OUARZA
Octobre 17, 2023, 7:04
1
Je me relance dans ce plugin et je rencontre un problème.
Après avoir renseigné les informations, je constate que malgré la relance du Daemon, je n’ai pas toutes les informations.
J’ai une erreur quand je sélectionne ma GoogleHome dans le widget.
Pourtant quand on regarde les logs, on voit qu’il y a de l’activité.
[2023-10-17 20:54:52][DEBUG] : %%%%%%%%%%%%%%%% BEGIN DEVICE (1888) %%%%%%%%%%%%%%%%
[2023-10-17 20:54:52][DEBUG] : --- DEVICE ID 3b5a3c9abfa0a6d2a0a2ca5d9787a37e2716e462 ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE NAME Web Player (Chrome) ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE VOLUME 100 ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE IS ACTIVE false ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE IS RESTRICTED false ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE TYPE Computer ---
[2023-10-17 20:54:52][DEBUG] : --- CAST CLIENT 192.168.1.43=Cuisine|192.168.1.45=Chambre ---
[2023-10-17 20:54:52][DEBUG] : --- CAST LENGTH 2 ---
[2023-10-17 20:54:52][DEBUG] : --- CAST ID 192.168.1.43 ---
[2023-10-17 20:54:52][DEBUG] : --- CAST NAME Cuisine ---
[2023-10-17 20:54:52][DEBUG] : --- --- DEVICE LENGTH 1 ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- DEVICE ID(0) 3b5a3c9abfa0a6d2a0a2ca5d9787a37e2716e462 ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- DEVICE NAME(0) Web_Player_(Chrome) ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- DEVICE IS ACTIVE(0) false ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- --- NOT FOUND ---
[2023-10-17 20:54:52][DEBUG] : --- CAST ID 192.168.1.45 ---
[2023-10-17 20:54:52][DEBUG] : --- CAST NAME Chambre ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE LENGTH 1 ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE ID(0) 3b5a3c9abfa0a6d2a0a2ca5d9787a37e2716e462 ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE NAME(0) Web_Player_(Chrome) ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE IS ACTIVE(0) false ---
[2023-10-17 20:54:52][DEBUG] : --- --- CAST LENGTH 2 ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- CAST ID(0) 192.168.1.43 ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- CAST NAME(0) Cuisine ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- CAST ID(1) 192.168.1.45 ---
[2023-10-17 20:54:52][DEBUG] : --- --- --- CAST NAME(1) Chambre ---
[2023-10-17 20:54:52][DEBUG] : --- LIST local.192.168.1.43|Cuisine;local.192.168.1.45|Chambre;3b5a3c9abfa0a6d2a0a2ca5d9787a37e2716e462|Web_Player_(Chrome) ---
[2023-10-17 20:54:52][DEBUG] : --- CURRENT DEVICE ID ---
[2023-10-17 20:54:52][DEBUG] : --- CURRENT DEVICE NAME Aucun ---
[2023-10-17 20:54:52][DEBUG] : --- CURRENT DEVICE VOLUME 0 ---
[2023-10-17 20:54:52][DEBUG] : --- CURRENT DEVICE IS ACTIVE false ---
[2023-10-17 20:54:52][DEBUG] : --- CURRENT DEVICE IS RESTRICTED false ---
[2023-10-17 20:54:52][DEBUG] : %%%%%%%%%%%%%%%% END DEVICE (1888) %%%%%%%%%%%%%%%%
[2023-10-17 20:54:52][DEBUG] : --- EXECUTE device_id_set / {"select":"local.192.168.1.43","user_login":"OUARZA","user_id":"2"} ---
[2023-10-17 20:54:52][DEBUG] : --- CLIENT ID 8ed4f692bebXXXXXXf4ab0a7af3b ---
[2023-10-17 20:54:52][DEBUG] : --- CLIENT SECRET 641e52feXXXXXa0d3d627ed1b46 ---
[2023-10-17 20:54:52][DEBUG] : --- EXPIRATION TIME 1697569397 ---
[2023-10-17 20:54:52][DEBUG] : --- ACCESS TOKEN BQDcBIHiQGow2AJryPzPYWCiYAqt5BhG77hOy3iG-JCXM137a5VBiyDbBVIhfHFUQJF8VoLW8kkpIWgYJdXFn7i26Inln6HpQkTlhAAiCGToUXjO2H-Umfp5nX3-xk6D1-mma0AdLIShgdKxsL2tO1fC1IVR1QnK2oSbbw3NvhLHY1qwDhThFEBbo2-I7brTyQEXV6OPOHTLWhRHFzm1rfH2180kxQEISt-DZq_u83nEh0SuE0Jl860iBHQ4_pNoA_wuKPZsfsYeUKBRwpg-6kX8ceAw-eO9dk9474UVR0E7BEvPYQcoDQ ---
[2023-10-17 20:54:52][DEBUG] : --- REFRESH TOKEN AQBZFV-DyeTVffFPeXsVWLS7bXvmjp1raRUrj5Dn3nHdsPXuD9_ziU7WUCaOIs5kwALF5S8vq_YG96h-K7giWWtTM7o07BvB8H0nQd1jarXBHgU2o-QnzpjySWKhW6mCWBM ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE TOKEN = BQDcBIHiQGow2AJryPzPYWCiYAqt5BhG77hOy3iG-JCXM137a5VBiyDbBVIhfHFUQJF8VoLW8kkpIWgYJdXFn7i26Inln6HpQkTlhAAiCGToUXjO2H-Umfp5nX3-xk6D1-mma0AdLIShgdKxsL2tO1fC1IVR1QnK2oSbbw3NvhLHY1qwDhThFEBbo2-I7brTyQEXV6OPOHTLWhRHFzm1rfH2180kxQEISt-DZq_u83nEh0SuE0Jl860iBHQ4_pNoA_wuKPZsfsYeUKBRwpg-6kX8ceAw-eO9dk9474UVR0E7BEvPYQcoDQ ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE REQUESTED ---
[2023-10-17 20:54:52][DEBUG] : --- DEVICE ID = local.192.168.1.43 ---
[2023-10-17 20:54:52][ERROR] : Erreur exécution de la commande [Cuisine][Test cuisine][Device Id Set] : An unknown error occurred.
