Lors de l’installation du plugin sur deux luna j’ai la même erreur :
node:internal/modules/cjs/loader:959
throw err;
Error: Cannot find module 'request'
Require stack:
- /var/www/html/plugins/espeasy/resources/espeasy.js
at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
at Function.Module._load (node:internal/modules/cjs/loader:804:27)
at Module.require (node:internal/modules/cjs/loader:1028:19)
at require (node:internal/modules/cjs/helpers:102:18)
at Object. (/var/www/html/plugins/espeasy/resources/espeasy.js:3:15)
at Module._compile (node:internal/modules/cjs/loader:1126:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
at Module.load (node:internal/modules/cjs/loader:1004:32)
at Function.Module._load (node:internal/modules/cjs/loader:839:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/var/www/html/plugins/espeasy/resources/espeasy.js' ]
Est-ce que quelqu’un à idée du sujet ? ;o)
