Voici les logs du noeud 120 qui est en DEAD
: 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 61.06ms
[2022-10-16 19:06:48]INFO : node action healNode
[2022-10-16 19:06:48]INFO : Heal network node (120) by requesting the node rediscover their neighbors
[2022-10-16 19:06:48]DEBUG : notif_callback : new notification
[2022-10-16 19:06:48]DEBUG : notif_callback : Notification type : 28, nodeId : 0
[2022-10-16 19:06:48]INFO : 200 GET /node?node_id=120&type=action&action=healNode&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 2.06ms
[2022-10-16 19:06:48]DEBUG : notif_callback : call callback context
[2022-10-16 19:06:48]DEBUG : zwcallback args=[{'controllerState': 'Starting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 1, 'controllerErrorDoc': 'None.', 'homeId': 3396522750L, 'controllerStateDoc': 'The command is starting.'}]
[2022-10-16 19:06:48]DEBUG : Z-Wave ControllerCommand : {'controllerState': 'Starting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 1, 'controllerErrorDoc': 'None.', 'homeId': 3396522750L, 'controllerStateDoc': 'The command is starting.'}
[2022-10-16 19:06:48]INFO : The command is starting. (Starting)
[2022-10-16 19:06:48]DEBUG : The controller is busy ? True
[2022-10-16 19:06:48]DEBUG : notif_callback : end
[2022-10-16 19:06:48]DEBUG : zwcallback args=[{'controllerState': 'Error', 'controllerError': 'Failed', 'controllerErrorInt': 10, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 3, 'controllerErrorDoc': 'RemoveFailedNode, RequestNetworkUpdate.', 'homeId': 3396522750L, 'controllerStateDoc': 'Command invocation had error(s) and was aborted.'}]
[2022-10-16 19:06:48]DEBUG : Z-Wave ControllerCommand : {'controllerState': 'Error', 'controllerError': 'Failed', 'controllerErrorInt': 10, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 3, 'controllerErrorDoc': 'RemoveFailedNode, RequestNetworkUpdate.', 'homeId': 3396522750L, 'controllerStateDoc': 'Command invocation had error(s) and was aborted.'}
[2022-10-16 19:06:48]INFO : Command invocation had error(s) and was aborted. (Error)
[2022-10-16 19:06:48]ERROR : RemoveFailedNode, RequestNetworkUpdate. (Failed)
[2022-10-16 19:06:48]DEBUG : The controller is busy ? False
[2022-10-16 19:06:49]INFO : node info all
[2022-10-16 19:06:49]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 88.53ms
[2022-10-16 19:06:51]INFO : node info all
[2022-10-16 19:06:51]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 65.52ms
[2022-10-16 19:06:54]DEBUG : notif_callback : new notification
[2022-10-16 19:06:54]DEBUG : notif_callback : Notification type : 2, nodeId : 40
[2022-10-16 19:06:54]DEBUG : addValueId : ValueID : 72057594713997312
[2022-10-16 19:06:54]DEBUG : addValueId : GetCommandClassId : 48, GetType : 0
[2022-10-16 19:06:54]DEBUG : addValueId : Notification : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_SENSOR_BINARY', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057594713997312L, 'index': 0, 'nodeId': 40, 'value': False, 'label': u'Sensor', 'instance': 1, 'units': u'', 'type': 'Bool'}, 'notificationType': 'ValueChanged', 'nodeId': 40}
[2022-10-16 19:06:54]DEBUG : notif_callback : call callback context
[2022-10-16 19:06:54]DEBUG : zwcallback args=[{'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_SENSOR_BINARY', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057594713997312L, 'index': 0, 'nodeId': 40, 'value': False, 'label': u'Sensor', 'instance': 1, 'units': u'', 'type': 'Bool'}, 'notificationType': 'ValueChanged', 'nodeId': 40}]
[2022-10-16 19:06:54]DEBUG : Z-Wave Notification ValueChanged : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_SENSOR_BINARY', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057594713997312L, 'index': 0, 'nodeId': 40, 'value': False, 'label': u'Sensor', 'instance': 1, 'units': u'', 'type': 'Bool'}, 'notificationType': 'ValueChanged', 'nodeId': 40}
[2022-10-16 19:06:54]DEBUG : value_update. 40 Sensor
[2022-10-16 19:06:54]DEBUG : notif_callback : end
[2022-10-16 19:06:56]INFO : node info getNodeStatistics
[2022-10-16 19:06:56]INFO : 200 GET /node?node_id=120&type=info&info=getNodeStatistics&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 2.19ms
[2022-10-16 19:06:56]INFO : 200 GET /network?type=info&info=getNodesList&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 21.84ms
[2022-10-16 19:06:56]INFO : node info all
[2022-10-16 19:06:56]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 54.04ms
[2022-10-16 19:06:58]DEBUG : notif_callback : new notification
