Problème sur la remontée de température de sonde
Le log précédent ne provient pas de cette machine alors.
Regardez le haut du log.
Je vois bien, mais cela provient bien de la même machine :
Linux jeedom 6.6.35-v7+ #1779 SMP Tue Jun 25 11:35:42 BST 2024 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jul  5 21:47:04 2024 from 192.168.2.25
jeedom@jeedom:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.6.35-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1779 SMP Tue Jun 25 11:35:42 BST 2024
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] random: crng init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x3a400000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x3a400000..0x3e3fffff (65536 KiB) map reusable linux,cma
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003e5fffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003e5fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003e5fffff]
[    0.000000] percpu: Embedded 18 pages/cpu s41876 r8192 d23660 u73728
[    0.000000] pcpu-alloc: s41876 r8192 d23660 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=39a3a68b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 253242
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 927592K/1021952K available (11264K kernel code, 1476K rwdata, 3256K rodata, 1024K init, 606K bss, 28824K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 36428 entries in 107 pages
[    0.000000] ftrace: allocated 107 pages with 5 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000018] Switching to timer-based delay loop, resolution 52ns
[    0.000399] Console: colour dummy device 80x30
[    0.000417] printk: console [tty1] enabled
[    0.001260] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001309] CPU: Testing write buffer coherency: ok
[    0.001379] pid_max: default: 32768 minimum: 301
[    0.001508] LSM: initializing lsm=capability,integrity
[    0.001716] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001762] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002821] cgroup: Disabling memory control group subsystem
[    0.003405] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004432] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.004564] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.004734] Setting up static identity map for 0x100000 - 0x10003c
[    0.004903] rcu: Hierarchical SRCU implementation.
[    0.004929] rcu:     Max phase no-delay instances is 1000.
[    0.005628] smp: Bringing up secondary CPUs ...
[    0.006575] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.007492] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.008340] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.008439] smp: Brought up 1 node, 4 CPUs
[    0.008526] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.008556] CPU: All CPU(s) started in HYP mode.
[    0.008576] CPU: Virtualization extensions available.
[    0.009755] devtmpfs: initialized
[    0.022599] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.022840] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.022895] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.025324] pinctrl core: initialized pinctrl subsystem
[    0.026366] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.028721] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.034282] audit: initializing netlink subsys (disabled)
[    0.034557] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[    0.035125] thermal_sys: Registered thermal governor 'step_wise'
[    0.035477] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.035536] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.035882] Serial: AMBA PL011 UART driver
[    0.039822] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.060028] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-05-24T15:31:41, variant start_cd
[    0.070053] raspberrypi-firmware soc:firmware: Firmware hash is 4942b7633c0ff1af1ee95a51a33b56a9dae47529
[    0.083991] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.088128] bcm2835-dma 3f007000.dma-controller: DMA legacy API manager, dmachans=0x1
[    0.089821] SCSI subsystem initialized
[    0.090078] usbcore: registered new interface driver usbfs
[    0.090145] usbcore: registered new interface driver hub
[    0.090214] usbcore: registered new device driver usb
[    0.090626] pps_core: LinuxPPS API ver. 1 registered
[    0.090653] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.090704] PTP clock support registered
[    0.093113] clocksource: Switched to clocksource arch_sys_counter
[    0.093572] VFS: Disk quotas dquot_6.6.0
[    0.093643] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.093787] FS-Cache: Loaded
[    0.097581] CacheFiles: Loaded
[    0.107174] NET: Registered PF_INET protocol family
[    0.107529] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.109927] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.109988] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.110031] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.110168] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.110518] TCP: Hash tables configured (established 8192 bind 8192)
[    0.110672] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.110746] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.110956] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.111458] RPC: Registered named UNIX socket transport module.
[    0.111488] RPC: Registered udp transport module.
[    0.111511] RPC: Registered tcp transport module.
[    0.111533] RPC: Registered tcp-with-tls transport module.
