Delta :
[2019-10-09 13:12:48][DEBUG] : opening session
[2019-10-09 13:12:48][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/tileset/all([])
[2019-10-09 13:12:48][DEBUG] : { "result" : [ { "data" : [ { "category" : "alarm", "ep_id" : 11, "label" : "État de l'alarme", "name" : "state", "refresh" : 2000, "signal_id" : 11, "ui" : { "access" : "r", "display" : "text", "icon_url" : "/resources/images/home/pictos/sirene.png" }, "value" : "idle", "value_type" : "string" }, { "category" : "alarm", "ep_id" : 1, "label" : "Alarme principale", "name" : "alarm1", "slot_id" : 1, "ui" : { "access" : "w", "display" : "button", "icon_url" : "/resources/images/home/pictos/alarm_1.png" }, "value" : null, "value_type" : "void" }, { "category" : "alarm", "ep_id" : 2, "label" : "Alarme secondaire", "name" : "alarm2", "slot_id" : 2, "ui" : { "access" : "w", "display" : "button", "icon_url" : "/resources/images/home/pictos/alarm_2.png" }, "value" : null, "value_type" : "void" }, { "category" : "alarm", "ep_id" : 4, "label" : "Désactiver l'alarme", "name" : "off", "slot_id" : 4, "ui" : { "access" : "w", "display" : "button", "icon_url" : "/resources/images/home/pictos/alarm_off.png" }, "value" : null, "value_type" : "void" }, { "category" : "alarm", "ep_id" : 3, "label" : "Passer le délai", "name" : "skip", "slot_id" : 3, "ui" : { "access" : "w", "display" : "button", "icon_url" : "/resources/images/home/pictos/zone_temporisee.png" }, "value" : null, "value_type" : "void" }, { "ep_id" : 5, "label" : "Code PIN", "name" : "pin", "refresh" : 2000, "signal_id" : 12, "slot_id" : 5, "ui" : { "access" : "rw", "display" : "text" }, "value" : "2902", "value_type" : "string" }, { "category" : "alarm", "ep_id" : 13, "label" : "Erreur", "name" : "error", "refresh" : 2000, "signal_id" : 13, "ui" : { "access" : "r", "display" : "text", "icon_url" : "/resources/images/home/pictos/warning.png" }, "value" : "", "value_type" : "string" } ], "ep_type" : "slot", "group" : { "icon_url" : "", "label" : "" }, "node_id" : 5, "type" : "alarm_control" }, { "data" : [ { "ep_id" : 16, "label" : "Caméra", "name" : "cam", "refresh" : 2000, "signal_id" : 16, "ui" : { "access" : "r", "display" : "cam", "icon_url" : "/resources/images/home/pictos/camera.png" }, "value" : "http://freeboxcam:@192.168.0.14/img/stream.m3u8", "value_type" : "string" } ], "ep_type" : "slot", "group" : { "icon_url" : "", "label" : "Salon" }, "label" : "Salon", "node_id" : 6, "type" : "camera" }, { "data" : [ { "ep_id" : 6, "history" : [ { "timestamp" : 1570441904, "value" : "1" }, { "timestamp" : 1570444447, "value" : "0" }, { "timestamp" : 1570444489, "value" : "1" }, { "timestamp" : 1570445731, "value" : "0" }, { "timestamp" : 1570445739, "value" : "1" }, { "timestamp" : 1570448404, "value" : "0" }, { "timestamp" : 1570448460, "value" : "1" }, { "timestamp" : 1570459643, "value" : "0" }, { "timestamp" : 1570459652, "value" : "1" }, { "timestamp" : 1570461824, "value" : "0" }, { "timestamp" : 1570461836, "value" : "1" }, { "timestamp" : 1570465515, "value" : "0" }, { "timestamp" : 1570465523, "value" : "1" }, { "timestamp" : 1570473098, "value" : "0" }, { "timestamp" : 1570473108, "value" : "1" }, { "timestamp" : 1570514628, "value" : "0" }, { "timestamp" : 1570514676, "value" : "1" }, { "timestamp" : 1570515247, "value" : "0" }, { "timestamp" : 1570515298, "value" : "1" }, { "timestamp" : 1570518431, "value" : "0" }, { "timestamp" : 1570518508, "value" : "1" }, { "timestamp" : 1570520688, "value" : "0" }, { "timestamp" : 1570520699, "value" : "1" }, { "timestamp" : 1570526835, "value" : "0" }, { "timestamp" : 