Problème Jeedom & Ajax
Ca se trouve c’est les modules inconnu après la de toute facon sans log je ne peux rien faire.
Non ce sont des Doorprotect classiques comme les autres
Utilisez le code ci-dessus, et ils seront alors identifiés.
ça annule et remplace le fichier ou ce n’est qu’une partie ?
je ne suis pas trop familier sur l’éditeur
Vous trouverez ci-dessous le contenu complet du fichier ajaxSystem.class.php.
<?php
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
/* * ***************************Includes********************************* */
require_once __DIR__  . '/../../../../core/php/core.inc.php';
class ajaxSystem extends eqLogic {
  /*     * *************************Attributs****************************** */
  /*     * ***********************Methode static*************************** */
  public static function templateWidget() {
    $return = array('info' => array('string' => array()));
    $return['info']['string']['state'] = array(
      'template' => 'tmplmultistate',
      'test' => array(
        array('operation' => '#value# == "ARMED"', 'state_light' => '<i class="fas fa-lock"></i>'),
        array('operation' => '#value# == "DISARMED"', 'state_light' => '<i class="fas fa-lock-open"></i>'),
        array('operation' => '#value# == "ARMED_NIGHT_MODE_OFF"', 'state_light' => '<i class="fas fa-lock"></i>'),
        array('operation' => '#value# == "DISARMED_NIGHT_MODE_ON"', 'state_light' => '<i class="fas fa-moon"></i>'),
        array('operation' => '#value# == "DISARMED_NIGHT_MODE_OFF"', 'state_light' => '<i class="fas fa-lock-open"></i>'),
        array('operation' => '#value# == "NIGHT_MODE"', 'state_light' => '<i class="fas fa-moon"></i>'),
        array('operation' => '#value# == "ARMED_NIGHT_MODE_ON"', 'state_light' => '<i class="fas fa-lock"></i>'),
        array('operation' => '#value# == "PANIC"', 'state_light' => '<i class="fas fa-exclamation-circle"></i>')
    return $return;
  public static function request($_path, $_data = null, $_type = 'GET') {
    $url = config::byKey('service::cloud::url') . '/service/ajaxSystem';
    $url .= '?path=' . urlencode(str_replace('{userId}', config::byKey('userId', 'ajaxSystem'), $_path));
    if ($_path != '/login' && $_path != '/refresh') {
      $mc = cache::byKey('ajaxSystem::sessionToken');
      $sessionToken = $mc->getValue();
      if (trim($mc->getValue()) == '') {
        $sessionToken = self::refreshToken();
      $url .= '&session_token=' . $sessionToken;
    if ($_data !== null && $_type == 'GET') {
      $url .= '&options=' . urlencode(json_encode($_data));
    $request_http = new com_http($url);
    $request_http->setHeader(array(
      'Content-Type: application/json',
      'Autorization: ' . sha512(mb_strtolower(config::byKey('market::username')) . ':' . config::byKey('market::password'))
    log::add('ajaxSystem', 'debug', '[request] ' . $url . ' => ' . json_encode($_data));
    if ($_type == 'POST') {
      $request_http->setPost(json_encode($_data));
    if ($_type == 'PUT') {
      $request_http->setPut(json_encode($_data));
    $return = json_decode($request_http->exec(60, 3), true);
    $return = is_json($return, $return);
    if (isset($return['error']) || isset($return['errors'])) {
      sleep(rand(1,30));
      throw new \Exception(__('Erreur lors de la requete à Ajax System : ', __FILE__) . json_encode($return));
    if (isset($return['body'])) {
      return $return['body'];
    log::add('ajaxSystem', 'debug', json_encode($return));
    return $return;
  public static function start() {
    self::refreshAllData();
  public static function refreshAllData() {
    foreach (eqLogic::byType('ajaxSystem', true) as $eqLogic) {
      try {
        sleep(rand(10, 60));
        $eqLogic->refreshData();
        if ($eqLogic->getCache('failedAjaxRequest', 0) > 0) {
          $eqLogic->setCache('failedAjaxRequest', 0);
      } catch (\Exception $e) {
        $eqLogic->setCache('failedAjaxRequest', $eqLogic->getCache('failedAjaxRequest', 0) + 1);
        if ($eqLogic->getCache('failedAjaxRequest', 0) > 3) {
          log::add('ajaxSystem', 'error', __('Erreur lors de la mise à jour des données de :', __FILE__) . ' ' . $eqLogic->getHumanName() . ' => ' . $e->getMessage(), 'ajaxSystem::failedGetData' . $eqLogic->getId());