[2023-10-17 20:55:25][DEBUG] : --- EXECUTE device_id_set / {"select":"local.192.168.1.43","user_login":"OUARZA","user_id":"2"} ---
[2023-10-17 20:55:25][DEBUG] : --- CLIENT ID 8ed4f692bXXXXXX5f4ab0a7af3b ---
[2023-10-17 20:55:25][DEBUG] : --- CLIENT SECRET 641e52febfXXXXXa0d3d627ed1b46 ---
[2023-10-17 20:55:25][DEBUG] : --- EXPIRATION TIME 1697569397 ---
[2023-10-17 20:55:25][DEBUG] : --- ACCESS TOKEN BQDcBIHiQGow2AJryPzPYWCiYAqt5BhG77hOy3iG-JCXM137a5VBiyDbBVIhfHFUQJF8VoLW8kkpIWgYJdXFn7i26Inln6HpQkTlhAAiCGToUXjO2H-Umfp5nX3-xk6D1-mma0AdLIShgdKxsL2tO1fC1IVR1QnK2oSbbw3NvhLHY1qwDhThFEBbo2-I7brTyQEXV6OPOHTLWhRHFzm1rfH2180kxQEISt-DZq_u83nEh0SuE0Jl860iBHQ4_pNoA_wuKPZsfsYeUKBRwpg-6kX8ceAw-eO9dk9474UVR0E7BEvPYQcoDQ ---
[2023-10-17 20:55:25][DEBUG] : --- REFRESH TOKEN AQBZFV-DyeTVffFPeXsVWLS7bXvmjp1raRUrj5Dn3nHdsPXuD9_ziU7WUCaOIs5kwALF5S8vq_YG96h-K7giWWtTM7o07BvB8H0nQd1jarXBHgU2o-QnzpjySWKhW6mCWBM ---
[2023-10-17 20:55:25][DEBUG] : --- DEVICE TOKEN = BQDcBIHiQGow2AJryPzPYWCiYAqt5BhG77hOy3iG-JCXM137a5VBiyDbBVIhfHFUQJF8VoLW8kkpIWgYJdXFn7i26Inln6HpQkTlhAAiCGToUXjO2H-Umfp5nX3-xk6D1-mma0AdLIShgdKxsL2tO1fC1IVR1QnK2oSbbw3NvhLHY1qwDhThFEBbo2-I7brTyQEXV6OPOHTLWhRHFzm1rfH2180kxQEISt-DZq_u83nEh0SuE0Jl860iBHQ4_pNoA_wuKPZsfsYeUKBRwpg-6kX8ceAw-eO9dk9474UVR0E7BEvPYQcoDQ ---
[2023-10-17 20:55:25][DEBUG] : --- DEVICE REQUESTED ---
[2023-10-17 20:55:25][DEBUG] : --- DEVICE ID = local.192.168.1.43 ---
[2023-10-17 20:55:25][ERROR] : Erreur exécution de la commande [Cuisine][Test cuisine][Device Id Set] : An unknown error occurred.
Version beta du 2023-03-21 00:38:14
Merci pour votre aide.
Il semblerait que les dépendances du plugin ne soient pas installées, non ?
OUARZA
Octobre 25, 2023, 11:59
3
Pourtant c’est le cas.
Je viens de supprimer le plugin, je vais refaire ça proprement pour voir.
Je reviens vers toi.
Mathieu
OUARZA
Octobre 25, 2023, 4:17
4
@sbarre35 ,
J’ai réinstallé le plugin en version beta en suivant le tuto.
Les dépendances ont été installées.