1570526858, "value" : "1" }, { "timestamp" : 1570528072, "value" : "1" }, { "timestamp" : 1570534338, "value" : "0" }, { "timestamp" : 1570534387, "value" : "1" }, { "timestamp" : 1570538459, "value" : "0" }, { "timestamp" : 1570538466, "value" : "1" }, { "timestamp" : 1570540832, "value" : "0" }, { "timestamp" : 1570540867, "value" : "1" }, { "timestamp" : 1570548241, "value" : "0" }, { "timestamp" : 1570548250, "value" : "1" }, { "timestamp" : 1570552817, "value" : "0" }, { "timestamp" : 1570552826, "value" : "1" }, { "timestamp" : 1570558194, "value" : "0" }, { "timestamp" : 1570558200, "value" : "1" }, { "timestamp" : 1570601349, "value" : "0" }, { "timestamp" : 1570601359, "value" : "1" }, { "timestamp" : 1570604553, "value" : "0" }, { "timestamp" : 1570604558, "value" : "1" }, { "timestamp" : 1570608558, "value" : "0" }, { "timestamp" : 1570608573, "value" : "1" }, { "timestamp" : 1570608575, "value" : "0" }, { "timestamp" : 1570608577, "value" : "1" }, { "timestamp" : 1570614967, "value" : "0" }, { "timestamp" : 1570614974, "value" : "1" }, { "timestamp" : 1570617890, "value" : "0" }, { "timestamp" : 1570617922, "value" : "1" } ], "label" : "État", "name" : "trigger", "refresh" : 2000, "signal_id" : 6, "ui" : { "access" : "r", "display" : "icon", "icon_url" : "/resources/images/home/pictos/porte_%.png", "status_text_range" : [ "Ouvert", "Fermé" ] }, "value" : true, "value_type" : "bool" }, { "ep_id" : 7, "history" : [ ], "label" : "Couvercle", "name" : "cover", "refresh" : 2000, "signal_id" : 7, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/warning.png", "status_text_range" : [ "Fermé", "Ouvert" ] }, "value" : false, "value_type" : "bool" }, { "ep_id" : 9, "label" : "Batterie faible", "name" : "battery_warning", "refresh" : 2000, "signal_id" : 9, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/batt_0.png", "range" : [ 0, 10 ], "status_text_range" : [ "Batterie critique", "Batterie faible" ], "unit" : "%" }, "value" : 100, "value_type" : "int" }, { "ep_id" : 0, "label" : "", "name" : "alarm1", "refresh" : 2000, "signal_id" : 3, "slot_id" : 0, "ui" : null, "value" : true, "value_type" : "bool" }, { "ep_id" : 1, "label" : "", "name" : "alarm2", "refresh" : 2000, "signal_id" : 4, "slot_id" : 1, "ui" : null, "value" : false, "value_type" : "bool" } ], "ep_type" : "signal", "group" : { "icon_url" : "", "label" : "Entrée" }, "icon_url" : "/resources/images/home/pictos/detecteur_ouverture.png", "label" : "Porte entrée", "node_id" : 7, "type" : "alarm_sensor" }, { "data" : [ { "ep_id" : 5, "label" : "Batterie faible", "name" : "battery_warning", "signal_id" : 5, "ui" : { "access" : "r", "display" : "warning", "icon_range" : [ 0, 10 ], "icon_url" : "/resources/images/home/pictos/batt_0.png", "status_text_range" : [ "Batterie critique", "Batterie faible" ], "unit" : "%" }, "value" : null, "value_type" : "int" }, { "ep_id" : 2, "history" : [ ], "label" : "Bouton appuyé", "name" : "pushed", "signal_id" : 2, "ui" : { "access" : "r", "display" : "none", "icon_range" : [ 1, 2, 3, 4 ], "icon_url" : "/resources/images/home/pictos/kfb_button_%.png", "range" : [ 0, 1, 2, 3 ], "status_text_range" : [ null, "Alarme principale", "Désactivation", "Alarme secondaire" ] }, "value" : null, "value_type" : "int" } ], "ep_type" : "slot", "group" : { "icon_url" : "", "label" : "" }, "icon_url" : "/resources/images/home/pictos/telecommande.png", "label" : "Télécommande Maison", "node_id" : 9, "type" : "alarm_remote" }, { "data" : [ { "ep_id" : 6, "history" : [ { "timestamp" : 1570603947, "value" : "0" }, { "timestamp" : 1570604035, "value" : "1" }, { "timestamp" : 1570604037, "value" : "0" }, { "timestamp" : 