requires-Python >=3.9; 4.5.2 Requires-Python >=3.9; 4.5.4 Requires-Python >=3.9; 5.0.0 Requires-Python >=3.10; 5.0.1 Requires-Python >=3.10; 5.1.0 Requires-Python >=3.10; 5.1.1 Requires-Python >=3.10; 6.0.0 Requires-Python >=3.10; 6.1.0 Requires-Python >=3.10; 6.1.1 Requires-Python >=3.10; 7.0.0 Requires-Python >=3.10; 7.0.1 Requires-Python >=3.10; 7.0.2 Requires-Python >=3.10; 7.0.3 Requires-Python >=3.10; 8.0.0 Requires-Python >=3.10
ERROR: Could not find a version that satisfies the requirement ical>=4.2.9 (from pyrainbird) (from versions: none)
ERROR: No matching distribution found for ical>=4.2.9
Thu Apr 25 13:17:47 CEST 2024
* Install ended *
Log de la config du plugin, j’ai une erreur sur AIOHTTP alors que je l’ai .
pip list
package Version
aiohttp 3.8.6
aiosignal 1.3.1
asn1crypto 0.24.0
async-timeout 4.0.3
asynctest 0.13.0
attrs 23.2.0
certifi 2022.9.24
chardet 3.0.4
charset-normalizer 2.1.1
cryptography 2.6.1
distro-info 0.21
entrypoints 0.3
fail2ban 0.10.2
frozenlist 1.3.3
httplib2 0.11.3
idna 3.4
importlib-metadata 6.7.0
iotop 0.6
keyring 17.1.1
keyrings.alt 3.1.1
multidict 6.0.5
oauthlib 3.2.2
olefile 0.46
pexpect 4.6.0
Pillow 5.4.1
pip 22.3
pycrypto 2.6.1
pycurl 7.43.0.2
PyGObject 3.30.4
pyinotify 0.9.6
pymodbus 2.5.3
pyserial 3.5
PySimpleSOAP 1.16.2
python-apt 1.8.4.3
python-debian 0.1.35
python-debianbts 2.8.2
pyudev 0.24.0
pyxdg 0.25
reportbug 7.5.3-deb10u1
reportlab 3.5.13
requests 2.28.1
requests-oauthlib 1.3.1
SecretStorage 2.3.1
setuptools 65.5.0
six 1.16.0
systemd-python 234
typing_extensions 4.7.1
unattended-upgrades 0.1
urllib3 1.26.12
websocket-client 1.4.2
wheel 0.32.3
yarl 1.9.4
zipp 3.15.0
[notice] A new release of pip available: 22.3 -> 24.0
[notice] To update, run: python3 -m pip install --upgrade pip
Si vous voyez d’où vient le problème !
merci d’avance
