[START CHECK AND FIX DB]
Fix : CREATE TABLE IF NOT EXISTS `cmd` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`eqLogic_id` int(11) NOT NULL,
`eqType` varchar(127) NULL,
`logicalId` varchar(1023) NULL,
`order` int(11) NULL,
`name` varchar(127) NULL,
`configuration` mediumtext NULL,
`template` text NULL,
`isHistorized` varchar(45) NOT NULL,
`type` varchar(45) NULL,
`subType` varchar(45) NULL,
`unite` varchar(45) NULL,
`display` text NULL,
`isVisible` int(11) NULL DEFAULT "1",
`value` varchar(255) NULL,
`alert` text NULL,
`generic_type` varchar(255) NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC);
CREATE INDEX `isHistorized` ON `cmd` (`isHistorized` ASC);
CREATE INDEX `type` ON `cmd` (`type` ASC);
CREATE INDEX `name` ON `cmd` (`name` ASC);
CREATE INDEX `subtype` ON `cmd` (`subType` ASC);
CREATE INDEX `eqLogic_id` ON `cmd` (`eqLogic_id` ASC);
CREATE INDEX `value` ON `cmd` (`value` ASC);
CREATE INDEX `order` ON `cmd` (`order` ASC);
CREATE INDEX `logicalID` ON `cmd` (`logicalId` ASC)
Fix : CREATE TABLE IF NOT EXISTS `config` (
`plugin` varchar(127) NOT NULL DEFAULT "core",
`key` varchar(127) NOT NULL,
`value` mediumtext NULL,
primary key(`plugin`,`key`))
ENGINE InnoDB;
Fix : CREATE TABLE IF NOT EXISTS `cron` (
`enable` int(11) NULL,
`class` varchar(127) NULL,
`function` varchar(127) NOT NULL,
`schedule` varchar(127) NULL,
`timeout` int(11) NULL,
`deamon` int(11) NULL DEFAULT "0",
`deamonSleepTime` int(11) NULL,
`option` text NULL,
`once` int(11) NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `function` ON `cron` (`function` ASC);
CREATE INDEX `deamon` ON `cron` (`deamon` ASC)
Fix : CREATE TABLE IF NOT EXISTS `dataStore` (
`type` varchar(127) NOT NULL,
`link_id` int(11) NOT NULL,
`value` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `UNIQUE` ON `dataStore` (`type` ASC,`link_id` ASC,`key` ASC)
Fix : CREATE TABLE IF NOT EXISTS `eqLogic` (
`name` varchar(127) NOT NULL,
`logicalId` varchar(127) NULL,
`object_id` int(11) NULL,
`eqType_name` varchar(127) NOT NULL,
`isVisible` tinyint(1) NULL,
`isEnable` tinyint(1) NULL,
`status` text NULL,
`category` text NULL,
`order` int(11) NULL DEFAULT "1",
`comment` text NULL,
`tags` varchar(255) NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `eqLogic` (`name` ASC,`object_id` ASC);
CREATE INDEX `eqTypeName` ON `eqLogic` (`eqType_name` ASC);
CREATE INDEX `name` ON `eqLogic` (`name` ASC);
CREATE INDEX `logical_id` ON `eqLogic` (`logicalId` ASC);
CREATE INDEX `object_id` ON `eqLogic` (`object_id` ASC);
CREATE INDEX `timeout` ON `eqLogic` (`timeout` ASC);
CREATE INDEX `generic_type` ON `eqLogic` (`generic_type` ASC);
CREATE INDEX `tags` ON `eqLogic` (`tags` ASC)
Fix : CREATE TABLE IF NOT EXISTS `history` (
`cmd_id` int(11) NOT NULL,
`datetime` datetime NOT NULL,
`value` varchar(127) NULL,
primary key(`cmd_id`,`datetime`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `history` (`datetime` ASC,`cmd_id` ASC);
CREATE INDEX `fk_history5min_commands1_idx` ON `history` (`cmd_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `historyArch` (
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `historyArch` (`cmd_id` ASC,`datetime` ASC)
Fix : CREATE TABLE IF NOT EXISTS `interactDef` (
`name` varchar(255) NULL,
`enable` int(11) NULL DEFAULT "1",
`query` text NULL,
`reply` text NULL,
`person` varchar(255) NULL,
`options` text NULL,
`filtres` text NULL,
`group` varchar(127) NULL,
`actions` text NULL,
primary key(`id`))
ENGINE InnoDB;
Fix : CREATE TABLE IF NOT EXISTS `interactQuery` (
`interactDef_id` int(11) NOT NULL,
`query` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `fk_sarahQuery_sarahDef1_idx` ON `interactQuery` (`interactDef_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `listener` (
`function` varchar(127) NULL,
`event` varchar(511) NULL,
`option` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `event` ON `listener` (`event`(255) ASC)
Fix : CREATE TABLE IF NOT EXISTS `message` (
`date` datetime NOT NULL,
`plugin` varchar(127) NOT NULL,
`message` text NULL,
`action` text NULL,
`occurrences` int(11) NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `plugin_logicalID` ON `message` (`plugin` ASC,`logicalId` ASC)
Fix : CREATE TABLE IF NOT EXISTS `note` (
`text` text NULL,
primary key(`id`))
ENGINE InnoDB;
Fix : CREATE TABLE IF NOT EXISTS `object` (
`father_id` int(11) NULL,
`position` int(11) NULL,
