Merci à tous.
C’est une Sensira FTXF25F.
Effectivement, je pense qu’il s’agit d’un problème de délai trop court entre 2 ordres.
Lorsque j’attends par exemple 5 min, tout se passe normalement.
Si j’enchaîne un ordre on/off via un scénario à 1 min d’intervalle, le 2è ordre ne passe pas (càd la clim ne répond pas, ce n’est pas juste un problème de retour d’état).
Voici au besoin les logs debug:
0000|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0001|[2026-06-23 11:15:00] DEBUG {"daikinToMQTT":{"df5efdc7-51a1-4b0e-b808-131d558adf53":{"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":false,"_powerfulMode":false,"_roomTemperature":25,"_outdoorTemperature":30,"_temperatureControl":22.5,"_fanCurrentMode":"fixed","_fanFixed":5,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3},"system":{"bridge":{"rate":{"remainingDay":99}}}}}
0002|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] ID : df5efdc7-51a1-4b0e-b808-131d558adf53 | Value : {"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":false,"_powerfulMode":false,"_roomTemperature":25,"_outdoorTemperature":30,"_temperatureControl":22.5,"_fanCurrentMode":"fixed","_fanFixed":5,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3}
0003|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInCautionState | Value : 0
0004|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionD | Value : 4.7
0005|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionM | Value : 10.3
0006|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionW | Value : 8.6
0007|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInErrorState | Value : 0
0008|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanCurrentMode | Value : "fixed"
0009|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanFixed | Value : 5
0010|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanVertical | Value : "stop"
0011|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionD | Value : 0
0012|[2026-06-23 11:15:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionM | Value : 0
0013|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionW | Value : 0
0014|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isHolidayModeActive | Value : 0
0015|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _operationMode | Value : "cooling"
0016|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _outdoorTemperature | Value : 30
0017|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _powerfulMode | Value : 0
0018|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _roomTemperature | Value : 25
0019|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _onOffMode | Value : 0
0020|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _temperatureControl | Value : 22.5
0021|[2026-06-23 11:15:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInWarningState | Value : 0
0022|[2026-06-23 11:30:00] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0023|[2026-06-23 11:30:00] DEBUG {"daikinToMQTT":{"system":{"bridge":{"rate":{"remainingDay":98}}}}}
0024|[2026-06-23 11:35:37] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_onOffMode":true}
0025|[2026-06-23 11:35:37] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0026|[2026-06-23 11:35:37] DEBUG {"daikinToMQTT":{"system":{"bridge":{"rate":{"remainingDay":97}}}}}
0027|[2026-06-23 11:36:07] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_operationMode":"cooling"}
0028|[2026-06-23 11:36:17] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_fanCurrentMode":"fixed"}
0029|[2026-06-23 11:36:27] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_fanFixed":"1"}
0030|[2026-06-23 11:36:27] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0031|[2026-06-23 11:36:27] DEBUG {"daikinToMQTT":{"system":{"bridge":{"rate":{"remainingDay":96}}}}}
0032|[2026-06-23 11:36:37] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_fanVertical":"stop"}
0033|[2026-06-23 11:36:47] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_temperatureControl":"23"}
0034|[2026-06-23 11:36:47] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0035|[2026-06-23 11:36:47] DEBUG {"daikinToMQTT":{"system":{"bridge":{"rate":{"remainingMinute":18,"remainingDay":95}}}}}
0036|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0037|[2026-06-23 11:39:00] DEBUG {"daikinToMQTT":{"df5efdc7-51a1-4b0e-b808-131d558adf53":{"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":true,"_powerfulMode":false,"_roomTemperature":26,"_outdoorTemperature":31,"_temperatureControl":23,"_fanCurrentMode":"fixed","_fanFixed":1,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3},"system":{"bridge":{"rate":{"remainingMinute":19,"remainingDay":94}}}}}
0038|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] ID : df5efdc7-51a1-4b0e-b808-131d558adf53 | Value : {"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":true,"_powerfulMode":false,"_roomTemperature":26,"_outdoorTemperature":31,"_temperatureControl":23,"_fanCurrentMode":"fixed","_fanFixed":1,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3}
