Ça donne rien
As tu réussi à débloquer le tien?
Non j’ai eu une mise à jour de setuptools :
Sudo pip3 install --upgrade setuptools
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (60.9.3)
Collecting setuptools
Using cached setuptools-65.4.0-py3-none-any.whl (1.2 MB)
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 60.9.3
Uninstalling setuptools-60.9.3:
Successfully uninstalled setuptools-60.9.3
Successfully installed setuptools-65.4.0
WARNING: Running pip as the ‹ root › user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.10.7 documentation
Mais ça reste bloquée a 4% maintenant dans rendre la main lorsque je tente de réinstaller la dépendance manuellement
Mais beaucoup plus verbos
echo '*******************Begin of package installation******************'
+ touch /tmp/jeedom_install_in_progress_xiaomihome
+ echo 1
+ echo 2
++ find /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (22.2.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 4
+ sudo pip3 install --force-reinstall --upgrade python-miio
Collecting python-miio
Using cached python_miio-0.5.12-py3-none-any.whl (330 kB)
Collecting cryptography>=35
Using cached cryptography-38.0.1.tar.gz (599 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting android_backup<1,>=0
Using cached android_backup-0.2.0.tar.gz (6.1 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting croniter>=1
Using cached croniter-1.3.7-py2.py3-none-any.whl (17 kB)
Collecting tqdm<5,>=4
Using cached tqdm-4.64.1-py2.py3-none-any.whl (78 kB)
Collecting attrs
Using cached attrs-22.1.0-py2.py3-none-any.whl (58 kB)
Collecting zeroconf<1,>=0
Using cached zeroconf-0.39.1-py3-none-any.whl (106 kB)
Collecting construct<3.0.0,>=2.10.56
Using cached construct-2.10.68.tar.gz (57 kB)
Collecting click>=8
Using cached click-8.1.3-py3-none-any.whl (96 kB)
Collecting defusedxml<1,>=0
Using cached defusedxml-0.7.1-py2.py3-none-any.whl (25 kB)
Collecting importlib_metadata<2,>=1
Using cached importlib_metadata-1.7.0-py2.py3-none-any.whl (31 kB)
Collecting appdirs<2,>=1
Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
Collecting PyYAML<7,>=5
Using cached PyYAML-6.0.tar.gz (124 kB)
Collecting pytz
Using cached pytz-2022.2.1-py2.py3-none-any.whl (500 kB)
Collecting micloud
Using cached micloud-0.5.tar.gz (7.8 kB)
Collecting netifaces<1,>=0
Using cached netifaces-0.11.0.tar.gz (30 kB)
Collecting python-dateutil
Using cached python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.1-cp37-cp37m-linux_armv7l.whl
Collecting zipp>=0.5
Downloading zipp-3.8.1-py3-none-any.whl (5.6 kB)
Collecting ifaddr>=0.1.7
Downloading ifaddr-0.2.0-py3-none-any.whl (12 kB)
Collecting async-timeout>=4.0.1
Downloading async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting requests
Downloading requests-2.28.1-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.8/62.8 kB 1.2 MB/s eta 0:00:00
Collecting tzlocal
Downloading tzlocal-4.2-py3-none-any.whl (19 kB)
Collecting pycryptodome
Downloading pycryptodome-3.15.0.tar.gz (4.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.5/4.5 MB 6.0 MB/s eta 0:00:00
Collecting typing-extensions>=3.6.5
Using cached typing_extensions-4.3.0-py3-none-any.whl (25 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Collecting six>=1.5
Using cached six-1.16.0-py2.py3-none-any.whl (11 kB)
Collecting idna<4,>=2.5
Downloading idna-3.4-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.5/61.5 kB 2.5 MB/s eta 0:00:00
Collecting certifi>=2017.4.17
Downloading certifi-2022.9.24-py3-none-any.whl (161 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 161.1/161.1 kB 4.4 MB/s eta 0:00:00
Collecting charset-normalizer<3,>=2
Downloading charset_normalizer-2.1.1-py3-none-any.whl (39 kB)
Collecting urllib3<1.27,>=1.21.1
Downloading urllib3-1.26.12-py2.py3-none-any.whl (140 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 140.4/140.4 kB 3.8 MB/s eta 0:00:00
Collecting backports.zoneinfo
Downloading backports.zoneinfo-0.2.1.tar.gz (74 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 74.1/74.1 kB 4.0 MB/s eta 0:00:00
Collecting pytz-deprecation-shim
Downloading pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
Collecting tzdata
