Je tente de mettre à jour mes packages python 2 : PyGObject et pyxdg
Cependant, j’ai des erreurs, pourriez-vous m’aider pour la solution ?
FX
******************Begin of package upgrade type pip2******************
+ sudo pip2 install --force-reinstall --upgrade PyGObject
/usr/local/lib/python2.7/dist-packages/secretstorage/dhcrypto.py:15: CryptographyDeprecationWarning: Python 2 is no longer supported by the Python core team. Support for it is now deprecated in cryptography, and will be removed in the next release.
from cryptography.utils import int_from_bytes
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Collecting PyGObject
Using cached PyGObject-3.36.1.tar.gz (716 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
ERROR: Command errored out with exit status 1:
command: /usr/bin/python /usr/local/lib/python2.7/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hT04pL/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools wheel pycairo
cwd: None
Complete output (59 lines):
Collecting setuptools
Using cached setuptools-44.1.1-py2.py3-none-any.whl (583 kB)
Collecting wheel
Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
Collecting pycairo
Using cached pycairo-1.18.2.tar.gz (200 kB)
Building wheels for collected packages: pycairo
Building wheel for pycairo (setup.py): started
Building wheel for pycairo (setup.py): finished with status 'error'
command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-rgUwHp/pycairo/setup.py'"'"'; __file__='"'"'/tmp/pip-install-rgUwHp/pycairo/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-3Z1Hk3
cwd: /tmp/pip-install-rgUwHp/pycairo/
Complete output (15 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.7
creating build/lib.linux-x86_64-2.7/cairo
copying cairo/__init__.py -> build/lib.linux-x86_64-2.7/cairo
copying cairo/__init__.pyi -> build/lib.linux-x86_64-2.7/cairo
copying cairo/py.typed -> build/lib.linux-x86_64-2.7/cairo
running build_ext
Package cairo was not found in the pkg-config search path.
Perhaps you should add the directory containing `cairo.pc'
to the PKG_CONFIG_PATH environment variable
No package 'cairo' found
Command '['pkg-config', '--print-errors', '--exists', 'cairo >= 1.13.1']' returned non-zero exit status 1
ERROR: Failed building wheel for pycairo
Running setup.py clean for pycairo
Failed to build pycairo
Installing collected packages: setuptools, wheel, pycairo
Running setup.py install for pycairo: started
Running setup.py install for pycairo: finished with status 'error'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-gRTAMC/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-hT04pL/overlay --compile --install-headers /tmp/pip-build-env-hT04pL/overlay/include/python2.7/pycairo
running install
running build
running build_py
creating build
running build_ext
ERROR: Command errored out with exit status 1: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-rgUwHp/pycairo/setup.py'"'"'; __file__='"'"'/tmp/pip-install-rgUwHp/pycairo/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-gRTAMC/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-hT04pL/overlay --compile --install-headers /tmp/pip-build-env-hT04pL/overlay/include/python2.7/pycairo Check the logs for full command output.
ERROR: Command errored out with exit status 1: /usr/bin/python /usr/local/lib/python2.7/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hT04pL/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools wheel pycairo Check the logs for full command output.
+ sudo pip2 install --force-reinstall --upgrade pyxdg
Collecting pyxdg
Using cached pyxdg-0.28-py2.py3-none-any.whl (49 kB)
Installing collected packages: pyxdg
Attempting uninstall: pyxdg
Found existing installation: pyxdg 0.25
ERROR: Cannot uninstall 'pyxdg'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
saisissez ou collez du code ici
