J’avais tenté d’installer theengs-gateway en direct et j’avais eu des erreurs et c’est pour cela que je suis passé par snap et la je n’ai pas eu de soucis.
Voici les erreurs en lançant l’installation manuellement avec pip :
pi@raspberrypi:~ $ sudo pip install TheengsGateway
Collecting TheengsGateway
Using cached TheengsGateway-1.1.0.tar.gz (26 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: paho-mqtt>=1.6.1 in /usr/local/lib/python3.7/dist-packages (from TheengsGateway) (1.6.1)
Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.7/dist-packages (from TheengsGateway) (1.7.0)
Collecting bleak>=0.19.0
Using cached bleak-0.20.2-py3-none-any.whl (135 kB)
Collecting bluetooth-numbers<2.0,>=1.0
Using cached bluetooth_numbers-1.1.1-py3-none-any.whl (474 kB)
Collecting bluetooth-clocks<1.0
Using cached bluetooth_clocks-0.1.2-py3-none-any.whl (19 kB)
Collecting TheengsDecoder>=1.5.0
Using cached TheengsDecoder-1.5.7.tar.gz (131 kB)
Installing build dependencies ... error
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [159 lines of output]
Collecting setuptools
Using cached setuptools-68.0.0-py3-none-any.whl (804 kB)
Collecting wheel
Using cached wheel-0.41.2-py3-none-any.whl (64 kB)
Collecting scikit-build
Using cached scikit_build-0.17.6-py3-none-any.whl (84 kB)
Collecting cmake
Using cached cmake-3.27.6.tar.gz (35 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting ninja
Using cached ninja-1.11.1.1.tar.gz (132 kB)
Collecting typing-extensions>=3.7
Using cached typing_extensions-4.7.1-py3-none-any.whl (33 kB)
Collecting packaging
Using cached packaging-23.2-py3-none-any.whl (53 kB)
Collecting distro
Using cached distro-1.8.0-py3-none-any.whl (20 kB)
Collecting tomli
Using cached tomli-2.0.1-py3-none-any.whl (12 kB)
Building wheels for collected packages: cmake, ninja
Building wheel for cmake (pyproject.toml): started
Building wheel for cmake (pyproject.toml): finished with status 'error'
× Building wheel for cmake (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [33 lines of output]
File "/tmp/pip-build-env-i5b_9_ck/overlay/lib/python3.7/site-packages/skbuild/setuptools_wrap.py", line 645, in setup
cmkr = cmaker.CMaker(cmake_executable)
File "/tmp/pip-build-env-i5b_9_ck/overlay/lib/python3.7/site-packages/skbuild/cmaker.py", line 148, in __init__
self.cmake_version = get_cmake_version(self.cmake_executable)
File "/tmp/pip-build-env-i5b_9_ck/overlay/lib/python3.7/site-packages/skbuild/cmaker.py", line 105, in get_cmake_version
raise SKBuildError(msg) from err
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cmake:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) If on Linux, with glibc < 2.12, you can set PIP_ONLY_BINARY=cmake in
order to retrieve the last manylinux1 compatible wheel.
3) If on Linux, with glibc < 2.12, you can cap "cmake<3.23" in your
requirements in order to retrieve the last manylinux1 compatible wheel.
4) Open an issue with the debug information that follows at
https://github.com/scikit-build/cmake-python-distributions/issues
Python: 3.7.3
platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
glibc: glibc 2.28
machine: armv7l
bits: 32
pip: 22.2.2
setuptools: 65.4.0
scikit-build: 0.17.6
PEP517_BUILD_BACKEND=setuptools.build_meta
Problem with the CMake installation, aborting build. CMake executable is cmake
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cmake
Building wheel for ninja (pyproject.toml): started
Building wheel for ninja (pyproject.toml): finished with status 'error'
× Building wheel for ninja (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [13 lines of output]
/tmp/pip-build-env-72np7h9_/overlay/lib/python3.7/site-packages/setuptools_scm/git.py:295: UserWarning: git archive did not support describe output
warnings.warn("git archive did not support describe output")
/tmp/pip-build-env-72np7h9_/overlay/lib/python3.7/site-packages/setuptools_scm/git.py:312: UserWarning: unexported git archival found
warnings.warn("unexported git archival found")
File "/tmp/pip-build-env-72np7h9_/overlay/lib/python3.7/site-packages/skbuild/setuptools_wrap.py", line 645, in setup
File "/tmp/pip-build-env-72np7h9_/overlay/lib/python3.7/site-packages/skbuild/cmaker.py", line 148, in __init__
File "/tmp/pip-build-env-72np7h9_/overlay/lib/python3.7/site-packages/skbuild/cmaker.py", line 105, in get_cmake_version
[end of output]
ERROR: Failed building wheel for ninja
Failed to build cmake ninja
ERROR: Could not build wheels for cmake, ninja, which is required to install pyproject.toml-based projects
--- Logging error ---
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 177, in emit
self.console.print(renderable, overflow="ignore", crop=False, style=style)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1673, in print
extend(render(renderable, render_options))
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1305, in render
for render_output in iter_render:
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 134, in __rich_console__
for line in lines:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/segment.py", line 249, in split_lines
for segment in segments:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1283, in render
renderable = rich_cast(renderable)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/protocol.py", line 36, in rich_cast
renderable = cast_method()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 130, in __rich__
pip_cmd = get_best_invocation_for_this_pip()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/entrypoints.py", line 60, in get_best_invocation_for_this_pip
os.path.join(binary_prefix, exe_name),
File "/usr/lib/python3.7/genericpath.py", line 97, in samefile
s2 = os.stat(f2)
FileNotFoundError: [Errno 2] Aucun fichier ou dossier de ce type: '/usr/bin/pip3.7'
Call stack:
File "/usr/local/lib/python3.7/dist-packages/pip/__pip-runner__.py", line 36, in <module>
runpy.run_module("pip", run_name="__main__", alter_sys=True)
File "/usr/lib/python3.7/runpy.py", line 205, in run_module
return _run_module_code(code, init_globals, run_name, mod_spec)
File "/usr/lib/python3.7/runpy.py", line 96, in _run_module_code
mod_name, mod_spec, pkg_name, script_name)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.7/dist-packages/pip/__main__.py", line 31, in <module>
sys.exit(_main())
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/req_command.py", line 190, in handle_pip_version_check
pip_self_version_check(session, options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 236, in pip_self_version_check
logger.warning("[present-rich] %s", upgrade_prompt)
File "/usr/lib/python3.7/logging/__init__.py", line 1395, in warning
self._log(WARNING, msg, args, **kwargs)
File "/usr/lib/python3.7/logging/__init__.py", line 1519, in _log
self.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1529, in handle
self.callHandlers(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1591, in callHandlers
hdlr.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 905, in handle
self.emit(record)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 179, in emit
self.handleError(record)
Message: '[present-rich] %s'
Arguments: (UpgradePrompt(old='22.2.2', new='23.2.1'),)
[end of output]
│ exit code: 1
╰─> See above for output.
for line in lines:
s2 = os.stat(f2)
Call stack:
File "/usr/local/bin/pip", line 10, in <module>
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