`configuration` text NULL,
`image` mediumtext NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `name_UNIQUE` ON `object` (`name` ASC);
CREATE INDEX `fk_object_object1_idx1` ON `object` (`father_id` ASC);
CREATE INDEX `position` ON `object` (`position` ASC)
Fix : CREATE TABLE IF NOT EXISTS `plan` (
`planHeader_id` int(11) NOT NULL,
`link_type` varchar(127) NULL,
`link_id` int(11) NULL,
`position` text NULL,
`css` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `unique` ON `plan` (`link_type` ASC,`link_id` ASC);
CREATE INDEX `fk_plan_planHeader1_idx` ON `plan` (`planHeader_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `plan3d` (
`plan3dHeader_id` int(11) NOT NULL,
`link_id` varchar(127) NULL,
`css` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `name` ON `plan3d` (`name` ASC);
CREATE INDEX `link_type_link_id` ON `plan3d` (`link_type` ASC,`link_id` ASC);
CREATE INDEX `fk_3d_3dHeader1_idx` ON `plan3d` (`plan3dHeader_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `plan3dHeader` (
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `order` ON `plan3dHeader` (`order` ASC)
Fix : CREATE TABLE IF NOT EXISTS `planHeader` (
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `order` ON `planHeader` (`order` ASC)
Fix : CREATE TABLE IF NOT EXISTS `scenario` (
`isActive` tinyint(1) NULL DEFAULT "1",
`mode` varchar(127) NULL,
`schedule` text NULL,
`scenarioElement` text NULL,
`trigger` varchar(511) NULL,
`isVisible` tinyint(1) NULL DEFAULT "1",
`description` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `name` ON `scenario` (`group` ASC,`object_id` ASC,`name` ASC);
CREATE INDEX `fk_scenario_object1_idx` ON `scenario` (`object_id` ASC);
CREATE INDEX `trigger` ON `scenario` (`trigger`(255) ASC);
CREATE INDEX `mode` ON `scenario` (`mode` ASC);
CREATE INDEX `modeTriger` ON `scenario` (`mode` ASC,`trigger`(255) ASC)
Fix : CREATE TABLE IF NOT EXISTS `scenarioElement` (
`order` int(11) NOT NULL,
`type` varchar(127) NULL,
`log` text NULL,
primary key(`id`))
ENGINE InnoDB;
Fix : CREATE TABLE IF NOT EXISTS `scenarioExpression` (
`scenarioSubElement_id` int(11) NOT NULL,
`subtype` varchar(127) NULL,
`expression` text NULL,
`log` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `fk_scenarioExpression_scenarioSubElement1_idx` ON `scenarioExpression` (`scenarioSubElement_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `scenarioSubElement` (
`scenarioElement_id` int(11) NOT NULL,
`log` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `fk_scenarioSubElement_scenarioElement1_idx` ON `scenarioSubElement` (`scenarioElement_id` ASC);
CREATE INDEX `type` ON `scenarioSubElement` (`scenarioElement_id` ASC,`type` ASC)
Fix : CREATE TABLE IF NOT EXISTS `update` (
`localVersion` varchar(127) NULL,
`remoteVersion` varchar(127) NULL,
`updateDate` datetime NULL,
`source` varchar(127) NULL DEFAULT "market",
`status` varchar(127) NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `status` ON `update` (`status` ASC)
Fix : CREATE TABLE IF NOT EXISTS `user` (
`login` varchar(45) NULL,
`profils` varchar(127) NOT NULL DEFAULT "admin",
`password` varchar(255) NULL,
`hash` varchar(255) NULL,
`rights` text NULL,
primary key(`id`))
ENGINE InnoDB;
Fix : CREATE TABLE IF NOT EXISTS `view` (
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `name_UNIQUE` ON `view` (`name` ASC)
Fix : CREATE TABLE IF NOT EXISTS `viewData` (
`viewZone_id` int(11) NOT NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `viewData` (`viewZone_id` ASC,`link_id` ASC,`type` ASC);
CREATE INDEX `order` ON `viewData` (`order` ASC,`viewZone_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `viewZone` (
`view_id` int(11) NOT NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE INDEX `fk_zone_view1` ON `viewZone` (`view_id` ASC)
Fix : CREATE TABLE IF NOT EXISTS `widgets` (
`name` varchar(191) NOT NULL,
`type` varchar(27) NULL,
`subtype` varchar(27) NULL,
`template` varchar(255) NULL,
`replace` text NULL,
`test` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `widgets` (`type` ASC,`subtype` ASC,`name` ASC)
Fix : CREATE TABLE IF NOT EXISTS `timeline` (
`folder` varchar(255) NULL,
`link_id` varchar(27) NULL,
primary key(`id`,`datetime`))
ENGINE InnoDB;
CREATE INDEX `datetime` ON `timeline` (`datetime` ASC)[END CHECK AND FIX DB]
Voici le résultat de la commande, mais aucun changement mêm aprés un relance du docker.Texte préformaté
