Je viens d’acheter le plugin Loxone et ai essayé d’installer celui-ci.
Les dépendances s’installent correctement mais le démon ne se lance pas. Voici les logs de l’install des dépendances et du démon
Dépendances
Début de l'installation
--2021-10-05 00:37:19-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1510 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 7.23M=0s
2021-10-05 00:37:19 (7.23 MB/s) - 'dependencies.sh' saved [1510/1510]
dependencies.sh: 3: [: /tmp/jeedom/loxone/dependancy: unexpected operator
Nodejs non installé
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
Hit:4 https://packages.sury.org/php buster InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
dependencies.sh: 29: dependencies.sh: [[: not found
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
dependencies.sh: 38: [: x86_64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Hit:5 https://packages.sury.org/php buster InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 14.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 1 newly installed, 0 to remove and 17 not upgraded.
Need to get 0 B/25.1 MB of archives.
After this operation, 122 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 110519 files and directories currently installed.)
Preparing to unpack .../nodejs_14.18.0-deb-1nodesource1_amd64.deb ...
Unpacking nodejs (14.18.0-deb-1nodesource1) ...
Setting up nodejs (14.18.0-deb-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated axios@0.18.1: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
> bufferutil@4.0.4 install /var/www/html/plugins/loxone/resources/node_modules/bufferutil
> node-gyp-build
> utf-8-validate@5.0.6 install /var/www/html/plugins/loxone/resources/node_modules/utf-8-validate
> node-gyp-build
> lxcommunicator@1.1.1 postinstall /var/www/html/plugins/loxone/resources/node_modules/lxcommunicator
> node ./browserify.js
Creating browserified module...
Creating debug module
Creating release module
Saving debug module
Saving release module
LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
npm notice created a lockfile as package-lock.json. You should commit this file.
added 295 packages from 209 contributors and audited 295 packages in 107.942s
38 packages are looking for funding
run `npm fund` for details
found 1 high severity vulnerability
run `npm audit fix` to fix them, or `npm audit` for details
Fin de l'installation
Démon
nohup: failed to run command 'nodejs': No such file or directory
sh: 1: nodejs: not found
[2021-10-05 00:42:52][ERROR] : Impossible de lancer le démon loxoned. Vérifiez le log.
nohup: impossible d'exécuter la commande 'nodejs': Aucun fichier ou dossier de ce type
[2021-10-05 00:45:41][ERROR] : Impossible de lancer le démon loxoned. Vérifiez le log.
Quelqu’un a déjà rencontré ce problème?
D’avance, un grand merci pour votre aide.
Michaël
