Depuis la dernière mise à jour du plugin je ne peux plus piloter mes squeeze box via jeedom.
Le deamon monte bien.
Et quand je lance unr musique depuis lms elle remonte dans jeedom.
Par contre dès que je veux lancer une action j’ai ce type d’erreur :
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).652][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).652][DEBUG] : Received command from jeedom : send
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).652][DEBUG] : Sending to device : aa:aa:3e:11:10:dc
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).653][DEBUG] : Connecting to server 192.168.X.X 9000
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).653][DEBUG] : sent login
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).656][DEBUG] : b’HTTP/1.1 400 Bad Request
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : result .1 400 Bad Request
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : sent player count ?
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : b’Date: [Thu, 31 Oct 2019 06:03:39 ](calendar:T7:Thu, 31 Oct 2019 06:03:39 )GMT
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : result Oct 2019 06:03:39 GMT
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : Server connected
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : Executing action
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : Stop {‹ multitarget ›: [None], ‹ datafolder ›: ‹ /var/www/html/plugins/squeezeboxcontrol/core/class/…/…/data ›, ‹ device ›: ‹ aa:aa:3e:11:10:dc ›, ‹ jeedompath ›: ‹ http://192.168.X.X:80 ›, ‹ action ›: ‹ stop ›, ‹ player ›: None}
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][DEBUG] : exception action ‹ NoneType › object has no attribute ‹ stop ›
[[2019-10-31 07:03:39](calendar:T7:2019-10-31 07:03:39).657][ERROR] : Exception on socket : ‹ NoneType › object has no attribute ‹ get_ref ›
Savez vous d’ou ça peut venir ?
Je suis sous jeedom 3.3.34, toutes mes squeezebox fonctionnaient depuis plus d’un an jusqu’à cette mise à jour.
D’avance merci
Jean