J’ai tenté de les réinstaller, mais la date ne change pas…
[2023:10:25 06:03:45]DEBUG[spotify ] BEGIN
[2023:10:25 06:03:45]DEBUG[configRequest ] BEGIN
[2023:10:25 06:03:45]DEBUG[configRequest ] PROTOCOL = HTTPS
[2023:10:25 06:03:45][INFO-][configRequest ] >> https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?action=account&api=jpTi0tpZh7kca2nEJQSayj8ZwvWFnXXXXXXXX1vDEBMq88hJ3GFL3hJ
[2023:10:25 06:03:46]DEBUG[configRequest ] END
[2023:10:25 06:03:46]DEBUG[spotify ] END
[2023:10:25 06:03:46]DEBUG[configResponse ] BEGIN
[2023:10:25 06:03:46][INFO-][configRequest ] << {"state":"ok","result":{"apikey":"jpTi0tpZh7kca2nEJQSXXXXXXXGXyb8bJAaX1vDEBMq88hJ3GFL3hJ","commands":"[]","itemcallback":"https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=item&id=#ID#&item_id=#ITEM_ID#&item_album=#ITEM_ALBUM#&item_title=#ITEM_TITLE#&item_artist=#ITEM_ARTIST#&item_image=#ITEM_IMAGE#&context_type=#CONTEXT_TYPE#&context_uri=#CONTEXT_URI#","devicecallback":"https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=device&id=#ID#&device_id=#DEVICE_ID#&device_name=#DEVICE_NAME#&device_type=#DEVICE_TYPE#&device_volume=#DEVICE_VOLUME#&device_is_active=#DEVICE_IS_ACTIVE#&device_is_restricted=#DEVICE_IS_RESTRICTED#","playlistcallback":"https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=playlist&id=#ID#&playlist_id=#PLAYLIST_ID#&playlist_name=#PLAYLIST_NAME#","shufflecallback":"https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&id=#ID#&state=#STATE#&action=shuffle","refreshcallback":"https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&i=#I#&id=#ID#&action=refresh_token"}}
[2023:10:25 06:03:46][INFO-][configResponse ] API KEY = jpTi0tpZh7kca2nEJQSayj8ZwvWFnxXXXXX1vDEBMq88hJ3GFL3hJ
[2023:10:25 06:03:46][INFO-][configResponse ] COMMANDS = []
[2023:10:25 06:03:46][INFO-][configResponse ] ITEM CALLBACK = https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=item&id=#ID#&item_id=#ITEM_ID#&item_album=#ITEM_ALBUM#&item_title=#ITEM_TITLE#&item_artist=#ITEM_ARTIST#&item_image=#ITEM_IMAGE#&context_type=#CONTEXT_TYPE#&context_uri=#CONTEXT_URI#
[2023:10:25 06:03:46][INFO-][configResponse ] DEVICE CALLBACK = https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=device&id=#ID#&device_id=#DEVICE_ID#&device_name=#DEVICE_NAME#&device_type=#DEVICE_TYPE#&device_volume=#DEVICE_VOLUME#&device_is_active=#DEVICE_IS_ACTIVE#&device_is_restricted=#DEVICE_IS_RESTRICTED#
[2023:10:25 06:03:46][INFO-][configResponse ] PLAYLIST CALLBACK = https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=playlist&id=#ID#&playlist_id=#PLAYLIST_ID#&playlist_name=#PLAYLIST_NAME#
[2023:10:25 06:03:46][INFO-][configResponse ] SHUFFLE CALLBACK = https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&id=#ID#&state=#STATE#&action=shuffle
[2023:10:25 06:03:46][INFO-][configResponse ] REFRESH CALLBACK = https://XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&i=#I#&id=#ID#&action=refresh_token
[2023:10:25 06:03:46]DEBUG[configResponse ] END
[2023:10:25 06:03:46]DEBUG[spotifyLoop ] ========================================== LOOP ================================================================
[2023:10:25 06:03:47]DEBUG[spotifyLoop ] ========================================== LOOP ================================================================
[2023:10:25 06:03:48]DEBUG[spotifyLoop ] ========================================== LOOP ================================================================
L’heure des logs est un peu déroutant (6h au ieu de 18h).
[2023-10-25 13:58:40]INFO : Début d'activation du plugin
[2023-10-25 13:58:41]INFO : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2023-10-25 13:58:41]DEBUG : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=spotify function=install callInstallFunction=1
[2023-10-25 18:02:47]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:02:47]DEBUG : --- DEPENDANCY INSTALL ---
