J’ai un soucis de puis hier que je ne parviens pas à résoudre, je ne peux pas sélectionner le port usb de mon modem téléinfo dans les paramètre de réglages du plugin.
En tapant lsusb je l’ai bien en bus 004 devis 004
Je suis sous Jeedom 3.3.39 et installation sous proxmox.
Ca à fonctionné pendant un moment mais depuis un reboot…
D’où proviens mon soucis?
dmesg | grep USB
[ 2.026823] ACPI: bus type USB registered
[ 2.028155] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.028693] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.108511] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus numbe r 1
[ 2.108841] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus numbe r 2
[ 2.109182] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.109183] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.109342] hub 1-0:1.0: USB hub found
[ 2.110738] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.110740] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.110861] hub 2-0:1.0: USB hub found
[ 2.111237] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus numbe r 3
[ 2.111352] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.111353] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.111461] hub 3-0:1.0: USB hub found
[ 2.145745] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus numbe r 4
[ 2.146099] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.146101] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.146236] hub 4-0:1.0: USB hub found
[ 2.292605] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus numbe r 5
[ 2.307100] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.307202] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.307204] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.307390] hub 5-0:1.0: USB hub found
[ 2.512632] hub 4-0:1.0: USB hub found
[ 2.547859] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus numbe r 6
[ 2.548122] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.548124] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.548317] hub 6-0:1.0: USB hub found
[ 2.571101] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[ 2.581080] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus numbe r 7
[ 2.581350] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.581352] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.581543] hub 7-0:1.0: USB hub found
[ 2.635481] usb 2-1: new full-speed USB device number 2 using xhci_hcd
[ 2.758403] usb 1-1: New USB device found, idVendor=0627, idProduct=0001
[ 2.758405] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=1 0
[ 2.758407] usb 1-1: Product: QEMU USB Tablet
[ 2.771865] usbhid: USB HID core driver
[ 2.773943] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/u sb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
[ 2.774046] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mou se [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
[ 2.809105] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60
[ 2.809108] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.809110] usb 2-1: Product: CP2102 USB to UART Bridge Controller
[ 3.119344] usb 2-2: new full-speed USB device number 3 using xhci_hcd
[ 3.123474] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[ 3.271838] usb 2-2: New USB device found, idVendor=0403, idProduct=6001
[ 3.271840] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.597776] usb 4-1: New USB device found, idVendor=051d, idProduct=0002
[ 3.597778] usb 4-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 3.597780] usb 4-1: Product: Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3
[ 3.671083] usb 2-3: new full-speed USB device number 4 using xhci_hcd
[ 3.818738] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[ 3.818740] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.943096] usb 2-4: new full-speed USB device number 5 using xhci_hcd
[ 4.084014] usb 2-4: New USB device found, idVendor=0409, idProduct=55aa
[ 4.084017] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.084019] usb 2-4: Product: QEMU USB Hub
[ 4.084421] hub 2-4:1.0: USB hub found
[ 4.101112] hid-generic 0003:051D:0002.0002: hiddev0,hidraw1: USB HID v1.10 D evice [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[ 4.656925] usb 2-4.1: new full-speed USB device number 6 using xhci_hcd
[ 4.902405] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[ 4.902407] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 4.927382] usbserial: USB Serial support registered for generic
[ 4.973408] usbserial: USB Serial support registered for FTDI USB Serial Devi ce
[ 4.973475] ftdi_sio 2-3:1.0: FTDI USB Serial Device converter detected
[ 4.974079] usbserial: USB Serial support registered for cp210x
[ 4.974673] usb 2-3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 4.976274] usb 2-1: cp210x converter now attached to ttyUSB1
[ 5.104776] cdc_acm 2-4.1:1.0: ttyACM0: USB ACM device
[ 5.105190] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 5338.363635] usb 2-3: USB disconnect, device number 4
[ 5338.363882] ftdi_sio ttyUSB0: error from flowcontrol urb
[ 5338.367544] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnect ed from ttyUSB0