[    0.111556] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.124334] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    2.054427] Initialise system trusted keyrings
[    2.054811] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    2.054917] zbud: loaded
[    2.055679] NFS: Registering the id_resolver key type
[    2.055726] Key type id_resolver registered
[    2.055750] Key type id_legacy registered
[    2.055794] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.055824] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.056554] Key type asymmetric registered
[    2.056582] Asymmetric key parser 'x509' registered
[    2.056676] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.056712] io scheduler mq-deadline registered
[    2.056737] io scheduler kyber registered
[    2.056803] io scheduler bfq registered
[    2.058565] pinctrl-bcm2835 3f200000.gpio: GPIO_OUT persistence: yes
[    2.061023] bcm2708_fb soc:fb: FB found 1 display(s)
[    2.067055] Console: switching to colour frame buffer device 82x26
[    2.070683] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[    2.076996] bcm2835-rng 3f104000.rng: hwrng registered
[    2.078502] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[    2.092616] brd: module loaded
[    2.101206] loop: module loaded
[    2.103048] Loading iSCSI transport class v2.0-870.
[    2.105778] usbcore: registered new interface driver lan78xx
[    2.107065] usbcore: registered new interface driver smsc95xx
[    2.108249] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.837803] Core Release: 2.80a
[    2.838979] Setting default values for core params
[    2.840154] Finished setting default values for core params
[    3.041548] Using Buffer DMA mode
[    3.042674] Periodic Transfer Interrupt Enhancement - disabled
[    3.043870] Multiprocessor Interrupt Enhancement - disabled
[    3.045078] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.046301] Dedicated Tx FIFOs mode
[    3.048040] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = ba504000 dma = 0xfa504000 len=9024
[    3.051436] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    3.056782] dwc_otg: Microframe scheduler enabled
[    3.056896] WARN::hcd_init_fiq:457: FIQ on core 1
[    3.059024] WARN::hcd_init_fiq:458: FIQ ASM at 808864b8 length 36
[    3.061208] WARN::hcd_init_fiq:496: MPHI regs_base at be810000
[    3.063415] dwc_otg 3f980000.usb: DWC OTG Controller
[    3.064580] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    3.065753] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    3.066917] Init: Port Power? op_state=1
[    3.068014] Init: Power Port (0)
[    3.069296] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    3.071554] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.072763] usb usb1: Product: DWC OTG Controller
[    3.073936] usb usb1: Manufacturer: Linux 6.6.35-v7+ dwc_otg_hcd
[    3.075108] usb usb1: SerialNumber: 3f980000.usb
[    3.076938] hub 1-0:1.0: USB hub found
[    3.078140] hub 1-0:1.0: 1 port detected
[    3.079895] dwc_otg: FIQ enabled
[    3.079905] dwc_otg: NAK holdoff enabled
[    3.079912] dwc_otg: FIQ split-transaction FSM enabled
[    3.079926] Module dwc_common_port init
[    3.080187] usbcore: registered new interface driver usb-storage
[    3.081603] mousedev: PS/2 mouse device common for all mice
[    3.084977] sdhci: Secure Digital Host Controller Interface driver
[    3.086197] sdhci: Copyright(c) Pierre Ossman
[    3.087563] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.090677] ledtrig-cpu: registered to indicate activity on CPUs
[    3.092246] hid: raw HID events driver (C) Jiri Kosina
[    3.093702] usbcore: registered new interface driver usbhid
[    3.094906] usbhid: USB HID core driver
[    3.100552] Initializing XFRM netlink socket
[    3.101811] NET: Registered PF_PACKET protocol family
[    3.103073] Key type dns_resolver registered
[    3.104564] Registering SWP/SWPB emulation handler
[    3.137155] registered taskstats version 1
[    3.138502] Loading compiled-in X.509 certificates
[    3.151924] Key type .fscrypt registered
[    3.153009] Key type fscrypt-provisioning registered
[    3.162365] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    3.165540] 3f201000.serial: ttyAMA1 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.168084] serial serial0: tty port ttyAMA1 registered
[    3.171046] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.172498] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    3.175066] sdhost: log_buf @ 132d7143 (fa507000)
[    3.203225] Indeed it is in host mode hprt0 = 00021501
[    3.227048] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.230665] of_cfs_init
[    3.231953] of_cfs_init: OK
[    3.233475] clk: Disabling unused clocks
[    3.235384] Waiting for root device PARTUUID=39a3a68b-02...