[2023-10-25 18:02:48]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:02:53]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:02:58]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:03:04]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:03:10]DEBUG : --- DEPENDANCY INFO ---
[2023-10-25 18:03:43]DEBUG : --- DAEMON STOP ---
[2023-10-25 18:03:43]DEBUG : --- DAEMON INFO {"log":"spotify_daemon","launchable":"ok","state":"ok"}---
[2023-10-25 18:03:43]DEBUG : --- DAEMON FIRST STOP ---
[2023-10-25 18:03:43]DEBUG : --- CMD = sudo kill $(ps aux | grep "spotify.js" | awk '{print $2}') ---
[2023-10-25 18:03:43]DEBUG : --- RESULT = ---
[2023-10-25 18:03:44]DEBUG : --- DAEMON INFO {"log":"spotify_daemon","launchable":"ok","state":"nok"}---
[2023-10-25 18:03:44]DEBUG : --- DAEMON STOP SUCCEED ---
[2023-10-25 18:03:44]DEBUG : --- DAEMON START ---
[2023-10-25 18:03:44]DEBUG : --- DAEMON info {"log":"spotify_daemon","launchable":"ok","state":"nok"}---
[2023-10-25 18:03:44]DEBUG : --- PROTOCOL = HTTPS ---
[2023-10-25 18:03:44]DEBUG : --- KEY = jpTi0tpZh7kca2nEJQSayj8XXXXXXXXXbJAaX1vDEBMq88hJ3GFL3hJ ---
[2023-10-25 18:03:44]DEBUG : --- NET = XXXXXX.synology.me ---
[2023-10-25 18:03:44]DEBUG : --- URL = XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?action=account&api=jpTi0tpZh7kca2nEJQSayj8XXXXXXXXXXXXXvDEBMq88hJ3GFL3hJ ---
[2023-10-25 18:03:44]DEBUG : --- LOG LEVEL = 100 ---
[2023-10-25 18:03:44]DEBUG : --- LOG = /var/www/html/core/class/../../log/spotify_daemon ---
[2023-10-25 18:03:44]DEBUG : --- CMD = sudo nice -n 19 nodejs "/var/www/html/plugins/spotify/ressources/spotify.js" "XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?action=account&api=jpTi0tpZh7kca2nEJQSayj8ZwvWFnxpFslTsGXyb8bJAaX1vDEBMq88hJ3GFL3hJ" "100" "HTTPS" > "/var/www/html/core/class/../../log/spotify_daemon" 2>&1 & ---
[2023-10-25 18:03:44]DEBUG : --- RESULT = ---
[2023-10-25 18:03:44]DEBUG : --- DAEMON info {"log":"spotify_daemon","launchable":"ok","state":"ok"}---
[2023-10-25 18:03:44]DEBUG : --- DAEMON START SUCCEED ---
[2023-10-25 18:03:46]DEBUG : %%%%%%%%%%%%%%%% BEGIN ACCOUNT %%%%%%%%%%%%%%%%
[2023-10-25 18:03:46]DEBUG : --- APIKEY jpTi0tpZh7kca2XXXXXxpFslTsGXyb8bJAaX1vDEBMq88hJ3GFL3hJ ---
[2023-10-25 18:03:46]DEBUG : --- CLIENT ID 8ed4f692bXXXXXf4ab0a7af3b ---
[2023-10-25 18:03:46]DEBUG : --- CLIENT SECRET 641e52fXXXXb7a0d3d627ed1b46 ---
[2023-10-25 18:03:46]DEBUG : --- PROTOCOL HTTPS ---
[2023-10-25 18:03:46]DEBUG : --- URL XXXXXX.synology.me ---
[2023-10-25 18:03:46]DEBUG : --- ITEM CALLBACK XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=item&id=#ID#&item_id=#ITEM_ID#&item_album=#ITEM_ALBUM#&item_title=#ITEM_TITLE#&item_artist=#ITEM_ARTIST#&item_image=#ITEM_IMAGE#&context_type=#CONTEXT_TYPE#&context_uri=#CONTEXT_URI# ---
[2023-10-25 18:03:46]DEBUG : --- DEVICE CALLBACK XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=device&id=#ID#&device_id=#DEVICE_ID#&device_name=#DEVICE_NAME#&device_type=#DEVICE_TYPE#&device_volume=#DEVICE_VOLUME#&device_is_active=#DEVICE_IS_ACTIVE#&device_is_restricted=#DEVICE_IS_RESTRICTED# ---
[2023-10-25 18:03:46]DEBUG : --- PLAYLIST CALLBACK XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&type=spotify&action=playlist&id=#ID#&playlist_id=#PLAYLIST_ID#&playlist_name=#PLAYLIST_NAME# ---
[2023-10-25 18:03:46]DEBUG : --- SHUFFLE CALLBACK XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&id=#ID#&state=#STATE#&action=shuffle ---
[2023-10-25 18:03:46]DEBUG : --- SHUFFLE CALLBACK XXXXXX.synology.me/plugins/spotify/core/ajax/spotify.ajax.php?api=#APIKEY#&i=#I#&id=#ID#&action=refresh_token ---
[2023-10-25 18:03:46]DEBUG : --- LENGTH 0 ---
[2023-10-25 18:03:46]DEBUG : --- COMMANDS [] ---
[2023-10-25 18:03:46]DEBUG : %%%%%%%%%%%%%%%% END ACCOUNT %%%%%%%%%%%%%%%%
[2023-10-25 18:05:24]DEBUG : %%%%%%%%%%%%%%%% BEGIN GET AUTHORIZE URL %%%%%%%%%%%%%%%%
