La Log complète si besoin Partie 1
- Downloading symfony/routing (v5.4.0)
- Downloading react/event-loop (v1.2.0)
- Downloading evenement/evenement (v3.0.1)
- Downloading react/stream (v1.2.0)
- Downloading react/promise (v2.8.0)
- Downloading react/promise-timer (v1.8.0)
- Downloading react/cache (v1.1.1)
- Downloading react/dns (v1.8.0)
- Downloading react/socket (v1.10.0)
- Downloading ralouphie/getallheaders (3.0.3)
- Downloading psr/http-message (1.0.1)
- Downloading psr/http-factory (1.0.1)
- Downloading guzzlehttp/psr7 (2.1.0)
- Downloading ratchet/rfc6455 (v0.3.1)
- Downloading cboden/ratchet (v0.4.4)
0/15 [>---------------------------] 0%
12/15 [======================>-----] 80%
15/15 [============================] 100%
- Installing symfony/routing (v5.4.0): Extracting archive
- Installing react/event-loop (v1.2.0): Extracting archive
- Installing evenement/evenement (v3.0.1): Extracting archive
- Installing react/stream (v1.2.0): Extracting archive
- Installing react/promise (v2.8.0): Extracting archive
- Installing react/promise-timer (v1.8.0): Extracting archive
- Installing react/cache (v1.1.1): Extracting archive
- Installing react/dns (v1.8.0): Extracting archive
- Installing react/socket (v1.10.0): Extracting archive
- Installing ralouphie/getallheaders (3.0.3): Extracting archive
- Installing psr/http-message (1.0.1): Extracting archive
- Installing psr/http-factory (1.0.1): Extracting archive
- Installing guzzlehttp/psr7 (2.1.0): Extracting archive
- Installing ratchet/rfc6455 (v0.3.1): Extracting archive
- Installing cboden/ratchet (v0.4.4): Extracting archive
10/15 [==================>---------] 66%
6 package suggestions were added by new dependencies, use `composer suggest` to see details.
Generating autoload files
12 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
* Install python3 debian packages
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
python3-pip est déjà la version la plus récente (20.3.4-4).
python3-requests est déjà la version la plus récente (2.25.1+dfsg-2).
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
bluez-obexd libarchive13 libcdio18 libexif12 libgdata-common libgdata22
libgoa-1.0-0b libgoa-1.0-common libgphoto2-6 libgphoto2-l10n
libgphoto2-port12 libical3 libldb1 libmtp-common libmtp-runtime libmtp9
libnfs12 libpython-dev libpython2-dev libpython2.7-dev libtalloc2 libtevent0
libwbclient0 python-pkg-resources python-setuptools python-six python2-dev
python2.7-dev samba-common
Veuillez utiliser « sudo apt autoremove » pour les supprimer.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 64 non mis à jour.
* Install python3 setuptools library
Requirement already satisfied: setuptools in /usr/local/lib/python3.9/site-packages (59.7.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
* Install python3 paho-mqtt library
Collecting paho-mqtt
Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_fe522066ea334a14a0f62a9aa7a3b043/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_fe522066ea334a14a0f62a9aa7a3b043/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-tozwwua1
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_fe522066ea334a14a0f62a9aa7a3b043/
Complete output (11 lines):
File "<string>", line 1, in <module>
File "/usr/local/lib/python3.9/site-packages/setuptools/__init__.py", line 18, in <module>
from setuptools.dist import Distribution
File "/usr/local/lib/python3.9/site-packages/setuptools/dist.py", line 37, in <module>
from setuptools import windows_support
File "/usr/local/lib/python3.9/site-packages/setuptools/windows_support.py", line 2, in <module>
import ctypes
File "/usr/local/lib/python3.9/ctypes/__init__.py", line 8, in <module>
from _ctypes import Union, Structure, Array
ModuleNotFoundError: No module named '_ctypes'
WARNING: Discarding https://files.pythonhosted.org/packages/f8/dd/4b75dcba025f8647bc9862ac17299e0d7d12d3beadbf026d8c8d74215c12/paho-mqtt-1.6.1.tar.gz#sha256=2a8291c81623aec00372b5a85558a372c747cbca8e9934dfe218638b8eefc26f (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.6.0.tar.gz (99 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_864bf99c9bc643aa94299c6e38a4f3ee/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_864bf99c9bc643aa94299c6e38a4f3ee/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-7npd6xk8
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_864bf99c9bc643aa94299c6e38a4f3ee/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/af/c0/15d9a53948cfee06410d2a2340ea5d1e633d5db753a4eeedf7b6638bae43/paho-mqtt-1.6.0.tar.gz#sha256=4b34b07ee45925ecbdddecc862ff68d9a9999d78d8876e23f8f54985dd9ed5d1 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.5.1.tar.gz (101 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_c831ee4111a54f9a8fbb8e4f159b3b8a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_c831ee4111a54f9a8fbb8e4f159b3b8a/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-zuf5y4w0
