Reee
Bon ben ,
C’ est en ordre. Si besoin voila les Log des dépendances après suppression du dossier
Merci a vous 2
Doud
[2024-03-08 12:15:38] ******************
[2024-03-08 12:15:38] * Update apt-get *
[2024-03-08 12:15:39] Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
[2024-03-08 12:15:39] Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
[2024-03-08 12:15:39] Hit:3 http://deb.debian.org/debian bullseye InRelease
[2024-03-08 12:15:39] Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
[2024-03-08 12:15:39] Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
[2024-03-08 12:15:48] Reading package lists...
[2024-03-08 12:15:48] ****************************
[2024-03-08 12:15:48] * Simulate apt-get upgrade *
[2024-03-08 12:15:50] Building dependency tree...
[2024-03-08 12:15:50] Reading state information...
[2024-03-08 12:15:51] Calculating upgrade...
[2024-03-08 12:15:52] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-03-08 12:15:52] ***************************************
[2024-03-08 12:15:52] * Install apt-get packages for Python3 *
[2024-03-08 12:15:52] Reading package lists...
[2024-03-08 12:15:54] Building dependency tree...
[2024-03-08 12:15:54] Reading state information...
[2024-03-08 12:15:56] python3 is already the newest version (3.9.2-3).
[2024-03-08 12:15:56] python3-dev is already the newest version (3.9.2-3).
[2024-03-08 12:15:56] python3-venv is already the newest version (3.9.2-3).
[2024-03-08 12:15:56] python3-requests is already the newest version (2.25.1+dfsg-2).
[2024-03-08 12:15:56] python3-setuptools is already the newest version (52.0.0-4).
[2024-03-08 12:15:56] python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
[2024-03-08 12:15:56] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-03-08 12:15:56] ***************************
[2024-03-08 12:15:56] * Check Python3.x Version *
[2024-03-08 12:15:56] Python3.x Version :: 3.9
[2024-03-08 12:15:56] ******************************************************
[2024-03-08 12:15:56] * Install apt-get packages for PyEnv (Python < 3.11) *
[2024-03-08 12:15:57] Reading package lists...
[2024-03-08 12:15:58] Building dependency tree...
[2024-03-08 12:15:58] Reading state information...
[2024-03-08 12:16:01] build-essential is already the newest version (12.9).
[2024-03-08 12:16:01] libbz2-dev is already the newest version (1.0.8-4).
[2024-03-08 12:16:01] curl is already the newest version (7.74.0-1.3+deb11u11).
[2024-03-08 12:16:01] git is already the newest version (1:2.30.2-1+deb11u2).
[2024-03-08 12:16:01] libffi-dev is already the newest version (3.3-6).
[2024-03-08 12:16:01] libxml2-dev is already the newest version (2.9.10+dfsg-6.7+deb11u4).
[2024-03-08 12:16:01] libncursesw5-dev is already the newest version (6.2+20201114-2+deb11u2).
[2024-03-08 12:16:01] libreadline-dev is already the newest version (8.1-1).
[2024-03-08 12:16:01] libsqlite3-dev is already the newest version (3.34.1-3).
[2024-03-08 12:16:01] tk-dev is already the newest version (8.6.11+1).
[2024-03-08 12:16:01] libxmlsec1-dev is already the newest version (1.2.31-1).
[2024-03-08 12:16:01] liblzma-dev is already the newest version (5.2.5-2.1~deb11u1).
[2024-03-08 12:16:01] xz-utils is already the newest version (5.2.5-2.1~deb11u1).
[2024-03-08 12:16:01] zlib1g-dev is already the newest version (1:1.2.11.dfsg-2+deb11u2).
[2024-03-08 12:16:01] libssl-dev is already the newest version (1.1.1w-0+deb11u1+rpt1).
[2024-03-08 12:16:01] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-03-08 12:16:01] *********************************
[2024-03-08 12:16:01] * Install PyEnv (Python < 3.11) *
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 270 100 270 0 0 516 0 --:--:-- --:--:-- --:--:-- 517
Cloning into '/var/www/html/plugins/ttscast/resources/pyenv'...
Cloning into '/var/www/html/plugins/ttscast/resources/pyenv/plugins/pyenv-doctor'...
Cloning into '/var/www/html/plugins/ttscast/resources/pyenv/plugins/pyenv-update'...
Cloning into '/var/www/html/plugins/ttscast/resources/pyenv/plugins/pyenv-virtualenv'...
WARNING: seems you still have not added 'pyenv' to the load path.
# Load pyenv automatically by appending
# the following to
# ~/.bash_profile if it exists, otherwise ~/.profile (for login shells)
# and ~/.bashrc (for interactive shells) :
export PYENV_ROOT="$HOME/.pyenv"
[[ -d $PYENV_ROOT/bin ]] && export PATH="$PYENV_ROOT/bin:$PATH"
eval "$(pyenv init -)"
# Restart your shell for the changes to take effect.
# Load pyenv-virtualenv automatically by adding
# the following to ~/.bashrc:
eval "$(pyenv virtualenv-init -)"
[2024-03-08 12:16:08] PyEnv installation / update : done
[2024-03-08 12:16:08] **************************************************
[2024-03-08 12:16:08] * Compile and Install Python 3.11.8 (with PyEnv) *
[2024-03-08 12:16:08] * *
[2024-03-08 12:16:08] * ATTENTION : Cette phase de l'installation peut *
[2024-03-08 12:16:08] * être longue et durer de 2 minutes (Config ++) *
[2024-03-08 12:16:08] * à plus de 40 minutes sur des petites config ! *
Downloading Python-3.11.8.tar.xz...
