J’ai installé le plugin Zigbee avec la clef EZSP (Elelabs).
J’ai un problème avec une sortie de câble Legrand. Celle-ci ne m’envoie pas la valeur de puissance (pas de rafraichissement). J’ai réinitialisé le module plusieurs fois… Sans effet.
Le module fonctionne sous Deconz avec une clé ConBee II
D’autres ont-ils-déjà rencontré ce problème ?
Ci-joint le json :
[details=« Résumé »]
"ieee": "00:04:74:00:00:0e:f0:f1",
"nwk": 8419,
"status": 2,
"lqi": "124",
"rssi": "-69",
"last_seen": "1619466565.334584",
"node_descriptor": "11:40:8e:21:10:59:3f:00:00:2a:3f:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1,
"profile_id": 260,
"manufacturer": " Legrand",
"model": " Cable outlet",
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 64513,
"name": "Manufacturer Specific",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 2
"id": 1,
"name": "app_version",
"value": 0
"id": 2,
"name": "stack_version",
"value": 66
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": " Legrand"
"id": 5,
"name": "model",
"value": " Cable outlet"
"id": 6,
"name": "date_code",
"value": " "
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "0008"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 5,
"name": "Scenes",
"attributes": []
"id": 64513,
"attributes": []
"id": 2820,
"name": "Electrical Measurement",
"attributes": [
"id": 1291,
"name": "active_power",
"value": 0
"id": 64576,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"byte1": 17,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4129,
"maximum_buffer_size": 89,
"maximum_incoming_transfer_size": 63,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 63,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 1,
"input_clusters": [
0,
3,
4,
6,
5,
64513,
2820,
64576
0,
64513,
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