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_c831ee4111a54f9a8fbb8e4f159b3b8a/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/32/d3/6dcb8fd14746fcde6a556f932b5de8bea8fedcb85b3a092e0e986372c0e7/paho-mqtt-1.5.1.tar.gz#sha256=9feb068e822be7b3a116324e01fb6028eb1d66412bf98595ae72698965cb1cae (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.5.0.tar.gz (99 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_693a76cdf3174549b79b149f5f95f08a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_693a76cdf3174549b79b149f5f95f08a/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-hur1e38g
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_693a76cdf3174549b79b149f5f95f08a/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/59/11/1dd5c70f0f27a88a3a05772cd95f6087ac479fac66d9c7752ee5e16ddbbc/paho-mqtt-1.5.0.tar.gz#sha256=e3d286198baaea195c8b3bc221941d25a3ab0e1507fc1779bdb7473806394be4 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.4.0.tar.gz (88 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_92240fe3badd4f149fc73751df125a80/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_92240fe3badd4f149fc73751df125a80/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-lpmuqi7b
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_92240fe3badd4f149fc73751df125a80/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/25/63/db25e62979c2a716a74950c9ed658dce431b5cb01fde29eb6cba9489a904/paho-mqtt-1.4.0.tar.gz#sha256=e440a052b46d222e184be3be38676378722072fcd4dfd2c8f509fb861a7b0b79 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.3.1.tar.gz (80 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_0e1503825348404593a651252c50a4e3/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_0e1503825348404593a651252c50a4e3/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-f0ythuyj
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_0e1503825348404593a651252c50a4e3/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/2a/5f/cf14b8f9f8ed1891cda893a2a7d1d6fa23de2a9fb4832f05cef02b79d01f/paho-mqtt-1.3.1.tar.gz#sha256=31911f6031de306c27ed79dc77b690d7c55b0dcb0f0434ca34ec6361d0371122 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.3.0.tar.gz (79 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_4a573a519e634bbfbc805012ba42999e/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_4a573a519e634bbfbc805012ba42999e/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-m0qcr_cp
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_4a573a519e634bbfbc805012ba42999e/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/33/7f/3ce1ffebaa0343d509aac003800b305d821e89dac3c11666f92e12feca14/paho-mqtt-1.3.0.tar.gz#sha256=2c9ef5494cfc1e41a9fff6544c5a2cd59ea5d401d9119a06ecf7fad6a2ffeb93 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.2.3.tar.gz (72 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_d0db3faff82940119be4245ff29692e0/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_d0db3faff82940119be4245ff29692e0/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-c8hv83ot
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_d0db3faff82940119be4245ff29692e0/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/ce/27/28ac0859fb8d63754ec51659be265bf3b89d1568c5f6736d21026e11ea85/paho-mqtt-1.2.3.tar.gz#sha256=0fd746d8650563290f1bd0fec01e74cb57c3ab7406bdb58e5d9252bb5fa5ca44 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.2.2.tar.gz (72 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_64c5f11a85454dc6b3736128c4cbe4b4/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_64c5f11a85454dc6b3736128c4cbe4b4/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-yqjbq5w_
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_64c5f11a85454dc6b3736128c4cbe4b4/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/31/0f/53f71dc9033b492ba6546c452c35722621f9120cee6b905808d893fa0d97/paho-mqtt-1.2.2.tar.gz#sha256=cf297194d2a716010b5ff975f735d025ac3cdb4a317e9330abde4f73a006f1b0 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.2.1.tar.gz (51 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_38858a9b54ab424dbeef174712eedfe2/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_38858a9b54ab424dbeef174712eedfe2/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-sr0pe0ty
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_38858a9b54ab424dbeef174712eedfe2/
import ctypes
WARNING: Discarding https://files.pythonhosted.org/packages/e0/fb/13680584b3781faf9da3eb5c4728e171d89357cb00cdf1cad6b4e30c8cc8/paho-mqtt-1.2.1.tar.gz#sha256=94f35ffc38ca1668b5c57dc47612284bf95b105d43d0cecd4c06896e2508779a (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached paho-mqtt-1.2.tar.gz (49 kB)
command: /usr/local/bin/python3.9 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_8b86ef7c8d11498d9fb5b06875b01120/setup.py'"'"'; __file__='"'"'/tmp/pip-install-0nsn0upj/paho-mqtt_8b86ef7c8d11498d9fb5b06875b01120/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-fvywbuec
cwd: /tmp/pip-install-0nsn0upj/paho-mqtt_8b86ef7c8d11498d9fb5b06875b01120/
import ctypes