[    3.288202] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.295419] mmc0: Host Software Queue enabled
[    3.296638] mmc0: new high speed SDXC card at address aaaa
[    3.298645] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
[    3.302767]  mmcblk0: p1 p2
[    3.304690] mmcblk0: mmc0:aaaa SR64G 59.5 GiB (quirks 0x00004000)
[    3.349460] EXT4-fs (mmcblk0p2): mounted filesystem 7a4375b9-aaa1-4be1-bc58-ff4332e11847 ro with ordered data mode. Quota mode: none.
[    3.352075] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.354263] devtmpfs: mounted
[    3.360799] Freeing unused kernel image (initmem) memory: 1024K
[    3.362585] Run /sbin/init as init process
[    3.363833]   with arguments:
[    3.363841]     /sbin/init
[    3.363848]   with environment:
[    3.363854]     HOME=/
[    3.363860]     TERM=linux
[    3.413156] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.414630] Indeed it is in host mode hprt0 = 00001101
[    3.653428] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[    3.656016] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.658120] hub 1-1:1.0: USB hub found
[    3.659591] hub 1-1:1.0: 5 ports detected
[    3.897911] systemd[1]: System time before build time, advancing clock.
[    3.973160] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    4.103490] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[    4.106260] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.110403] smsc95xx v2.0.0
[    4.135857] NET: Registered PF_INET6 protocol family
[    4.138568] Segment Routing with IPv6
[    4.140058] In-situ OAM (IOAM) with IPv6
[    4.212361] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    4.217585] systemd[1]: Detected architecture arm.
[    4.265080] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=199)
[    4.268977] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:19:37:45
[    4.313550] systemd[1]: Set hostname to <jeedom>.
[    4.363213] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[    4.505500] usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[    4.508654] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.510206] usb 1-1.5: Product: ConBee II
[    4.511652] usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[    4.513210] usb 1-1.5: SerialNumber: DE2425277
[    5.160634] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[    5.268193] systemd[1]: Listening on fsck to fsckd communication Socket.
[    5.271862] systemd[1]: Reached target Swap.
[    5.275768] systemd[1]: Listening on udev Control Socket.
[    5.279274] systemd[1]: Listening on udev Kernel Socket.
[    5.282878] systemd[1]: Listening on Syslog Socket.
[    5.286145] systemd[1]: Reached target System Time Synchronized.
[    6.307311] EXT4-fs (mmcblk0p2): re-mounted 7a4375b9-aaa1-4be1-bc58-ff4332e11847 r/w. Quota mode: none.