[2023-10-25 18:05:24]DEBUG : --- CALLBACK XXXXXX.synology.me/index.php?v=d&m=spotify&p=spotify ---
[2023-10-25 18:05:24]DEBUG : --- CLIENT ID 8ed4f69XXXXXXXX1905f4ab0a7af3b ---
[2023-10-25 18:05:24]DEBUG : --- CLIENT SECRET 641e52XXXXXXXXXXX45ecb7a0d3d627ed1b46 ---
[2023-10-25 18:05:24]DEBUG : --- AUTHORIZE URL https://accounts.spotify.com/authorize?client_id=8ed4f692beXXXXXXXXXXab0a7af3b&redirect_uri=https%3A%2F%2FXXXXXXXXXXXXXX.synology.me%2Findex.php%3Fv%3Dd%26m%3Dspotify%26p%3Dspotify&response_type=code&scope=user-library-modify+user-library-read+app-remote-control+streaming+playlist-read-private+playlist-read-collaborative+playlist-modify-public+playlist-modify-private+user-follow-modify+user-follow-read+user-read-recently-played+user-top-read+user-read-email+user-read-private+user-read-currently-playing+user-read-playback-state+user-modify-playback-state ---
[2023-10-25 18:05:24]DEBUG : %%%%%%%%%%%%%%%% END GET AUTHORIZE URL %%%%%%%%%%%%%%%%
[2023-10-25 18:05:24]DEBUG : ### CODE AQCniNpViqXwUoeY_xue-Vfxglgg3ttn3Or7vChG4Bxw8UFX1tTLXXXXXXXXX7aL14Wd4uRYjafcpo47dOjjI6VA6zv5-0j-5bKOvBMzXoa8wqiy3yJImeQYvuAg0fdlGpK4DhmHZjUFjyaEYGh1gKzlazdsJsf8fYzO7rwbOgKYkRHKecOQoqOUuzdZRDPPqmsgGnvEsbuW1MzNE3DhoFlV3p9C06NZE3Mz1QfnrJr6vQl4GekC__Tpi6GaDYQVQq7LYIjC0uDZ2vBHCOawOXu_9I10lnX0Z8uJ5VJ43e_0EQi5gzW4x9kjeOSMfDQwTjW-fOZlcHdT7q1u6TRpDfM70gDpCdf_MRkvU0Non9VyJTNXux10WGFtzAP9VsRhEbE-BawI9QC6j7aIzAfneJoTknXVxVH0LwVZWaKv-ohi4Yb4vQx4HuqOe9elVJhkfYO68Bjo2UvuTqx6u6LpOok5juA7Mkzd9mAufAghWI-qoUKYc0TjOvZ3SJRDubeb1Xx7RNxcQtHYRbgcgzHZUwVpE60cfKInEDovqtSzaVyNvf1Sdk-jxalWd84MW5hhdLkk7lTAAWOBoU7758EelnfB82Ho3twLWwGuaeKXCw-WHfwUT4R8GknxwP8jrrqJDv1aLYUnAgARxxtv--SyNqhJXLZ2GhLxTIFLjtDoYbGonZtFsIMlInw3KH_o2SraZeg ###
[2023-10-25 18:05:25]DEBUG : %%%%%%%%%%%%%%%% BEGIN GET TOKEN %%%%%%%%%%%%%%%%
[2023-10-25 18:05:25]DEBUG : --- CALLBACK XXXXXX.synology.me/index.php?v=d&m=spotify&p=spotify ---
[2023-10-25 18:05:25]DEBUG : --- CLIENT ID 8ed4f692beb146XXXXXXXXXXab0a7af3b ---
[2023-10-25 18:05:25]DEBUG : --- CLIENT SECRET 641e52febXXXXXXXXXXXXXa0d3d627ed1b46 ---
[2023-10-25 18:05:25]DEBUG : --- CODE AQCniNpViqXwUoeY_xue-Vfxglgg3ttn3Or7vChG4XXXXXXXXXXXXXXXXXXXXXo47dOjjI6VA6zv5-0j-5bKOvBMzXoa8wqiy3yJImeQYvuAg0fdlGpK4DhmHZjUFjyaEYGh1gKzlazdsJsf8fYzO7rwbOgKYkRHKecOQoqOUuzdZRDPPqmsgGnvEsbuW1MzNE3DhoFlV3p9C06NZE3Mz1QfnrJr6vQl4GekC__Tpi6GaDYQVQq7LYIjC0uDZ2vBHCOawOXu_9I10lnX0Z8uJ5VJ43e_0EQi5gzW4x9kjeOSMfDQwTjW-fOZlcHdT7q1u6TRpDfM70gDpCdf_MRkvU0Non9VyJTNXux10WGFtzAP9VsRhEbE-BawI9QC6j7aIzAfneJoTknXVxVH0LwVZWaKv-ohi4Yb4vQx4HuqOe9elVJhkfYO68Bjo2UvuTqx6u6LpOok5juA7Mkzd9mAufAghWI-qoUKYc0TjOvZ3SJRDubeb1Xx7RNxcQtHYRbgcgzHZUwVpE60cfKInEDovqtSzaVyNvf1Sdk-jxalWd84MW5hhdLkk7lTAAWOBoU7758EelnfB82Ho3twLWwGuaeKXCw-WHfwUT4R8GknxwP8jrrqJDv1aLYUnAgARxxtv--SyNqhJXLZ2GhLxTIFLjtDoYbGonZtFsIMlInw3KH_o2SraZeg ---
[2023-10-25 18:05:25]DEBUG : --- ACCESS TOKEN BQA9BTkqZG9YXXXXXXXXXX0rhFAoWSpkr3gpqpEGQKR7fKh5_ZS0zIVK9rCVym0Q2dWHd9GhJJoqP2zM7ViBa_wbBMeyGZtc-Ju0GAxutdCekQI3pcPwqURlPi4SfKGKdiD_AMt227waIUlXbHyNHcL4CaBSwjgIFJi32wRKZfRDeg1PLhZxs7VD0vFKhtdUt4jJJCHtPDWt_WJiRnaYQ7d2tcczLEBfrWcU005CyUh6HUdSM4EN6LarnaCgdX-BieyW8ea_ROEQhnXz4qlwjNObfPhpWNRsX4_w ---
[2023-10-25 18:05:25]DEBUG : --- REFRESH TOKEN AQB_pWlwN5PpLU6vyI9XXXXXXXXXXXXXX5Q4SVbZ2vveUgNGGue8q8TELyl_7xyP-9TifuuTE7nRrfZ5n6pOKDcsshFdgnIHdkrg2h01isqo3lPj-M ---
[2023-10-25 18:05:25]DEBUG : --- EXPIRE 1698253525 ---
[2023-10-25 18:05:25]DEBUG : %%%%%%%%%%%%%%%% END GET TOKEN %%%%%%%%%%%%%%%%
Mathieu
OUARZA
Octobre 25, 2023, 7:21
5
@sbarre35 ,
Je viens de trouver le problème…
J’ai des playlist avec des emojis dans le titre :
Je ne sais pas si tu peux faire une correction ou pas.
Mathieu
les emojis ne posent normalement aucun pb, peux-tu préciser ?
OUARZA
Octobre 26, 2023, 6:18
7
@sbarre35 ,
J’ai du supprimer les 3 playlist avec Emoji pour que je puisse avoir mes playlist dans le menu déroulant [Playlist Id Set].