[2022-10-16 19:06:58]DEBUG : notif_callback : Notification type : 2, nodeId : 72
[2022-10-16 19:06:58]DEBUG : addValueId : ValueID : 72057595250900994
[2022-10-16 19:06:58]DEBUG : addValueId : GetCommandClassId : 50, GetType : 2
[2022-10-16 19:06:58]DEBUG : addValueId : Notification : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 23.600000381469727, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:06:58]DEBUG : notif_callback : call callback context
[2022-10-16 19:06:58]DEBUG : zwcallback args=[{'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 23.600000381469727, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}]
[2022-10-16 19:06:58]DEBUG : Z-Wave Notification ValueChanged : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 23.600000381469727, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:06:58]DEBUG : value_update. 72 Power
[2022-10-16 19:06:58]INFO : Received Meter report from node 72: Power=23.6W
[2022-10-16 19:06:58]DEBUG : A node value has been updated. nodeId:72 value:Power
[2022-10-16 19:06:58]DEBUG : notif_callback : end
[2022-10-16 19:06:58]DEBUG : Send to jeedom : {'devices': {'72': {'5010': {'instance': 1, 'node_id': 72, 'CommandClass': 50, 'value': 23.6, 'index': 0}}}}
[2022-10-16 19:06:58]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2022-10-16 19:06:58]DEBUG : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy HTTP/1.1" 200 0
[2022-10-16 19:06:58]INFO : node info all
[2022-10-16 19:06:59]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 128.25ms
[2022-10-16 19:07:00]DEBUG : notif_callback : new notification
[2022-10-16 19:07:00]DEBUG : notif_callback : Notification type : 2, nodeId : 72
[2022-10-16 19:07:00]DEBUG : addValueId : ValueID : 72057595250900994
[2022-10-16 19:07:00]DEBUG : addValueId : GetCommandClassId : 50, GetType : 2
[2022-10-16 19:07:00]DEBUG : addValueId : Notification : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 21.0, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:07:00]DEBUG : notif_callback : call callback context
[2022-10-16 19:07:00]DEBUG : zwcallback args=[{'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 21.0, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}]
[2022-10-16 19:07:00]DEBUG : Z-Wave Notification ValueChanged : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 21.0, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:07:00]DEBUG : value_update. 72 Power
[2022-10-16 19:07:00]INFO : Received Meter report from node 72: Power=21.0W
[2022-10-16 19:07:00]DEBUG : A node value has been updated. nodeId:72 value:Power
[2022-10-16 19:07:00]DEBUG : notif_callback : end
[2022-10-16 19:07:00]DEBUG : Send to jeedom : {'devices': {'72': {'5010': {'instance': 1, 'node_id': 72, 'CommandClass': 50, 'value': 21.0, 'index': 0}}}}
[2022-10-16 19:07:00]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2022-10-16 19:07:01]DEBUG : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy HTTP/1.1" 200 0
[2022-10-16 19:07:01]INFO : node info all
[2022-10-16 19:07:01]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 76.84ms
[2022-10-16 19:07:03]INFO : node info all
[2022-10-16 19:07:03]INFO : 200 GET /node?node_id=120&type=info&info=all&apikey=GFLFRFkdYn5nY5GE8GcEJH0b4VxM4dOIFX881G9QfI9aEkHy (127.0.0.1) 93.74ms
[2022-10-16 19:07:05]DEBUG : notif_callback : new notification
[2022-10-16 19:07:05]DEBUG : notif_callback : Notification type : 2, nodeId : 72
[2022-10-16 19:07:05]DEBUG : addValueId : ValueID : 72057595250900994
[2022-10-16 19:07:05]DEBUG : addValueId : GetCommandClassId : 50, GetType : 2
[2022-10-16 19:07:05]DEBUG : addValueId : Notification : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 20.899999618530273, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:07:05]DEBUG : notif_callback : call callback context
[2022-10-16 19:07:05]DEBUG : zwcallback args=[{'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 20.899999618530273, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}]
[2022-10-16 19:07:05]DEBUG : Z-Wave Notification ValueChanged : {'homeId': 3396522750L, 'valueId': {'commandClass': 'COMMAND_CLASS_METER', 'homeId': 3396522750L, 'readOnly': True, 'genre': 'User', 'id': 72057595250900994L, 'index': 0, 'nodeId': 72, 'value': 20.899999618530273, 'label': u'Power', 'instance': 1, 'units': u'W', 'type': 'Decimal'}, 'notificationType': 'ValueChanged', 'nodeId': 72}
[2022-10-16 19:07:05]DEBUG : value_update. 72 Power
[2022-10-16 19:07:05]INFO : Received Meter report from node 72: Power=20.8W