  public static function login($_username, $_password) {
    if (trim(network::getNetworkAccess('external')) == '') {
      throw new Exception(__('URL d\'accès externe de votre Jeedom invalide. Merci de la configurer dans Réglage -> Système -> Configuration puis onglet Réseaux'));
    $data = self::request('/login', array(
      'login' => $_username,
      'passwordHash' => $_password,
      'userRole' => 'USER',
      'apikey' => jeedom::getApiKey('ajaxSystem'),
      'url' => network::getNetworkAccess('external')
    ), 'POST');
    log::add('ajaxSystem', 'debug', '[login] ' . json_encode($data));
    config::save('refreshToken', $data['refreshToken'], 'ajaxSystem');
    config::save('userId', $data['userId'], 'ajaxSystem');
    cache::set('ajaxSystem::sessionToken', $data['sessionToken'], 60 * 14);
  public static function refreshToken() {
    $data = self::request('/refresh', array(
      'userId' => config::byKey('userId', 'ajaxSystem'),
      'refreshToken' => config::byKey('refreshToken', 'ajaxSystem')
    ), 'POST');
    log::add('ajaxSystem', 'debug', '[refreshToken] ' . json_encode($data));
    if ($data['refreshToken'] == '') {
      log::add('ajaxSystem', 'debug', '[refreshToken] Empty refresh token, retry in 5s');
      sleep(5);
      ), 'POST');
      throw new Exception(__('Impossible de mettre à jour les tokens d\'accès, refresh token vide : ', __FILE__) . json_encode($data));
    return $data['sessionToken'];
  public static function sync() {
    $hubs = self::request('/user/{userId}/hubs');
    //log::add('ajaxSystem', 'debug', json_encode($hubs));
    foreach ($hubs as $hub) {
      $hub_info = self::request('/user/{userId}/hubs/' . $hub['hubId']);
      //log::add('ajaxSystem', 'debug', json_encode($hub_info));
      $eqLogic = eqLogic::byLogicalId($hub['hubId'], 'ajaxSystem');
      if (!is_object($eqLogic)) {
        $eqLogic = new ajaxSystem();
        $eqLogic->setEqType_name('ajaxSystem');
        $eqLogic->setIsEnable(1);
        $eqLogic->setName($hub_info['name']);
        $eqLogic->setCategory('security', 1);
        $eqLogic->setIsVisible(1);
      $eqLogic->setConfiguration('type', 'hub');
      $eqLogic->setConfiguration('color', $hub_info['color']);
      $eqLogic->setConfiguration('device', $hub_info['hubSubtype']);
      $eqLogic->setConfiguration('ip', $hub_info['ethernet']['ip']);
      $eqLogic->setConfiguration('firmware', $hub_info['firmware']['version']);
      $eqLogic->setLogicalId($hub['hubId']);
      $eqLogic->save();
      $eqLogic->refreshData($hub_info); //give already obtained data to refresh function
      $devices = self::request('/user/{userId}/hubs/' . $hub['hubId'] . '/devices');
      log::add('ajaxSystem', 'debug', 'Number of devices found for hub: ' . $hub['hubId'] . ': ' . count($devices));
      foreach ($devices as $device) {
          if (!isset($device['id'])) {
              continue;
          // Identify whether the device exists already in Jeedom
          $eqLogic = eqLogic::byLogicalId($device['id'], 'ajaxSystem');
          // Only obtain extra info if the data is not available in the original devices list
          $device_info = $device;
          if (!isset($device['deviceName']) || !isset($device['deviceType'])) {
              $device_info = self::request('/user/{userId}/hubs/' . $hub['hubId'] . '/devices/' . $device['id']);
              log::add('ajaxSystem', 'debug', 'Retrieve Extra info fo: ' . $device['id']);
               usleep(200000); // short brake to reduce impact on API
          if (!$device_info || !isset($device_info['id'])) {
              log::add('ajaxSystem', 'warning', 'Not able to retrieve data for device with ID: ' . $device['id']);
              continue;
          // Create only a new object if required
              $eqLogic->setLogicalId($device_info['id']);
          // Update data (also for existing devices)
          $hasChanged = false;
          if ($eqLogic->getName() !== $device_info['deviceName']) {
              $eqLogic->setName($device_info['deviceName']);
              $hasChanged = true;
          // Update config and check changes
          $configs = [
              'hub_id'   => $hub['hubId'],
              'type'     => 'device',
              'color'    => $device_info['color'] ?? '',