[ 5338.818850] usb 2-3: new full-speed USB device number 7 using xhci_hcd
[ 5338.970614] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[ 5338.970617] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5338.970619] usb 2-3: Product: FT232R USB UART
[ 5343.364472] usb 2-4.1: USB disconnect, device number 6
[ 5350.742810] usb 2-4.1: new full-speed USB device number 8 using xhci_hcd
[ 5350.844453] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[ 5350.844456] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 5350.845196] cdc_acm 2-4.1:1.0: ttyACM1: USB ACM device
[22593.095194] usb 4-1: USB disconnect, device number 2
[22593.095782] usb 2-4.1: USB disconnect, device number 8
[22593.116196] usb 2-2: USB disconnect, device number 3
[22594.078634] usb 2-3: USB disconnect, device number 7
[22594.157643] usb 2-4.1: new full-speed USB device number 9 using xhci_hcd
[22594.259349] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[22594.259352] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[22594.260184] cdc_acm 2-4.1:1.0: ttyACM1: USB ACM device
[22594.309670] usb 4-1: new low-speed USB device number 3 using uhci_hcd
[22594.509510] usb 4-1: New USB device found, idVendor=051d, idProduct=0002
[22594.509513] usb 4-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[22594.509514] usb 4-1: Product: Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3
[22595.003923] hid-generic 0003:051D:0002.0003: hiddev0,hidraw1: USB HID v1.10 D evice [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[22727.710549] usb 2-1: USB disconnect, device number 2
[22727.715189] cp210x ttyUSB1: failed set request 0x7 status: -19
[22727.721568] cp210x ttyUSB1: failed set request 0x12 status: -19
[22727.722378] cp210x ttyUSB1: failed set request 0x0 status: -19
[22727.724981] cp210x ttyUSB1: cp210x converter now disconnected from ttyUSB1
[22736.573028] usb 2-2: new full-speed USB device number 10 using xhci_hcd
[22736.725183] usb 2-2: New USB device found, idVendor=0403, idProduct=6001
[22736.725185] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22738.181003] usb 2-1: new full-speed USB device number 11 using xhci_hcd
[22738.353102] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60
[22738.353104] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22738.353105] usb 2-1: Product: CP2102 USB to UART Bridge Controller
[22738.363432] usb 2-1: cp210x converter now attached to ttyUSB0
[22738.809019] usb 2-3: new full-speed USB device number 12 using xhci_hcd
[22738.960881] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[22738.960883] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22940.078994] usb 2-4.1: USB disconnect, device number 9
[22940.082726] usb 2-1: USB disconnect, device number 11
[22940.083180] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[22940.086161] usb 4-1: USB disconnect, device number 3
[22941.043977] usb 2-2: USB disconnect, device number 10
[22941.124113] usb 2-4.1: new full-speed USB device number 13 using xhci_hcd
[22941.416097] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[22941.416099] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[22941.416861] cdc_acm 2-4.1:1.0: ttyACM1: USB ACM device
[22941.472110] usb 4-1: new low-speed USB device number 4 using uhci_hcd
[22941.616127] usb 2-2: new full-speed USB device number 14 using xhci_hcd
[22941.669369] usb 4-1: New USB device found, idVendor=051d, idProduct=0002
[22941.669372] usb 4-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[22941.669373] usb 4-1: Product: Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3
[22942.165442] hid-generic 0003:051D:0002.0004: hiddev0,hidraw1: USB HID v1.10 D evice [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[22947.108092] usb 2-2: new full-speed USB device number 15 using xhci_hcd
[22947.262246] usb 2-2: New USB device found, idVendor=0403, idProduct=6001
[22947.262248] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22947.263131] usb 2-3: USB disconnect, device number 12
[22947.708081] usb 2-3: new full-speed USB device number 16 using xhci_hcd
[22947.865807] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[22947.865809] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23065.870920] usb 2-4.1: USB disconnect, device number 13
[23065.875488] usb 2-2: USB disconnect, device number 15
[23065.879407] usb 4-1: USB disconnect, device number 4
[23066.835371] usb 2-3: USB disconnect, device number 16
[23066.915526] usb 2-4.1: new full-speed USB device number 17 using xhci_hcd
[23067.017342] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[23067.017345] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[23067.018050] cdc_acm 2-4.1:1.0: ttyACM1: USB ACM device
[23067.103526] usb 4-1: new low-speed USB device number 5 using uhci_hcd
[23067.303201] usb 4-1: New USB device found, idVendor=051d, idProduct=0002
[23067.303204] usb 4-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[23067.303206] usb 4-1: Product: Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3
[23067.788611] hid-generic 0003:051D:0002.0005: hiddev0,hidraw1: USB HID v1.10 D evice [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[23076.495488] usb 2-2: new full-speed USB device number 18 using xhci_hcd