0039|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInCautionState | Value : 0
0040|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionD | Value : 4.7
0041|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionM | Value : 10.3
0042|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionW | Value : 8.6
0043|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInErrorState | Value : 0
0044|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanCurrentMode | Value : "fixed"
0045|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanFixed | Value : 1
0046|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanVertical | Value : "stop"
0047|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionD | Value : 0
0048|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionM | Value : 0
0049|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionW | Value : 0
0050|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isHolidayModeActive | Value : 0
0051|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _operationMode | Value : "cooling"
0052|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _outdoorTemperature | Value : 31
0053|[2026-06-23 11:39:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _powerfulMode | Value : 0
0054|[2026-06-23 11:39:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _roomTemperature | Value : 26
0055|[2026-06-23 11:39:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _onOffMode | Value : 1
0056|[2026-06-23 11:39:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _temperatureControl | Value : 23
0057|[2026-06-23 11:39:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInWarningState | Value : 0
0058|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0059|[2026-06-23 11:45:00] DEBUG {"daikinToMQTT":{"df5efdc7-51a1-4b0e-b808-131d558adf53":{"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":true,"_powerfulMode":false,"_roomTemperature":24,"_outdoorTemperature":32,"_temperatureControl":23,"_fanCurrentMode":"fixed","_fanFixed":1,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3},"system":{"bridge":{"rate":{"remainingDay":93}}}}}
0060|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] ID : df5efdc7-51a1-4b0e-b808-131d558adf53 | Value : {"_device":{"id":"df5efdc7-51a1-4b0e-b808-131d558adf53","name":"Chambre","modelInfo":"BRP069C4x","serialNumber":"0000000015915981","firmwareVersion":"2_3_0","isInErrorState":false,"errorCode":"00-00"},"_isHolidayModeActive":false,"_isInErrorState":false,"_isInWarningState":false,"_isInCautionState":false,"_operationMode":"cooling","_onOffMode":true,"_powerfulMode":false,"_roomTemperature":24,"_outdoorTemperature":32,"_temperatureControl":23,"_fanCurrentMode":"fixed","_fanFixed":1,"_fanVertical":"stop","_heatingConsumptionD":0,"_heatingConsumptionW":0,"_heatingConsumptionM":0,"_coolingConsumptionD":4.7,"_coolingConsumptionW":8.6,"_coolingConsumptionM":10.3}
0061|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInCautionState | Value : 0
0062|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionD | Value : 4.7
0063|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionM | Value : 10.3
0064|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _coolingConsumptionW | Value : 8.6
0065|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInErrorState | Value : 0
0066|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanCurrentMode | Value : "fixed"
0067|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanFixed | Value : 1
0068|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _fanVertical | Value : "stop"
0069|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionD | Value : 0
0070|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionM | Value : 0
0071|[2026-06-23 11:45:00] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _heatingConsumptionW | Value : 0
0072|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isHolidayModeActive | Value : 0
0073|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _operationMode | Value : "cooling"
0074|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _outdoorTemperature | Value : 32
0075|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _powerfulMode | Value : 0
0076|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _roomTemperature | Value : 24
0077|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _onOffMode | Value : 1
0078|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _temperatureControl | Value : 23
0079|[2026-06-23 11:45:01] DEBUG [handleMqttMessageV1] Data Debug => logicalID : _isInWarningState | Value : 0
0080|[2026-06-23 11:47:55] DEBUG [publishMqttValue] Publication Mqtt Valuedf5efdc7-51a1-4b0e-b808-131d558adf53 {"_onOffMode":false}
0081|[2026-06-23 11:47:56] DEBUG [handleMqttMessageV1] Message Mqtt reçu
0082|[2026-06-23 11:47:56] DEBUG {"daikinToMQTT":{"system":{"bridge":{"rate":{"remainingDay":92}}}}}
Encore merci à tous, je vais donc cliquer moins vite
Julien