              'device'   => $device_info['deviceType'] ?? '',
              'firmware' => $device_info['firmwareVersion'] ?? ''
          foreach ($configs as $key => $value) {
              if ($eqLogic->getConfiguration($key) !== $value) {
                  $eqLogic->setConfiguration($key, $value);
                  $hasChanged = true;
          // Only store changes, not existing data to reduce impact on db
          if ($hasChanged || $eqLogic->getId() == null) {
              $eqLogic->save();
              log::add('ajaxSystem', 'info', 'Device updated/added: ' . $device_info['deviceName']);
          $eqLogic->refreshData($device_info); //give already obtained data to refresh function
      $groups = self::request('/user/{userId}/hubs/' . $hub['hubId'] . '/groups');
      log::add('ajaxSystem', 'debug', 'Number of groups: ' . count($groups));
      foreach ($groups as $group) {
        $eqLogic = eqLogic::byLogicalId($group['id'], 'ajaxSystem');
          $eqLogic->setName($group['groupName']);
        $eqLogic->setConfiguration('hub_id', $hub['hubId']);
        $eqLogic->setConfiguration('type', 'group');
        $eqLogic->setConfiguration('device', 'group');
        $eqLogic->setLogicalId($group['id']);
        $eqLogic->save();
        $eqLogic->refreshData($group); //give already obtained data to refresh function
  public static function devicesParameters($_device = '') {
    $return = array();
    $files = ls(__DIR__ . '/../config/devices', '*.json', false, array('files', 'quiet'));
    foreach ($files as $file) {
      try {
        $return[str_replace('.json', '', $file)] = is_json(file_get_contents(__DIR__ . '/../config/devices/' . $file), false);
      } catch (Exception $e) {
    if (isset($_device) && $_device != '') {
      if (isset($return[$_device])) {
        return $return[$_device];
      return array();
    return $return;
  /*     * *********************Méthodes d'instance************************* */
  public function postSave() {
    if ($this->getConfiguration('applyDevice') != $this->getConfiguration('device')) {
      $this->applyModuleConfiguration();
    foreach ($this->getCmd() as $cmd) {
      if(strpos($cmd->getLogicalId(),'sia') !== false){
        $cmd->remove();
  public function applyModuleConfiguration() {
    $this->setConfiguration('applyDevice', $this->getConfiguration('device'));
    $this->save();
    if ($this->getConfiguration('device') == '') {
      return true;
    $device = self::devicesParameters($this->getConfiguration('device'));
    if (!is_array($device)) {
      return true;
    $this->import($device, true);
  public function getImage() {
    if(method_exists($this,'getCustomImage')){
         $customImage = $this->getCustomImage();
         if($customImage !== null){
            return $customImage;
    if (file_exists(__DIR__ . '/../config/devices/' .  $this->getConfiguration('device') . '_' . strtolower($this->getConfiguration('color')) . '.png')) {
      return 'plugins/ajaxSystem/core/config/devices/' .  $this->getConfiguration('device') . '_' . strtolower($this->getConfiguration('color')) . '.png';
    if (file_exists(__DIR__ . '/../config/devices/' .  $this->getConfiguration('device') . '.png')) {
      return 'plugins/ajaxSystem/core/config/devices/' .  $this->getConfiguration('device') . '.png';
    return false;
  public function refreshData($_data = null) {
    $datas=$_data; //reuse data from sync function
    if (isset($datas['firmwareVersion']) && $datas['firmwareVersion'] != $this->getConfiguration('firmware')) {
      $this->setConfiguration('firmware', $datas['firmwareVersion']);
      $this->save(true);
    foreach ($this->getCmd('info') as $cmd) {
      $paths = explode('::', $cmd->getLogicalId());
      $value = $datas;
      foreach ($paths as $key) {
        if (!isset($value[$key])) {
          continue 2;
        $value = $value[$key];
      $this->checkAndUpdateCmd($cmd, $value);
    //Refresh batterie depuis trame de synchronisation / refresh
    $batteryChargeLevel = '-1';
    if (isset($datas['batteryChargeLevelPercentage'])) {
      $batteryChargeLevel = $datas['batteryChargeLevelPercentage'];
    if (isset($datas['battery']) && isset($datas['battery']['chargeLevelPercentage'])) {
      $batteryChargeLevel = $datas['battery']['chargeLevelPercentage'];