[23076.647353] usb 2-2: New USB device found, idVendor=0403, idProduct=6001
[23076.647355] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23078.511475] usb 2-3: new full-speed USB device number 19 using xhci_hcd
[23078.661135] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[23078.661138] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23078.661139] usb 2-3: Product: FT232R USB UART
[23078.665351] ftdi_sio 2-3:1.0: FTDI USB Serial Device converter detected
[23078.666137] usb 2-3: FTDI USB Serial Device converter now attached to ttyUSB0
[23160.335132] usb 2-1: new full-speed USB device number 20 using xhci_hcd
[23160.507390] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60
[23160.507393] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23160.507395] usb 2-1: Product: CP2102 USB to UART Bridge Controller
[23160.517824] usb 2-1: cp210x converter now attached to ttyUSB1
[23235.884097] usb 2-4.1: USB disconnect, device number 17
[23240.498770] usb 2-4.1: new full-speed USB device number 21 using xhci_hcd
[23240.600359] usb 2-4.1: New USB device found, idVendor=0658, idProduct=0200
[23240.600362] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[23240.601082] cdc_acm 2-4.1:1.0: ttyACM1: USB ACM device
dmesg | grep USB
[ 2.108511] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
[ 2.108841] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus number 2
[ 2.109183] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.110740] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.111237] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus number 3
[ 2.111353] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.145745] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 2.146101] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.292605] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 2.307204] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.547859] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 2.548124] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.581080] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 2.581352] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.758405] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
[ 2.773943] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
[ 2.774046] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
[ 4.101112] hid-generic 0003:051D:0002.0002: hiddev0,hidraw1: USB HID v1.10 Device [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[ 4.902407] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.973408] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.105190] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5338.367544] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 5350.844456] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[22594.259352] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[22595.003923] hid-generic 0003:051D:0002.0003: hiddev0,hidraw1: USB HID v1.10 Device [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[22941.416099] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[22942.165442] hid-generic 0003:051D:0002.0004: hiddev0,hidraw1: USB HID v1.10 Device [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[23067.017345] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[23067.788611] hid-generic 0003:051D:0002.0005: hiddev0,hidraw1: USB HID v1.10 Device [American Power Conversion Back-UPS XS 700U FW:924.Z3 .I USB FW:Z3 ] on usb-0000:00:1d.0-1/input0
[23240.600362] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Tu n’as pas compris ma question. Je vais donc détailler. Tu mélanges Rfxcom et téléinfo.
En effet, tu montres une image du plugin RFXCOM alors que le titre du sujet est « Problème USB téléinfo ».
J’explique en détail
Je suis sous proxmox et jeedom 3.3.39
Jusqu’à la semaine dernière environ tout marchait bien.
Après un redémarrage, j’ai eu des soucis avec mes modules USB.
J’ai pu remettre ma clé zwave et zigbee en fonctionnement
Mais je peu sois remettre mon téléinfo soit mon rfxcom mais jamais les 2 en même temps
Je ne vois pas de quoi cela peu provenir
Que puis-je faire?
Les modems téléinfo Cartelectronic et GCE Electronics ont la même interface série/USB, c’est une puce de chez FTDI (ID 0403:6015).
Le rfxcom a aussi une puce FTDI (ID 0403:6001).
Un conflit possible entre rfxcom et téléinfo identifié ici : « defaut communication port USB » : defaut communication port USB - Forum Communauté Jeedom
A quoi correspond CP210x (ID 10c4:ea60) qui est aussi une puce interface série/USB (de Silicon Labs aka Silabs) ? la clé Zigbee ?
J’ai pas de chance !!!
Y’a-t-il une solution?
Ce qui est bizzare c’est que ça à marché sur mon pi pendant au moin 3 ans puis sur mon Nuc et Debian pendant plusieurs semaine et d’un coup paff !!!
Le CP210 est c’est le convertisseur TTL de ma clé Zigate
Merci pour ton aide @akenad mais j’avais mis un nuc pour pas être embêté avec un pi et sa carte SD ou son SSD qui refuse de booter sur un redémarrage …
Si il n’y a pas d’autre solution ça m’occupera pendant les vacances la semaine prochaine
