Nouveau problème cette nuit, dernier relevé des températures vers 1h00 et ce matin pas d’actions sur les volets
Au reboot j’ai des erreurs dans le log openzwaved mais comme je n’avais pas été voir avant ces problèmes je ne sais pas si c’est normal ?
2020-03-10 07:35:22.379 Always, OpenZwave Version 1.4.0 Starting Up
2020-03-10 07:35:24.206 Error, Node016, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:35:24.230 Error, Node002, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:24.677 Error, Node009, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:27.664 Error, Node009, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:28.321 Error, Node009, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:32.318 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:35:36.377 Error, Node019, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:36.916 Error, Node019, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:40.913 Error, Node022, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:35:45.169 Error, Node028, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:35:45.839 Error, Node032, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:48.907 Error, Node032, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:49.384 Error, Node032, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:35:53.354 Error, Node032, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:35:58.127 Error, Node009, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:36:02.445 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:03.460 Error, Node002, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:36:07.442 Error, Node002, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:11.578 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:15.746 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:15.950 Error, Node015, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-03-10 07:36:19.748 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:24.691 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:32.021 Error, Node028, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:36.819 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:37.820 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-03-10 07:36:38.171 Always,
2020-03-10 07:36:38.171 Always, Dumping queued log messages
2020-03-10 07:36:38.172 Always,
2020-03-10 07:36:38.172 Always, End of queued log message dump
2020-03-10 07:36:38.176 Error, Node022, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
