j’ai de temps en temps ce type d’erreur dans mes logs Zigate, du coup le service s’arrête et se relance pas. Une idée ? Merci d’avance.
[2020-08-07 06:51:58][WARNING]zigate : No response after command 0x0010 (1)
Exception in thread ZiGate-Listen:
File « /usr/lib/python3.5/threading.py », line 914, in _bootstrap_inner
self.run()
File « /usr/lib/python3.5/threading.py », line 862, in run
self._target(*self._args, **self._kwargs)
File « /usr/local/lib/python3.5/dist-packages/zigate/transport.py », line 326, in listen
read_sockets, write_sockets, error_sockets = select.select(socket_list, socket_list, , 5)
ValueError: file descriptor cannot be a negative integer (-1)
[2020-08-07 06:56:58][WARNING]zigate : No response after command 0x0010 (2)
[2020-08-07 07:01:59][WARNING]zigate : No response after command 0x0010 (3)
[2020-08-07 07:06:59][WARNING]zigate : No response after command 0x0010 (4)
[2020-08-07 07:11:59][WARNING]zigate : No response after command 0x0010 (5)
[2020-08-07 07:16:59][WARNING]zigate : No response after command 0x0010 (6)
[2020-08-07 07:21:59][WARNING]zigate : No response after command 0x0010 (7)
[2020-08-07 07:26:59][WARNING]zigate : No response after command 0x0010 (8)
[2020-08-07 07:31:59][WARNING]zigate : No response after command 0x0010 (9)
[2020-08-07 07:36:59][WARNING]zigate : No response after command 0x0010 (10)
[2020-08-07 07:41:59][WARNING]zigate : No response after command 0x0010 (11)
[2020-08-07 07:46:59][WARNING]zigate : No response after command 0x0010 (12)
[2020-08-07 07:51:59][WARNING]zigate : No response after command 0x0010 (13)
[2020-08-07 07:56:59][WARNING]zigate : No response after command 0x0010 (14)
