J’essaye d’installer le plugin ZigbeLinker.
Je suis sous Synology docker.
Je choisi l’installation complète pour que tout soit en local sur Jeedom.
Je sélectionne l’adaptateur conbee2.
Mais lorsque ej sauvegarde et relance les dépendances voici le message que j’obtiens dans démon:
Vérifiez l’installation des dépendances de la partie Mqtt client
Voila le log que j’obtiens:
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://phoscon.de/apt/deconz buster InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
git is already the newest version (1:2.20.1-2+deb10u3).
make is already the newest version (4.2.1-1.2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
##### Install or update NodeJs
NodeJs 14 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
Running in chroot, ignoring request: stop
mosquitto is already the newest version (1.5.7-1+deb10u1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
Removed /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service.
Running in chroot, ignoring request: daemon-reload
Running in chroot, ignoring request: reset-failed
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
mv: cannot stat '/opt/zigbee2mqtt/data/database.db': No such file or directory
mv: cannot stat '/opt/zigbee2mqtt/data/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db': No such file or directory
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service → /etc/systemd/system/zigbee2mqtt.service.
# END #
Starting Apache httpd web server: apache2.
J’ai l’impression que ça vient des lignes Running in chroot.
Pour info complémentaire, les fichiers « manquants », j’ai essayé de les créer à la manuelle. Les lignes concernant les fichiers disparaissent car Ok, par contre les autres sont toujours présentes et l’erreur persiste: Vérifiez l’installation des dépendances de la partie Mqtt client
Avez vous une idée ?