Downloading tzdata-2022.2-py2.py3-none-any.whl (336 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 336.4/336.4 kB 9.2 MB/s eta 0:00:00
Building wheels for collected packages: android_backup, construct, cryptography, netifaces, PyYAML, micloud, pycryptodome, backports.zoneinfo
Building wheel for android_backup (setup.py): started
Building wheel for android_backup (setup.py): finished with status 'done'
Created wheel for android_backup: filename=android_backup-0.2.0-py3-none-any.whl size=7613 sha256=6ca4139aaba5c9e36f26fd4817bef30beebcad98e5bac2da5f24c66a887f541f
Stored in directory: /root/.cache/pip/wheels/ec/ab/f1/feb14d3068d6c07a26f15e57f34a157e8b317920fef8fa42e3
Building wheel for construct (setup.py): started
Building wheel for construct (setup.py): finished with status 'done'
Created wheel for construct: filename=construct-2.10.68-py3-none-any.whl size=59224 sha256=c6b84d5ad4b2fa90c0f4e1fd371bc89cc399517ddc8f745d0d5ded7a835e48b1
Stored in directory: /root/.cache/pip/wheels/32/b9/a0/30cd99f34b5d16190994a5a110d32c44712dd33507e7de2fad
Building wheel for cryptography (pyproject.toml): started
Building wheel for cryptography (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
× Building wheel for cryptography (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [191 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-37
creating build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
creating build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.circleci'
adding license file 'LICENSE'
adding license file 'LICENSE.APACHE'
adding license file 'LICENSE.BSD'
adding license file 'LICENSE.PSF'
writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/hazmat/bindings/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
running build_ext
running build_rust
/usr/local/lib/python3.7/dist-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning: Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
# Package would be ignored #
Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package,
but it is not listed in the `packages` configuration of setuptools.
'cryptography.hazmat.bindings._rust' has been automatically added to the distribution only
because it may contain data files, but this behavior is likely to change
in future versions of setuptools (and therefore is considered deprecated).
Please make sure that 'cryptography.hazmat.bindings._rust' is included as a package by using
the `packages` configuration field or the proper discovery methods
(for example by using `find_namespace_packages(...)`/`find_namespace:`
instead of `find_packages(...)`/`find:`).
You can read more about "package discovery" and "data files" on setuptools
documentation page.
check.warn(importable)
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.7.3
platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
pip: 22.2.2
setuptools: 65.4.0
setuptools_rust: 1.5.2
rustc: n/a
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.48.0.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography
Building wheel for netifaces (setup.py): started
Building wheel for netifaces (setup.py): finished with status 'done'
Created wheel for netifaces: filename=netifaces-0.11.0-cp37-cp37m-linux_armv7l.whl size=29664 sha256=d352cc9ff2d92ed2d2c7840282d2ae400266915c7023155b17342b276c9dc6fe
Stored in directory: /root/.cache/pip/wheels/de/4d/2c/5d57c99647cb68bcea4f729b6fa95fb1f9e5e75ebb3f732483
Building wheel for PyYAML (pyproject.toml): started
Building wheel for PyYAML (pyproject.toml): finished with status 'done'
Created wheel for PyYAML: filename=PyYAML-6.0-cp37-cp37m-linux_armv7l.whl size=45334 sha256=f96171d7958e9e1999ad63be7d337b8ecd62b360d3dec3b764984238c436b883
Stored in directory: /root/.cache/pip/wheels/ca/e8/5c/5bdf13545e93ea6fda886afab27e2faecc419e84bf870c2623
Building wheel for micloud (setup.py): started
Building wheel for micloud (setup.py): finished with status 'done'
Created wheel for micloud: filename=micloud-0.5-py3-none-any.whl size=8003 sha256=67d157d1644b7adddfd3d28119462c6e6c6dddd6d4a33b5cfc60cfc2b455530d
Stored in directory: /root/.cache/pip/wheels/5a/3d/1f/e8b4a08221022192771953b2edbca9b753c405cc0e41e0ff01
Building wheel for pycryptodome (setup.py): started
Building wheel for pycryptodome (setup.py): still running...
