Je viens d’installer deux modules VR TS130f et j’ai des erreurs d’intégration.
Y a-t 'il des personnes chez qui cela fonctionne ?
Ci-dessous les messages d’erreurs :
Modèle : TS130F_dual
Fabricant : Lonsonho
### Property inconnue : "calibration_time_left. Commande : {"access":1,"description":"Calibration time","endpoint":"left","name":"calibration_time","property":"calibration_time_left","type":"numeric","unit":"S"}
### Property inconnue : "calibration_time_right. Commande : {"access":1,"description":"Calibration time","endpoint":"right","name":"calibration_time","property":"calibration_time_right","type":"numeric","unit":"S"}
#### Last Payload :
{"calibration_left":"OFF","calibration_right":"OFF","calibration_time_left":25.1,"calibration_time_right":22.8,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"Volets 1-2","hardwareVersion":1,"ieeeAddr":"0xa4c138eeeada24f5","manufacturerID":4417,"manufacturerName":"_TZ3000_j1xl73iw","model":"TS130F_dual","networkAddress":7358,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"linkquality":113,"motor_reversal_left":"OFF","motor_reversal_right":"OFF","moving_left":"STOP","moving_right":"STOP","position_left":0,"position_right":100,"state_left":"CLOSE","state_right":"OPEN"}
Ma config :
Mes logs :
zigbee2mqt.txt (1,6 Mo)
zigbee2mqtt_demon.txt (549,9 Ko)
zigbee2mqtt_dep.txt (2,6 Ko)
J’ai bien envoyé tout cela à @MrGreen mais pas de réponse à ce jour (pas étonnant vu la charge qu’il doit avoir !).
Merci par avance pour votre aide.