Je viens de remettre une paylist avec Emoji en favoris et j’ai relancé le Daemon.
[2023-10-26 08:11:50][DEBUG] : %%%%%%%%%%%%%%%% BEGIN PLAYLIST (1898) %%%%%%%%%%%%%%%%
[2023-10-26 08:11:50][DEBUG] : --- ITEM IMAGE /plugins/spotify/plugin_info/spotify.png ---
[2023-10-26 08:11:50][DEBUG] : --- PLAYLIST ID spotify:playlist:32HiyEXKoCYkxazhRNs1Mn|spotify:playlist:76MmphciRzIy63lYPd80Vl|spotify:playlist:37i9dQZF1DWY1vQTCT1CCD|spotify:playlist:07I9gbRdNiJiyUrhG9b5Fy|spotify:playlist:1eWtVp1Mcqvxcll2Qy2L3l|spotify:playlist:4IaZuNZ4qlE5EaVENrKLfh|spotify:playlist:37i9dQZF1DWTvNyxOwkztu|spotify:playlist:37i9dQZF1DXdrln2UyZD7F|spotify:playlist:37i9dQZF1DXbsWQD03AVcA|spotify:playlist:37i9dQZF1DWYRdd9noPgqB|spotify:playlist:6vDGVr652ztNWKZuHvsFvx|spotify:playlist:37i9dQZF1E4ksNjPITHshx|spotify:playlist:37i9dQZF1DXcSPhLAnCjoM|spotify:playlist:37i9dQZF1DX4WYpdgoIcn6|spotify:playlist:37i9dQZF1DWY6UWUOwj4BO|spotify:playlist:37i9dQZF1DX39mId53VASc|spotify:playlist:7oBeEkujcRybm7dCAUAIhG|spotify:playlist:1vws6UZEInsJ7iNvu6EslW|spotify:playlist:37i9dQZF1DXaXB8fQg7xif|spotify:playlist:37i9dQZF1DX915ogFalrko ---
[2023-10-26 08:11:50][DEBUG] : --- CONTEXT TYPE ---
[2023-10-26 08:11:50][DEBUG] : --- CONTEXT URI ---
[2023-10-26 08:11:50][DEBUG] : --- PLAYLIST ID ---
[2023-10-26 08:11:50][DEBUG] : --- PLAYLIST NAME Chill, Relax 💆 Playlist Electro Chill 2023 / Chillout Lounge Music|Relaxation|Temps calme|Hypnose pour dormir|Jean-Jacques Goldman|Tabata Music 2023|Chillout Lounge|La vie est belle|Travailler en musique|Feel Good|Deep House 2023|Radio RIOPY|Grand Hit|Hits chill|Hit Acoustique|Motivation pour le sport|Blind Test : Tubes Incontournables | Blindtest Soirée | Quizz Musical l Hits all time|Classical Crossover|Dance Party|Dîner entre amis ---
[2023-10-26 08:11:50][DEBUG] : --- LENGTH 20 ---
[2023-10-26 08:11:50][DEBUG] : --- LIST spotify:playlist:32HiyEXKoCYkxazhRNs1Mn|Chill, Relax 💆 Playlist Electro Chill 2023 / Chillout Lounge Music;spotify:playlist:76MmphciRzIy63lYPd80Vl|Relaxation;spotify:playlist:37i9dQZF1DWY1vQTCT1CCD|Temps calme;spotify:playlist:07I9gbRdNiJiyUrhG9b5Fy|Hypnose pour dormir;spotify:playlist:1eWtVp1Mcqvxcll2Qy2L3l|Jean-Jacques Goldman;spotify:playlist:4IaZuNZ4qlE5EaVENrKLfh|Tabata Music 2023;spotify:playlist:37i9dQZF1DWTvNyxOwkztu|Chillout Lounge;spotify:playlist:37i9dQZF1DXdrln2UyZD7F|La vie est belle;spotify:playlist:37i9dQZF1DXbsWQD03AVcA|Travailler en musique;spotify:playlist:37i9dQZF1DWYRdd9noPgqB|Feel Good;spotify:playlist:6vDGVr652ztNWKZuHvsFvx|Deep House 2023;spotify:playlist:37i9dQZF1E4ksNjPITHshx|Radio RIOPY;spotify:playlist:37i9dQZF1DXcSPhLAnCjoM|Grand Hit;spotify:playlist:37i9dQZF1DX4WYpdgoIcn6|Hits chill;spotify:playlist:37i9dQZF1DWY6UWUOwj4BO|Hit Acoustique;spotify:playlist:37i9dQZF1DX39mId53VASc|Motivation pour le sport;spotify:playlist:7oBeEkujcRybm7dCAUAIhG|Blind Test : Tubes Incontournables ;spotify:playlist:1vws6UZEInsJ7iNvu6EslW| Blindtest Soirée ;spotify:playlist:37i9dQZF1DXaXB8fQg7xif| Quizz Musical l Hits all time;spotify:playlist:37i9dQZF1DX915ogFalrko|Classical Crossover ---
[2023-10-26 08:11:50][DEBUG] : %%%%%%%%%%%%%%%% END DEVICE (1898) %%%%%%%%%%%%%%%%
Chill Hits est une autre playlist.
Et j’ai un autre souci, lorsque je sélectionne mon Google Home puis une paylist, cela fonctionne mais j’ai toujours une erreur dans les logs et les notifications.