-> https://www.python.org/ftp/python/3.11.8/Python-3.11.8.tar.xz
Installing Python-3.11.8...
Installed Python-3.11.8 to /var/www/html/plugins/ttscast/resources/pyenv/versions/3.11.8
[2024-03-08 12:32:29] Python 3.11.8 installation : done
[2024-03-08 12:32:29] **************************
[2024-03-08 12:32:29] * Create Python3.11 venv *
[2024-03-08 12:32:29] Python3 (Venv) Version :: 3.11
[2024-03-08 12:32:55] Python3.11 venv : done
[2024-03-08 12:32:55] *****************************
[2024-03-08 12:32:55] * Install Python3 libraries *
[2024-03-08 12:32:58] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-03-08 12:32:58] Requirement already satisfied: pip in ./venv/lib/python3.11/site-packages (24.0)
[2024-03-08 12:32:59] Requirement already satisfied: wheel in ./venv/lib/python3.11/site-packages (0.42.0)
[2024-03-08 12:33:06] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-03-08 12:33:06] Requirement already satisfied: PyChromecast==14.0.0 in ./venv/lib/python3.11/site-packages (14.0.0)
[2024-03-08 12:33:06] Requirement already satisfied: google-cloud-texttospeech==2.16.2 in ./venv/lib/python3.11/site-packages (2.16.2)
[2024-03-08 12:33:06] Requirement already satisfied: gTTS==2.5.1 in ./venv/lib/python3.11/site-packages (2.5.1)
[2024-03-08 12:33:06] Requirement already satisfied: protobuf>=4.25.1 in ./venv/lib/python3.11/site-packages (from PyChromecast==14.0.0) (4.25.3)
[2024-03-08 12:33:06] Requirement already satisfied: zeroconf>=0.25.1 in ./venv/lib/python3.11/site-packages (from PyChromecast==14.0.0) (0.131.0)
[2024-03-08 12:33:06] Requirement already satisfied: casttube>=0.2.0 in ./venv/lib/python3.11/site-packages (from PyChromecast==14.0.0) (0.2.1)
[2024-03-08 12:33:06] Requirement already satisfied: google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1 in ./venv/lib/python3.11/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.2) (2.17.1)
[2024-03-08 12:33:06] Requirement already satisfied: google-auth<3.0.0dev,>=2.14.1 in ./venv/lib/python3.11/site-packages (from google-cloud-texttospeech==2.16.2) (2.28.1)
[2024-03-08 12:33:06] Requirement already satisfied: proto-plus<2.0.0dev,>=1.22.3 in ./venv/lib/python3.11/site-packages (from google-cloud-texttospeech==2.16.2) (1.23.0)
[2024-03-08 12:33:06] Requirement already satisfied: requests<3,>=2.27 in ./venv/lib/python3.11/site-packages (from gTTS==2.5.1) (2.31.0)
[2024-03-08 12:33:06] Requirement already satisfied: click<8.2,>=7.1 in ./venv/lib/python3.11/site-packages (from gTTS==2.5.1) (8.1.7)
[2024-03-08 12:33:06] Requirement already satisfied: googleapis-common-protos<2.0.dev0,>=1.56.2 in ./venv/lib/python3.11/site-packages (from google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.2) (1.62.0)
[2024-03-08 12:33:06] Requirement already satisfied: grpcio<2.0dev,>=1.33.2 in ./venv/lib/python3.11/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.2) (1.62.0)
[2024-03-08 12:33:06] Requirement already satisfied: grpcio-status<2.0.dev0,>=1.33.2 in ./venv/lib/python3.11/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.2) (1.62.0)
[2024-03-08 12:33:07] Requirement already satisfied: cachetools<6.0,>=2.0.0 in ./venv/lib/python3.11/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.2) (5.3.3)
[2024-03-08 12:33:07] Requirement already satisfied: pyasn1-modules>=0.2.1 in ./venv/lib/python3.11/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.2) (0.3.0)
[2024-03-08 12:33:07] Requirement already satisfied: rsa<5,>=3.1.4 in ./venv/lib/python3.11/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.2) (4.9)
[2024-03-08 12:33:07] Requirement already satisfied: charset-normalizer<4,>=2 in ./venv/lib/python3.11/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (3.3.2)
[2024-03-08 12:33:07] Requirement already satisfied: idna<4,>=2.5 in ./venv/lib/python3.11/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (3.6)
[2024-03-08 12:33:07] Requirement already satisfied: urllib3<3,>=1.21.1 in ./venv/lib/python3.11/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (2.2.1)
[2024-03-08 12:33:07] Requirement already satisfied: certifi>=2017.4.17 in ./venv/lib/python3.11/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (2024.2.2)
[2024-03-08 12:33:07] Requirement already satisfied: ifaddr>=0.1.7 in ./venv/lib/python3.11/site-packages (from zeroconf>=0.25.1->PyChromecast==14.0.0) (0.2.0)
[2024-03-08 12:33:07] Requirement already satisfied: pyasn1<0.6.0,>=0.4.6 in ./venv/lib/python3.11/site-packages (from pyasn1-modules>=0.2.1->google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.2) (0.5.1)
[2024-03-08 12:33:09] ****************
[2024-03-08 12:33:09] * Install DONE *