[    6.477406] systemd-journald[111]: Received request to flush runtime journal from PID 1
[    7.154619] rpi-gpiomem 3f200000.gpiomem: window base 0x3f200000 size 0x00001000
[    7.156552] rpi-gpiomem 3f200000.gpiomem: initialised 1 regions as /dev/gpiomem
[    7.232534] mc: Linux media interface: v0.10
[    7.285348] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    7.287178] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    7.287227] [vc_sm_connected_init]: start
[    7.327422] vc_sm_cma_vchi_init: failed to open VCHI service (-22)
[    7.327459] [vc_sm_connected_init]: failed to initialize shared memory service
[    7.452979] videodev: Linux video capture interface: v2.00
[    7.492441] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    7.537881] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    7.544193] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-22)
[    7.563648] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    7.596170] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-22)
[    7.596509] : Unregister from media controller
[    7.596554] (efault): Unregistering node (null)[0] device node /dev/video0
[    7.596609] (efault): Unregistering node (null)[0] device node /dev/video0
[    7.596661] (efault): Unregistering node (null)[0] device node /dev/video0
[    7.596709] (efault): Unregistering node (null)[0] device node /dev/video0
[    7.715067] usb 1-1.5: USB disconnect, device number 4
[    7.752372] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    7.803549] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-22)
[    7.861434] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    7.907682] bcm2835_audio bcm2835_audio: card created with 8 channels
[    8.056489] Bluetooth: Core ver 2.22
[    8.056601] NET: Registered PF_BLUETOOTH protocol family
[    8.056611] Bluetooth: HCI device and connection manager initialized
[    8.056638] Bluetooth: HCI socket layer initialized
[    8.056654] Bluetooth: L2CAP socket layer initialized
[    8.056682] Bluetooth: SCO socket layer initialized
[    8.073214] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[    8.156767] Bluetooth: HCI UART driver ver 2.3
[    8.156804] Bluetooth: HCI UART protocol H4 registered
[    8.156907] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    8.157452] Bluetooth: HCI UART protocol Broadcom registered
[    8.158231] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    8.158466] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    8.210865] usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[    8.210904] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.210919] usb 1-1.5: Product: ConBee II
[    8.210931] usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[    8.210942] usb 1-1.5: SerialNumber: DE2425277
[    8.273396] uart-pl011 3f201000.serial: no DMA platform data
[    8.551191] Bluetooth: hci0: BCM: chip id 94
[    8.555655] Bluetooth: hci0: BCM: features 0x2e
[    8.558966] Bluetooth: hci0: BCM43430A1
[    8.559000] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[    8.581964] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.hcd' Patch
[    8.650309] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[    8.650492] usbcore: registered new interface driver cdc_acm
[    8.650504] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    9.414238] Bluetooth: hci0: BCM: features 0x2e
[    9.417405] Bluetooth: hci0: BCM43438A1 37.4MHz Raspberry Pi 3-0141
[    9.417419] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0508
[   10.071138] 8021q: 802.1Q VLAN Support v1.8
[   10.348345] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.382430] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   10.385291] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   10.388051] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.390626] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   10.566229] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   10.569193] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[   10.608618] Adding 1048572k swap on /var/swap.  Priority:-2 extents:13 across:3244028k SS
[   10.958449] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   10.958477] Bluetooth: BNEP filters: protocol multicast
[   10.958495] Bluetooth: BNEP socket layer initialized
[   10.966114] Bluetooth: MGMT ver 1.22
[   22.805776] systemd[978]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[  138.663289] Bluetooth: hci0: Opcode 0x200c failed: -16
[  138.663347] Bluetooth: hci0: start background scanning failed: -16
jeedom@jeedom:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
jeedom@jeedom:~ $
Ha oui, c’est pareil chez moi, j’avais oublié cela :
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
[    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.2
[    0.000000] efi: UEFI not found.
Par contre, je ne comprends pas votre version visible dans ce log.
Ou alors, vous avez fait une mise a jour du kernel, ce qui est peut être la source de votre problème.
Pouvez vous réinstaller Debian 10 light et y restaurer votre Jeedom pour voir. Sans faire de mise a jour du kernel. Vous devriez être sur un kernel 5.
Justement, avant de faire la mise à jour du Kernel, j’avais déjà le problème.
Par contre, j’ai installé sur mon RPI une image pré-compilée.
Il faudrait que je refasse l’installation avec une Debian lite et ensuite j’installe jeedom en suivant la procédure d’installation manuelle.
Par contre, je n’aurais pas le choix de prendre Debian 11
CitationPouvez vous réinstaller Debian 10 light et y restaurer votre Jeedom pour voir. Sans faire de mise a jour du kernel. Vous devriez être sur un kernel 5.
Ah ok, je ferais çà demain, si j’arrive à trouver une image en Debian 10… Debian 11 pose vraiment des problèmes ?