    //Si niveau de charge numérique disponible, mise à jour de l'information
    if($batteryChargeLevel != '-1'){
      //Au niveau de l'équipement
      $this->batteryStatus($batteryChargeLevel);
      $this->checkAndUpdateCmd('battery::chargeLevelPercentage', $value);
  /*     * **********************Getteur Setteur*************************** */
class ajaxSystemCmd extends cmd {
  /*     * *********************Methode d'instance************************* */
  public function alreadyInState($_options) {
    $eqLogic = $this->getEqLogic();
    if ($eqLogic->getConfiguration('type') == 'hub') {
      $cmdValue = $this->getCmdValue();
      $value =  $cmdValue->execCmd();
      if ($this->getLogicalId() == 'ARM') {
        return ($value == 'ARMED');
      if ($this->getLogicalId() == 'DISARM') {
        return ($value == 'DISARMED_NIGHT_MODE_OFF' || $value == 'DISARMED');
      if ($this->getLogicalId() == 'NIGHT_MODE') {
        return ($value == 'NIGHT_MODE');
      if ($this->getLogicalId() == 'PANIC' || $this->getLogicalId() == 'muteFireDetectors') {
        return false;
    if ($eqLogic->getConfiguration('type') == 'group') {
      return false;
    return parent::alreadyInState($_options);
  public function execute($_options = array()) {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getLogicalId() . '/commands/arming', array('command' => 'ARM', 'ignoreProblems' => true), 'PUT');
      } else if ($this->getLogicalId() == 'DISARM') {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getLogicalId() . '/commands/arming', array('command' => 'DISARM', 'ignoreProblems' => true), 'PUT');
      } else if ($this->getLogicalId() == 'NIGHT_MODE') {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getLogicalId() . '/commands/arming', array('command' => 'NIGHT_MODE_ON', 'ignoreProblems' => true), 'PUT');
      } else if ($this->getLogicalId() == 'PANIC') {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getLogicalId() . '/commands/panic', array('location' => array('latitude' => 0, 'longitude' => 0, 'accuracy' => 0, 'speed' => 0, 'timestamp' => 0)), 'PUT');
      } else if ($this->getLogicalId() == 'muteFireDetectors') {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getLogicalId() . '/commands/muteFireDetectors', array('muteType' => 'ALL_FIRE_DETECTORS'), 'PUT');
    } else if ($eqLogic->getConfiguration('type') == 'device') {
      $command = array(
        'command' => $this->getLogicalId(),
        'deviceType' => $eqLogic->getConfiguration('device')
      ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getConfiguration('hub_id') . '/devices/' . $eqLogic->getLogicalId() . '/command', $command, 'POST');
    } else if ($eqLogic->getConfiguration('type') == 'group') {
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getConfiguration('hub_id') . '/groups/' . $eqLogic->getLogicalId()  . '/commands/arming', array('command' => 'ARM', 'ignoreProblems' => true), 'PUT');
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getConfiguration('hub_id') . '/groups/' . $eqLogic->getLogicalId() . '/commands/arming', array('command' => 'DISARM', 'ignoreProblems' => true), 'PUT');
        ajaxSystem::request('/user/{userId}/hubs/' . $eqLogic->getConfiguration('hub_id') . '/groups/' . $eqLogic->getLogicalId() . '/commands/arming', array('command' => 'NIGHT_MODE_ON', 'ignoreProblems' => true), 'PUT');
Super ça fonctionne très bien, je retrouve tous mes équipements
Euh j’ai peut etre parlé trop vite
Maintenant j’ai une erreur en rouge
core/ajax/eqLogic.ajax.php : Error /error: Syntax error, unrecognized expression: . /async:true /type:POST /dataType:json /action:get
Edit : NON rien a voir Désolé :wink:
Je ne suis pas sûr de la manière dont vous avez inclus le code. Les indentations sont-elles correctes ? Cette erreur est liée à la façon dont vous avez inséré le code dans votre instance Jeedom.
Rien a voir
Commencez par supprimer les appareils aux noms étranges, puis synchronisez à nouveau.
Tout est OK :+1:
Merci pour ces retours, une nouvelle version stable sortira demain et intègrera certaine modification de @Dirk pour réduire le nombre de requêtes. J’ai aussi augmenter la nombre de requête possible sur le cloud. Les deux ensemble devrais je l’espere corriger les soucis que vous avez.