1570604120, "value" : "1" }, { "timestamp" : 1570604185, "value" : "0" }, { "timestamp" : 1570604547, "value" : "1" }, { "timestamp" : 1570604640, "value" : "0" }, { "timestamp" : 1570604706, "value" : "1" }, { "timestamp" : 1570605384, "value" : "0" }, { "timestamp" : 1570605444, "value" : "1" }, { "timestamp" : 1570605450, "value" : "0" }, { "timestamp" : 1570605566, "value" : "1" }, { "timestamp" : 1570605841, "value" : "0" }, { "timestamp" : 1570605907, "value" : "1" }, { "timestamp" : 1570606045, "value" : "0" }, { "timestamp" : 1570606124, "value" : "1" }, { "timestamp" : 1570606431, "value" : "0" }, { "timestamp" : 1570606491, "value" : "1" }, { "timestamp" : 1570607466, "value" : "0" }, { "timestamp" : 1570607575, "value" : "1" }, { "timestamp" : 1570607606, "value" : "0" }, { "timestamp" : 1570607858, "value" : "1" }, { "timestamp" : 1570607867, "value" : "0" }, { "timestamp" : 1570607977, "value" : "1" }, { "timestamp" : 1570608237, "value" : "0" }, { "timestamp" : 1570608395, "value" : "1" }, { "timestamp" : 1570615044, "value" : "0" }, { "timestamp" : 1570615178, "value" : "1" }, { "timestamp" : 1570615273, "value" : "0" }, { "timestamp" : 1570615364, "value" : "1" }, { "timestamp" : 1570615554, "value" : "0" }, { "timestamp" : 1570615686, "value" : "1" }, { "timestamp" : 1570617236, "value" : "0" }, { "timestamp" : 1570617296, "value" : "1" }, { "timestamp" : 1570617415, "value" : "0" }, { "timestamp" : 1570617475, "value" : "1" }, { "timestamp" : 1570617536, "value" : "0" }, { "timestamp" : 1570617596, "value" : "1" }, { "timestamp" : 1570617726, "value" : "0" }, { "timestamp" : 1570617831, "value" : "1" }, { "timestamp" : 1570617959, "value" : "0" }, { "timestamp" : 1570618019, "value" : "1" }, { "timestamp" : 1570618023, "value" : "0" }, { "timestamp" : 1570618291, "value" : "1" }, { "timestamp" : 1570618308, "value" : "0" }, { "timestamp" : 1570618651, "value" : "1" }, { "timestamp" : 1570618655, "value" : "0" }, { "timestamp" : 1570618715, "value" : "1" }, { "timestamp" : 1570619435, "value" : "0" }, { "timestamp" : 1570619502, "value" : "1" } ], "label" : "Détection", "name" : "trigger", "refresh" : 2000, "signal_id" : 6, "ui" : { "access" : "r", "display" : "text", "icon_url" : "/resources/images/home/pictos/mouvement.png", "status_text_range" : [ "Mouvement détecté", "Aucun mouvement" ] }, "value" : true, "value_type" : "bool" }, { "ep_id" : 7, "history" : [ { "timestamp" : 1546110382, "value" : "0" } ], "label" : "Couvercle", "name" : "cover", "refresh" : 2000, "signal_id" : 7, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/warning.png", "status_text_range" : [ "Fermé", "Ouvert" ], "unit" : "" }, "value" : false, "value_type" : "bool" }, { "ep_id" : 9, "label" : "Batterie faible", "name" : "battery_warning", "signal_id" : 9, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/batt_0.png", "range" : [ 0, 10 ], "status_text_range" : [ "Batterie critique", "Batterie faible" ], "unit" : "%" }, "value" : null, "value_type" : "int" }, { "ep_id" : 0, "label" : "", "name" : "alarm1", "refresh" : 2000, "signal_id" : 3, "slot_id" : 0, "ui" : null, "value" : false, "value_type" : "bool" }, { "ep_id" : 1, "label" : "", "name" : "alarm2", "refresh" : 2000, "signal_id" : 4, "slot_id" : 1, "ui" : null, "value" : false, "value_type" : "bool" } ], "ep_type" : "signal", "group" : { "icon_url" : "", "label" : "Salon" }, "icon_url" : "/resources/images/home/pictos/detecteur_mouvement.png", "label" : "Mouvement Test", "node_id" : 11, "type" : "alarm_sensor" } ], "success" : true }
[2019-10-09 13:12:48][DEBUG] : closing session
