suite à un problème eMMc HS, j’ai dû en racheter une auprès de domadoo (ma smart étant hors garantie).
J’ai installé ma dernière sauvegarde et OPEN VPN refuse d’installer les dépendances. J’ai vu dans le forum qu’il fallait le réinstaller, ce que j’ai fait, mais ça ne fonctionne toujours pas.
Je suis bien connecté au market.
Cela fait plusieurs jours que j’essaye mais toujours pareil.
Voici les logs de l’update, a priori un problème d’adresse
Launch install of openvpn
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:3 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:4 http://ftp.uk.debian.org/debian buster-updates InRelease [51.9 kB]
Err:2 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.178.69.128 443]
Ign:5 https://oph.mdrjr.net/meveric all InRelease
Ign:6 https://oph.mdrjr.net/meveric buster InRelease
Err:7 https://oph.mdrjr.net/meveric all Release
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 216.155.132.189 443]
Err:8 https://oph.mdrjr.net/meveric buster Release
Get:9 http://www.deb-multimedia.org buster InRelease [15.8 kB]
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
E: The repository 'https://oph.mdrjr.net/meveric all Release' no longer has a Release file.
E: The repository 'https://oph.mdrjr.net/meveric buster Release' no longer has a Release file.
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libpkcs11-helper1
Suggested packages:
resolvconf openvpn-systemd-resolved
Recommended packages:
easy-rsa
libpkcs11-helper1 openvpn
0 upgraded, 2 newly installed, 0 to remove and 62 not upgraded.
Need to get 464 kB/509 kB of archives.
After this operation, 1,299 kB of additional disk space will be used.
Err:1 http://ftp.uk.debian.org/debian buster/main arm64 openvpn arm64 2.4.7-1
404 Not Found [IP: 2001:1b40:5600:ff80:f8ee::1 80]
E: Failed to fetch http://ftp.uk.debian.org/debian/pool/main/o/openvpn/openvpn_2.4.7-1_arm64.deb 404 Not Found [IP: 2001:1b40:5600:ff80:f8ee::1 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Everything is successfully installed!
et dans opendns_jeedom
sudo: openvpn: command not found
Bonjour @Mips,
merci beaucoup pour votre réponse, mais cela ne corrige pas le problème, même après redémarrage de la smart.
J’ai lancé la commande avec putty une fois connecté en root.
Voici le résultat :
root@Jeedom:~# sudo apt-get update -y
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:3 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:5 http://www.deb-multimedia.org buster InRelease [15.8 kB]
Ign:6 https://oph.mdrjr.net/meveric all InRelease
Ign:7 https://oph.mdrjr.net/meveric buster InRelease
Err:8 https://oph.mdrjr.net/meveric all Release
Err:9 https://oph.mdrjr.net/meveric buster Release
Err:1 https://repo.jeedom.com/odroid stable InRelease
Reading package lists... Done
N: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Version' value from '10.6' to '10.10'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
N: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Version' value from '10.6' to '10.10'
Bonjour @Salvialf,
Merci beaucoup, j’ai pu réinstaller es dépendances et j’ai pu récupérer l’accès à l’extérieur
Il y a malgré tou eu des erreurs et je ne sais pas si cela peut poser problème à l’avenir.
Voici le résultat de la commande
root@Jeedom:~# apt-get --allow-releaseinfo-change update
Get:2 http://www.deb-multimedia.org buster InRelease [15.8 kB]
Get:4 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:5 http://ftp.uk.debian.org/debian buster-updates InRelease [51.9 kB]
Get:7 http://www.deb-multimedia.org buster/main Sources [101 kB]
Get:8 http://www.deb-multimedia.org buster/non-free Sources [3,244 B]
Get:9 http://www.deb-multimedia.org buster/main arm64 Packages [112 kB]
Get:10 http://www.deb-multimedia.org buster/main Translation-en [1,927 B]
Ign:11 https://oph.mdrjr.net/meveric buster InRelease
Err:12 https://oph.mdrjr.net/meveric all Release
Get:13 http://security.debian.org/debian-security buster/updates/non-free Sources [688 B]
Get:14 http://security.debian.org/debian-security buster/updates/main Sources [200 kB]
Get:15 http://security.debian.org/debian-security buster/updates/main arm64 Packages [299 kB]
Get:16 http://security.debian.org/debian-security buster/updates/main Translation-en [160 kB]
Err:17 https://oph.mdrjr.net/meveric buster Release
Get:18 http://ftp.uk.debian.org/debian buster/contrib Sources [42.5 kB]
Get:19 http://ftp.uk.debian.org/debian buster/main Sources [7,836 kB]
Get:20 http://ftp.uk.debian.org/debian buster/non-free Sources [85.7 kB]
Get:21 http://ftp.uk.debian.org/debian buster/main arm64 Packages [7,735 kB]
Get:22 http://ftp.uk.debian.org/debian buster/main Translation-en [5,968 kB]
Get:23 http://ftp.uk.debian.org/debian buster/contrib arm64 Packages [38.4 kB]
Get:24 http://ftp.uk.debian.org/debian buster/contrib Translation-en [44.2 kB]
Get:25 http://ftp.uk.debian.org/debian buster/non-free arm64 Packages [53.8 kB]
Get:26 http://ftp.uk.debian.org/debian buster/non-free Translation-en [88.9 kB]
Get:27 http://ftp.uk.debian.org/debian buster-updates/main Sources.diff/Index [8,608 B]
Ign:27 http://ftp.uk.debian.org/debian buster-updates/main Sources.diff/Index
Get:28 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages.diff/Index [8,608 B]
Get:29 http://ftp.uk.debian.org/debian buster-updates/main Translation-en.diff/Index [5,164 B]
Get:30 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2020-12-24-1401.30.pdiff [286 B]
Get:31 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-01-29-2000.47.pdiff [408 B]
Get:32 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-02-07-1359.56.pdiff [2,291 B]
Get:33 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-04-22-1401.14.pdiff [2,024 B]
Get:34 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-04-23-1401.02.pdiff [1,130 B]
Get:35 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-06-21-1401.46.pdiff [658 B]
Get:36 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-06-23-1401.37.pdiff [4,335 B]
Get:37 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-09-18-2009.26.pdiff [1,099 B]
Get:38 http://ftp.uk.debian.org/debian buster-updates/main arm64 Packages 2021-09-28-1420.03.pdiff [185 B]
Get:39 http://ftp.uk.debian.org/debian buster-updates/main Translation-en 2021-02-07-1359.56.pdiff [1,506 B]
Get:40 http://ftp.uk.debian.org/debian buster-updates/main Translation-en 2021-04-22-1401.14.pdiff [1,408 B]
Get:41 http://ftp.uk.debian.org/debian buster-updates/main Translation-en 2021-06-21-1401.46.pdiff [719 B]
Get:42 http://ftp.uk.debian.org/debian buster-updates/main Translation-en 2021-06-23-1401.37.pdiff [6,585 B]
Get:43 http://ftp.uk.debian.org/debian buster-updates/main Sources [16.6 kB]
N: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
