Promox Updates
J’utilise proxmox depuis 1 an et j’en suis super content (aucun plantage ou autre), cependant, je m’apercois que, depuis ce temps il y aurait …153 updates a faire !!!
Pour ceux qui sont sous promox, puis-je faire ces udates sans risque pour jeedom ?
Ci-dessous la liste des updates :
Starting system upgrade: apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
  curl idn libcurl4 libfuse3-3 libproxmox-acme-perl libproxmox-backup-qemu0
  libqrencode4 libyaml-0-2 libyaml-libyaml-perl proxmox-archive-keyring
  proxmox-backup-client pve-kernel-5.3.18-3-pve pve-kernel-5.4
  pve-kernel-5.4.78-2-pve pve-lxc-syscalld qrencode zstd
The following packages will be upgraded:
  apt apt-utils base-files bind9-host ca-certificates corosync dbus dmeventd
  dmsetup dnsutils e2fsprogs fuse iputils-ping krb5-locales libapt-inst2.0
  libapt-pkg5.0 libbind9-161 libboost-atomic1.67.0 libboost-iostreams1.67.0
  libboost-program-options1.67.0 libboost-regex1.67.0 libboost-system1.67.0
  libboost-thread1.67.0 libcfg7 libcmap4 libcom-err2 libcorosync-common4
  libcpg4 libcups2 libcurl3-gnutls libdbus-1-3 libdevmapper-event1.02.1
  libdevmapper1.02.1 libdns-export1104 libdns1104 libefiboot1 libefivar1
  libext2fs2 libfreetype6 libfuse2 libgnutls30 libgnutlsxx28 libgssapi-krb5-2
  libicu63 libidn2-0 libirs161 libisc-export1100 libisc1100 libisccc161
  libisccfg163 libjpeg62-turbo libjson-c3 libk5crypto3 libknet1 libkrb5-3
  libkrb5support0 libldap-2.4-2 libldap-common liblvm2cmd2.03 liblwres161
  libnss-systemd libnss3 libnvpair1linux libp11-kit0 libpam-systemd
  libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libperl5.28
  libpve-access-control libpve-apiclient-perl libpve-cluster-api-perl
  libpve-cluster-perl libpve-common-perl libpve-guest-common-perl
  libpve-http-server-perl libpve-storage-perl libpython3.7 libpython3.7-minimal
  libpython3.7-stdlib libquorum5 libsqlite3-0 libss2 libssl1.1 libsystemd0
  libtimedate-perl libudev1 libunwind8 libuutil1linux libvotequorum8 libx11-6
  libx11-data libx11-xcb1 libxml2 libzfs2linux libzpool2linux linux-libc-dev
  lvm2 lxc-pve lxcfs nfs-common nmap nmap-common openssh-client openssh-server
  openssh-sftp-server openssl perl perl-base perl-modules-5.28 postfix
  proxmox-ve proxmox-widget-toolkit pve-cluster pve-container pve-docs
  pve-edk2-firmware pve-firewall pve-firmware pve-ha-manager pve-i18n
  pve-kernel-5.3 pve-kernel-helper pve-manager pve-qemu-kvm pve-xtermjs
  python-apt-common python3-apt python3.7 python3.7-minimal qemu-server spl
  sqlite3 ssh systemd systemd-sysv tcpdump tzdata udev vncterm zfs-initramfs
  zfs-zed zfsutils-linux
143 upgraded, 17 newly installed, 0 to remove and 0 not upgraded.
Need to get 280 MB of archives.
After this operation, 624 MB of additional disk space will be used.
Do you want to continue? [Y/n] ^C
System not fully up to date (found 153 new packages)
Faire un update d’un système n’est jamais anodin cependant cela est assez bien sous contrôle, les paquets à mettre à jour ont été testé et on rencontre rarement un problème.
Evidemment le saut à franchir après un an est plus compliqué que s’il n’y avait qu’une semaine.
De toute façon ici c’est l’hyperviseur, pas jeedom donc en soit si vous avez un backup de jeedom plus un backup de votre VM, même si votre hote crash suite à ces updates il sera temps de le réinstaller et de restaurer le backup de votre VM ou si il y a également un soucis avec celui là de réinstaller une nouvelle VM, jeedom et de restaurer le backup de jeedom.
Donc en conclusion allez y et faite cela plus souvent.
Et probablement que vous devriez faire la même chose sur la VM jeedom :wink: (et potentiellement d’autres) car jeedom installe les mises à jours de l’application (jeedom + plugins) mais ne gère pas vos mises à jour du système.
Ok, merci, je ferais une sauvegarde de jeedom et de une image de la vm et ferais les updates
Oui, et évitez de faire toutes les MaJ en même temps : hyperviseur un jour, VM un autre, jeedom le suivant, plugins un autre, etc pour éviter d’empiler les problèmes et les risques…
Je voudrais bien ne pas les faire en même temps mais, apparemment, dans le menu proxmox « upgrade », la commande lance toutes les mise a jour , a moins qu’il y ait une autre possibilité ?
Il s’agit des maj de l’hyperviseur, ce ne sont pas les VM
Ok, meri, je fais les updates ce WE
Avec le plugin Proxmox, tu peut savoir si tu as des MaJ à faire, te faire envoyer un message…:slight_smile:A+
Thierry
