Hi,
Unfortunately, there is no proscenicHome plugin on Jeedom, so I will show you how to use the proscenicHome api for the proscenic M7 pro with curl requests.
1. Prerequired
- Have a proscenicHome account
The host is https://mobile.proscenic.com.de and header content :
Content-Type: application/json;charset=UTF-8
Content-Length: 0
Host: mobile.proscenic.com.de
Connection: Keep-Alive
Accept-Encoding: gzip
User-Agent: okhttp/3.10.0
So your curl request will have this form:
curl -X POST https://mobile.proscenic.com.de/ -H "Content-Type: application/json;charset=UTF-8" -H "Host: mobile.proscenic.com.de" -H "Connection: Keep-Alive" -H "Accept-Encoding: gzip" -H "User-Agent: okhttp/3.10.0"
2. Login
Login URL is https://mobile.proscenic.com.de/user/login
In order to login you must fill in the JSON body like this :
"password":"3d4e2938bdcba243e5280bf2fc32fa91",
"countryCode":"{yourCountryCode}", //ex : 33 for France
"username":"{yourUsername}",
"appVer":"1.4.3.4-prd",
"pwd":"{yourPassword}"
Curl example :
curl -X POST https://mobile.proscenic.com.de/user/login -H "Content-Type: application/json;charset=UTF-8"-H "Host: mobile.proscenic.com.de" -H "Connection: Keep-Alive" -H "Accept-Encoding: gzip" -H "User-Agent: okhttp/3.10.0" --data "{\"password\":\"3d4e2938bdcba243e5280bf2fc32fa91\",\"countryCode\":\"{yourCountryCode}\", \"username\":\"{yourUsername}\",\"appVer\":\"1.4.3.4-prd\",\"pwd\":\"{yourPassword}\"}"
You will get a response like this :
"code":0,
"msg":"success",
"data":
"token":"{yourToken}",
"uid":"{yourUid}",
"equipcount":{nbOfEquipement},
"nickname":"{yourNickname}",
"recieveMsg":false,
"homeId":{yourHomeId}
NB : {yourToken} will be used in some requests
3. Starting the robot
URL : https://mobile.proscenic.com.de/instructions/cmd21005/LSLDSM7PRO20101046
Parameters :
- cleanMode : sweepOnly
- username : {yourUsername}
NB : {yourToken} is required in the header
Curl example :
curl -X POST https://mobile.proscenic.com.de/instructions/cmd21005/LSLDSM7PRO20101046?cleanMode=sweepOnly&username={yourUserName} -H "token: {yourToken}" -H "Content-Type: application/json;charset=UTF-8" -H "Host: mobile.proscenic.com.de" -H "Connection: Keep-Alive" -H "Accept-Encoding: gzip" -H "User-Agent: okhttp/3.10.0"
4. Robot power mode
URL : https://mobile.proscenic.com.de/instructions/LSLDSM7PRO20101046/21022
Parameters :
- username : {yourUserNamer}
- setMode : quiet|auto|strong
Curl example :
curl -X POST -d "{yourUsername}&mode=pause" "https://mobile.proscenic.com.de/instructions/LSLDSM7PRO20101046/21017" -H "Content-Type: application/x-www-form-urlencoded" -H "Host: mobile.proscenic.com.de" -H "Connection: Keep-Alive" -H "Accept-Encoding: gzip" -H "User-Agent: okhttp/3.10.0"
6. Return to base
URL : https://mobile.proscenic.com.de/instructions/LSLDSM7PRO20101046/21012
Parameters :
- Username : {yourUsername}
- Charge : start
Curl example :
curl -X POST -d "username={yourUsername}&charge=start" "https://mobile.proscenic.com.de/instructions/LSLDSM7PRO20101046/21012" -H "Content-Type: application/x-www-form-urlencoded" -H "Host: mobile.proscenic.com.de"
7. Depth total mode
URL : https://mobile.proscenic.com.de/instructions/cmd21005_2/LSLDSM7PRO20101046
Parameters :
- Username: {yourUsername}
- mode: depthTotalClean
Curl example:
curl -X POST "https://mobile.proscenic.com.de/instructions/cmd21005_2/LSLDSM7PRO20101046?username={yourUsername}&mode=depthTotalClean" -H "token: {yourToken}" -H "Content-Type: application/json;charset=UTF-8" -H "Host: mobile.proscenic.com.de" -H "Connection: Keep-Alive" -H "Accept-Encoding: gzip" -H "User-Agent: okhttp/3.10.0"