[2023-10-26 08:18:42]DEBUG : --- SPOTIFY OK --- GET MY DEVICE ---
[2023-10-26 08:18:42]DEBUG : --- SPOTIFY OK --- WAIT AND SEE ---
[2023-10-26 08:18:42]DEBUG : --- Cuisine ? 145fc13c373dcdcf12d2bd57f8cd33fcd4a00b9a / Web Player (Chrome) ---
[2023-10-26 08:18:42]DEBUG : %%% FALSE %%% 145fc13c373dcdcf12d2bd57f8cd33fcd4a00b9a / Web Player (Chrome) %%%
[2023-10-26 08:18:42]DEBUG : --- Cuisine ? 25bd8af958d310bda91c0dc33bcc7cb7d48ef259 / Web Player (Chrome) ---
[2023-10-26 08:18:42]DEBUG : %%% FALSE %%% 25bd8af958d310bda91c0dc33bcc7cb7d48ef259 / Web Player (Chrome) %%%
[2023-10-26 08:18:42]DEBUG : --- Cuisine ? 1c2800d2f280676b14d5c37c1f37b3e3 / Cuisine ---
[2023-10-26 08:18:42]DEBUG : %%% TRUE %%% 1c2800d2f280676b14d5c37c1f37b3e3 / Cuisine %%%
[2023-10-26 08:18:43]DEBUG : --- SPOTIFY OK --- END ---
[2023-10-26 08:18:43]ERROR : Erreur exécution de la commande [Cuisine][Cuisine spotify][Device Id Set] : Player command failed: No active device found
Et une suggestion de développement, avoir la possibilité de retrouver les artistes en favoris Zazie | Spotify et/ou d’avoir la possibilité de mettre manuellement dans une commande de scenario l’id de la playlist, de l’artiste, d’un album…
Thrive - Album by RIOPY | Spotify
Mathieu
OUARZA
Novembre 26, 2023, 1:17
8
Sans savoir pourquoi, j’ai de nouveau un problème de « An unknown error occured ».
Dans ls logs de spotify_daemon, j’ai ça.
[2023:11:26 01:14:35]ERROR[statusPollingRequest] PROCESS PLAYBACK STATE(1898) = 429
[2023:11:26 01:14:35]ERROR[devicePollingRequest] PROCESS DEVICE(1898) = 429
Un truc étrange aussi, quand je lance l’installation des dépendances, la date et l’heure ne changent pas.
0328|[2023-11-26 16:15:13]ERROR : Attention : l'installation des dépendances a dépassé le temps maximum autorisé : 60min
0329|[2023-11-26 16:15:13]DEBUG : --- DEPENDANCY INFO ---
0330|[2023-11-26 16:15:17]DEBUG : --- DEPENDANCY INFO ---
0331|[2023-11-26 16:15:18]DEBUG : --- DEPENDANCY INFO ---
0332|[2023-11-26 16:15:22]DEBUG : --- DEPENDANCY INFO ---
0333|[2023-11-26 16:15:23]DEBUG : --- DEPENDANCY INFO ---
0334|[2023-11-26 16:15:28]DEBUG : --- DEPENDANCY INFO ---
0335|[2023-11-26 16:16:55]DEBUG : --- DEPENDANCY INFO ---
0336|[2023-11-26 16:16:55]DEBUG : --- DEPENDANCY INSTALL ---
0337|[2023-11-26 16:16:55]DEBUG : --- DEPENDANCY INFO ---
0338|[2023-11-26 16:16:55]DEBUG : --- DEPENDANCY INFO ---
0339|[2023-11-26 16:16:56]DEBUG : --- DEPENDANCY INFO ---
0340|[2023-11-26 16:17:00]DEBUG : --- DEPENDANCY INFO ---
0341|[2023-11-26 16:17:02]DEBUG : --- DEPENDANCY INFO ---
0342|[2023-11-26 16:17:04]DEBUG : --- DEPENDANCY INFO ---
0343|[2023-11-26 16:17:07]DEBUG : --- DEPENDANCY INFO ---
0344|[2023-11-26 16:17:08]DEBUG : --- DEPENDANCY INFO ---
0345|[2023-11-26 16:17:09]DEBUG : --- DEPENDANCY INFO ---
0346|[2023-11-26 16:17:12]DEBUG : --- DEPENDANCY INFO ---
0347|[2023-11-26 16:17:14]DEBUG : --- DEPENDANCY INFO ---
0348|[2023-11-26 16:17:15]DEBUG : --- DEPENDANCY INFO ---
0349|[2023-11-26 16:17:18]DEBUG : --- DEPENDANCY INFO ---
0350|[2023-11-26 16:18:18]DEBUG : %%%%%%%%%%%%%%%% BEGIN DEVICE (1898) %%%%%%%%%%%%%%%%
@sbarre35 as-tu une idée ?
Merci par avance.
Mathieu
429 Too Many Requests
Erreur sur les appels des APIs Spotify => regarder dans ta console dev spotify
OUARZA
Décembre 2, 2023, 10:27
11
Hello @sbarre35 ,
Je n’ai pas pu lancer une playlist ce matin.
Erreur exécution de la commande [Maison][Spotify Mathieu][Device Name Set] : An unknown error occurred.