Si, c’est toujours possible de télécharger Debian 10, mais a ce stade, moi j’ai fait le choix de remplacer BLEA par Mqttdiscovery et tgw pour ne pas rester sur un os déprécié.
Avec BLEA oui, mais apsnchez tout le monde.
On ne peut que vous conseiller de passer sur Debian 11. D’autant, que des packages commence depuis au moins 6 mois a disparaitres sur cette version.
Ah et bien, autant que j’essaye ceci, en éspérant que je ne vais pas perdre tout mon historique de température…
Sinon, j’ai constaté un autre problème : certaines de mes sondes (Xiaomi carrées) sont bien vu présente, mais affiche une température erronée qui ne bouge pas ; alors que mes sondes Xiaomi ronde remontent la bonne température (toujours avec ce laps de temps d’1 minutes avant le blocage)
Supprimez les piles de vos sondes pour voir, il est possible qu’une sonde défectueuse créer ce problème
Ne laissez qu’un truc pour voir.
Dans la sauvegarde de Jeedom, il y a tout votre historique.
Ok, j’essayerais çà ;
ce que je voulais dire, c’est que si je passe sur MQTTDiscovery, j’espère ne pas perdre l’historique de mes sondes.
Non plus, car Jeedom intègre une fonction pour remplacer un équipement par un autre. Regardez la fonction remplacer. C’est une vraie perle !
Après ré-installation complète du Raspberry PI 3 avec Debian 11 en 64 bits (autant se mettre un peu au gout du jour) ; le problème de blocage est identique avec BLEA.
Je suis du coup passé sur MQTTDiscovery ; il n’y a plus l’air d’avoir de blocage, par contre j’ai l’impression qu’il détecte mal mes sondes Xiaomi :
Je n’ai plus l’icône comme auparavant :
Bonjour.
Pour le widget, regardez dans l’équipement, vous pouvez lui affecter le widget hygrothermographe
je suis dans le dashboard en fait
Et ?
Il faut cliquer sur votre équipement, puis allez ensuite sur l’onglet commandes.
Sélectionnez la commande température par exemple et puis allez sur sa roue crantée. Ensuite, onglet affichage et appliquez lui Hygrothermographe.
Ah oui, effectivement ; il y avait longtemps que j’avais paramétré mes sondes.
D’ailleurs depuis tout ce temps, je n’ai au aucun problème.
Je crois avoir compris la commande « remplacer » pour récupérer mon historique…
Et donc, si j’ai bien compris, avec MQTT, j’ai 3 plugins qui tournent en permanence : MQTT manager, Theegs Gateway (pour l’anntenne Bluetooth - qui permet de se connecter à une antenne distante si j’ai bien lu) et MQTT Discovery.
Et tout çà, bien plus stable que BLEA et évolutif ?
Oui, très stable.
Par contre, que 2 pluginz en fait. Car techniquement, le plugin tgw ne fait une vous aider à installer les antennes Theengs Gateway.
Il est possible de faire sans ce plugin à la condition de savoir se débrouiller tout seul.
Et ce n’est pas que pour les antennes distantes, c’est aussi valable pour l’antenne locale.
Je confirme que çà à l’air plus stable, j’ai l’impression d’avoir les remontée de mes sondes en temps réels quasiment.
Finalement, tout ceci à été bénéfique :
  • ré-installation complète de mon Raspberry sur une version plus récente (et en 64bits) ; une belle évolution
  • remplacement du plugin BLEA par MQTT
  • récupération de l’historique
Et en plus, j’ai changé la carte micro-SD de mon RPI, j’ai l’impression qu’elle ramait à fond (normal depuis le temps qu’elle tournait)
Un grand merci, @Fabrice pour tout ces conseils et ce précieux « coup de main » !!
Je ne me sentais pas de tout ré-installer à la main et de perdre tout l’historique.
…par contre, mon Raspberry chauffe beaucoup plus qu’avant ; c’est le fait qu’il y ait plus de plug-in qui tournent peut-être :frowning:
C’est plutôt l’effet Debian 11 (consomme davantage).