Building wheel for pycryptodome (setup.py): finished with status 'done'
Created wheel for pycryptodome: filename=pycryptodome-3.15.0-cp35-abi3-linux_armv7l.whl size=1791544 sha256=05bf3a9ed3851ab899665000a4c6d86abda5189a1960ff19121512cbd6b7b658
Stored in directory: /root/.cache/pip/wheels/3c/51/d7/915ccdbe9e41d96705b1037d9e92d887902418a39785e13546
Building wheel for backports.zoneinfo (pyproject.toml): started
Building wheel for backports.zoneinfo (pyproject.toml): finished with status 'done'
Created wheel for backports.zoneinfo: filename=backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl size=52806 sha256=bcb033ad3db3519479c0fd3cff103fe64b82e20208b8c6c8cc3148ad1cfe848a
Stored in directory: /root/.cache/pip/wheels/ce/bb/ad/1f44f43f7c4fce0a96dbe348c4acdf4fe2481496933357be62
Successfully built android_backup construct netifaces PyYAML micloud pycryptodome backports.zoneinfo
Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
+ echo 5
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end xiaomihome
+ rm /tmp/jeedom_install_in_progress_xiaomihome
En ssh
sudo pip install cryptography
Permet de vérifier sans lancer !es dépendances jeedom, j’ai trouvé cela plus rapide, en phase de test
J’ai fait une installation rustc et j’ai cette erreur :
error: Rust 1.41.1 does not match extension requirement >=1.48.0
Comme ici :
Nouveau log :
+ echo 1
+ echo 2
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ echo 4
Using cached netifaces-0.11.0-cp37-cp37m-linux_armv7l.whl
Using cached construct-2.10.68-py3-none-any.whl
Collecting click>=8
Using cached PyYAML-6.0-cp37-cp37m-linux_armv7l.whl
Using cached android_backup-0.2.0-py3-none-any.whl
Collecting attrs
Collecting pytz
Collecting micloud
Using cached micloud-0.5-py3-none-any.whl
Using cached zipp-3.8.1-py3-none-any.whl (5.6 kB)
Using cached ifaddr-0.2.0-py3-none-any.whl (12 kB)
Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting requests
Using cached requests-2.28.1-py3-none-any.whl (62 kB)
Using cached pycryptodome-3.15.0-cp35-abi3-linux_armv7l.whl
Collecting tzlocal
Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
Collecting six>=1.5
Using cached charset_normalizer-2.1.1-py3-none-any.whl (39 kB)
Using cached idna-3.4-py3-none-any.whl (61 kB)
Using cached certifi-2022.9.24-py3-none-any.whl (161 kB)
Using cached urllib3-1.26.12-py2.py3-none-any.whl (140 kB)
Using cached pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
Using cached backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl
Collecting tzdata
Using cached tzdata-2022.2-py2.py3-none-any.whl (336 kB)
Building wheels for collected packages: cryptography
│ exit code: 1
╰─> [179 lines of output]
running bdist_wheel
running build
running build_py
creating build
running egg_info
running build_ext
running build_rust
documentation page.
Python: 3.7.3
pip: 22.2.2
setuptools: 65.4.0
rustc: 1.41.1
[end of output]
+ echo 5
sudo apt -y install rustc
A installé la version 1.41 et l’on demande la 1.48
Oui je confirme et j’arrive pas a trouver comment installer cette version 1.48…
rustc --version
Donne
rustc 1.64.0 (a55dd71d5 2022-09-19)
Et pourtant il y a 1.41 quand je lance crypto…truc
Ah non moi il donne bien 1.41.1
Tu avais installé comme ça toi je crois ?
curl --proto ‹ =https › --tlsv1.2 -sSf https://sh.rustup.rs
Oui,c’est ca
J’ai pas passé la commande mais ca change rien
. Après on est pas les seuls avec cette erreur comme vu tout à l’heure :
J’abandonne pour aujourd’hui, a demain
Même erreur faite ce matin de mettre à jour le plugin. J’ai hésite à faire la MAJ et j’aurais du m’écouter …
Le plugin fonctionne mais installation des dépendances tourne en boucle …
Bon espérons un correctif du Dev…
oui il faut que tu arrives à réparer au moins cryptography (tente en cliquant sur corriger à droite) et pour python-miio vu qu’il y a d’autres personnes qui ont le soucis je pense que l’on va attendre une solution Dev je vois pas d’autres solutions avec tous les tests que l’on a réalisé …
Finalement après plusieurs relance en appuyant sur installer, cela a finit par fonctionner.
Je croise les doigts et je n’y touche plus
Lorsque je clique sur corriger ; les 2 erreures retournées sont
C’est ce paquet qu’il faut installer ?
sudo apt install libstd-rust-1.48
meme aprés avoir lancé « sudo apt-get update »