[2023-12-02 09:32:58][DEBUG] : --- EXECUTE device_name_set / {"background":"0","title":"Cuisine","message":""} ---
[2023-12-02 09:32:58][DEBUG] : --- CLIENT ID 8ed4f692XXXXXXXXXXXXab0a7af3b ---
[2023-12-02 09:32:58][DEBUG] : --- CLIENT SECRET 641e5XXXXXXXXXX3d627ed1b46 ---
[2023-12-02 09:32:58][DEBUG] : --- EXPIRATION TIME 1701508168 ---
[2023-12-02 09:32:58][DEBUG] : --- ACCESS TOKEN BQA8AZS0jjXXXXXXXXXwDTB7ADtWy-zxNTxmtpvy9W6lBaih6lA4TkWSxPHXXXXXXXXXXXX5jsP29ws3nkRzbM0Y8m3EHeVeL6IE-ubnujwqoDYJYhACBxVRjIXo55rU7-ayIruiBoD0cLpCAlWPnb15Y0PXXXXXXXXXXXX3NntoyIwUWdeVCcTaPUakhndY295bz2kkVrCmS_pgrWGryjBUTqRykufGpqsSZXXXXXXXXXXW53QcN96wRiU158A ---
[2023-12-02 09:32:58][DEBUG] : --- REFRESH TOKEN AQAYnYWY0jI8pbXXXXXXXXXRV4LRH0mBmW6YfvL-G0znjqC-om0VOqrEus0EHaQzNraSheuXXXXXXXXXATBoaC1IcKnkCpTl-oSPN2uw ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE TOKEN = BQA8AZS0jjKgnx665Ss-jdwDTB7ADtWy-zxNTxmtpvy9W6lBaih6lA4TXXXXXXXXXX4uGZhHlBAjCBHj2J5jsP29ws3nkRzbM0Y8m3EHeVeL6IE-ubnujwqoDYJYhACBxVRjIXo55rU7-ayIruiBoD0cLpCAlWPnb15XXXXXXXXXXX5Xm3NntoyIwUWdeVCcTaPUakhndY295bz2kkVrCmS_pgrWGryjBUTqRykufGpqsXXXXXXXW53QcN96wRiU158A ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE REQUESTED ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE NAME = Cuisine ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE LIST= local.192.168.1.42|Salon;local.192.168.1.43|Cuisine;local.192.168.1.44|Salle de bain ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE PARSE = Salon ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE PARSE = Cuisine ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE FOUND = local.192.168.1.43 ---
[2023-12-02 09:32:58][DEBUG] : --- DEVICE ID = local.192.168.1.43 ---
[2023-12-02 09:32:59][ERROR] : Erreur exécution de la commande [Maison][Spotify Mathieu][Device Name Set] : An unknown error occurred.
[2023-12-02 09:33:00][DEBUG] : --- EXECUTE playlist_name_set / {"background":"0","title":"R\u00e9veil en douceur","message":""} ---
[2023-12-02 09:33:00][DEBUG] : --- CLIENT ID 8ed4f692bebXXXXXXXXXXXXa7af3b ---
[2023-12-02 09:33:00][DEBUG] : --- CLIENT SECRET 641e52feXXXXXXXXXXXXX627ed1b46 ---
[2023-12-02 09:33:00][DEBUG] : --- EXPIRATION TIME 1701508168 ---
[2023-12-02 09:33:00][DEBUG] : --- ACCESS TOKEN BQA8AZS0jjKgnx665Ss-jdwDTB7ADtWy-zxNTxmtpvy9XXXXXXXXXYJYhACBxVRjIXo55rU7-ayIruiBoD0cLpCAlWPnb15Y0PuBNdYNuRubheHd_Ns8LhRJtcXXXXXXXXXXPUakhndY295bz2kkVrCmS_pgrWGryjBUTqRykufGpqsSZugH5Ko7bKsF8X2kQfIvW53QcN96wRiU158A ---
[2023-12-02 09:33:00][DEBUG] : --- REFRESH TOKEN AQAYnYWY0jI8pb3puucdXXXXXXXXXXXXXX0mBmW6YfvL-G0znjqC-om0VOqrEus0EHaQzNraSheunGfXXXXXXXXXC1IcKnkCpTl-oSPN2uw ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST REQUESTED ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST NAME = Réveil en douceur ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Easy Winter ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = On connait la chanson ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Relaxation ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Temps calme ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Hypnose pour dormir ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Jean-Jacques Goldman ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Tabata Music 2023 ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Chillout Lounge ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = La vie est belle ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Travailler en musique ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Feel Good ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Deep House 2023 ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = RIOPY Radio ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Grand Hit ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Chill Hits ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Hit Acoustique ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Motivation pour le sport ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Blind Test : Tubes Incontournables ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Blindtest Soirée ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST PARSE = Quizz Musical l Hits all time ---
[2023-12-02 09:33:00][DEBUG] : --- PLAYLIST ID = ---
Gros correctif aujourd’hui sur les appareils CAST suite à des changements bien entendu non documentés de google et spotify, en espérant que cela résolve vos pbs.
OUARZA
Novembre 1, 2024, 6:03
13
Hello @sbarre35 ,
Je vais tester cela
OUARZA
Novembre 2, 2024, 8:58
14
@sbarre35 j’ai aucune mise à jour, c’est normal ?
J’ai pourtant poussé une màj => 2024-11-01 17:36:10
OUARZA
Novembre 17, 2024, 2:06
16
Hello @sbarre35 ,
C’est bon, j’ai pu mettre à jour.
Pour l’instant ça fonctionne.
Pour combien de temps, je ne sais pas.
Merci beaucoup pour ton aide
Mathieu
