Salut a tous,
J’ai un petit soucis j’ai une installe fresh sur raspbian 11 et je n’arrive pas a faire fonctionner le plugin (file empty) d’après tomitomas normalement ça aurais du fonctionner grrrr .
[2024-01-30 09:57:18][ERROR] : Erreur sur noip::ipCheckAndUpdate() : Exception Object ( [message:protected] => [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name ORDER BY ob.name,el.name [string:Exception:private] => [code:protected] => 0 [file:protected] => /var/www/html/core/class/DB.class.php [line:protected] => 102 [trace:Exception:private] => Array ( [0] => Array ( [file] => /var/www/html/core/class/eqLogic.class.php [line] => 193 [function] => Prepare [class] => DB [type] => :: ) [1] => Array ( [file] => /var/www/html/plugins/noip/core/class/noipTools.class.php [line] => 68 [function] => byType [class] => eqLogic [type] => :: ) [2] => Array ( [file] => /var/www/html/plugins/noip/core/class/noipTools.class.php [line] => 97 [function] => getDomainToUpdate [class] => noipTools [type] => :: ) [3] => Array ( [file] => /var/www/html/plugins/noip/core/class/noip.class.php [line] => 47 [function] => makeIpUpdate [class] => noipTools [type] => :: ) [4] => Array ( [file] => /var/www/html/core/php/jeeCron.php [line] => 78 [function] => ipCheckAndUpdate [class] => noip [type] => :: ) ) [previous:Exception:private] => )
[2024-01-30 09:58:38][DEBUG] : Pas de mise à jour d'IP à réaliser
[2024-01-30 10:00:59][DEBUG] : Pas de mise à jour d'IP à réaliser
[2024-01-30 10:08:40][DEBUG] : Task 'syncNoIp' executed now
[2024-01-30 10:08:41][INFO] : Début de synchronisation
[2024-01-30 10:08:41][INFO] : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py --loglevel info --user alx68xxxxxxxxxxx --pwd "**********" --threshold 7 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 0<<
[2024-01-30 09:08:42][INFO] : Log level : info
[2024-01-30 09:08:42][INFO] : User : alx68.xxxxxxxxxx
[2024-01-30 09:08:42][INFO] : Threshold : 7
[2024-01-30 09:08:42][INFO] : Renew : 0
[2024-01-30 09:08:42][INFO] : ForcePath : 0
[2024-01-30 09:08:42][ERROR] : Exception has been thrown. Message: Unable to obtain driver for chrome using Selenium Manager.; For documentation on this error, please visit: https://www.selenium.dev/documentation/webdriver/troubleshooting/errors/driver_location
[2024-01-30 10:08:42][DEBUG] : [Aucun][v] file content:
[2024-01-30 10:08:42][ERROR] : [Aucun][v] file content empty
[2024-01-30 10:08:42][INFO] : Fin de la synchronisation
Launch install of noip dependencies
-- Current OS version :
Description: Raspbian GNU/Linux 11 (bullseye)
-- Updating repo...
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
-- Installation of python3 and dependencies
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
The following additional packages will be installed:
libpython2-dev libpython2-stdlib libpython2.7 libpython2.7-dev
libpython2.7-minimal libpython2.7-stdlib python-is-python2 python2
python2-dev python2-minimal python2.7 python2.7-dev python2.7-minimal
Suggested packages:
python2-doc python-tk python2.7-doc binfmt-support
The following packages will be REMOVED:
python-is-python3
libpython2.7-minimal libpython2.7-stdlib python-dev-is-python2
python-is-python2 python2 python2-dev python2-minimal python2.7
0 upgraded, 14 newly installed, 1 to remove and 0 not upgraded.
Need to get 6815 kB of archives.
After this operation, 27.3 MB of additional disk space will be used.
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython2.7-minimal armhf 2.7.18-8+deb11u1 [397 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2.7-minimal armhf 2.7.18-8+deb11u1 [1074 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython2.7-stdlib armhf 2.7.18-8+deb11u1 [1803 kB]
Get:3 http://distrib-coffee.ipsl.jussieu.fr/pub/linux/raspbian/raspbian bullseye/main armhf python2-minimal armhf 2.7.18-3 [34.2 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2.7 armhf 2.7.18-8+deb11u1 [311 kB]
Get:6 http://mirrors.ircam.fr/pub/raspbian/raspbian bullseye/main armhf libpython2-stdlib armhf 2.7.18-3 [21.2 kB]
Get:7 http://mirrors.ircam.fr/pub/raspbian/raspbian bullseye/main armhf python2 armhf 2.7.18-3 [24.5 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython2.7 armhf 2.7.18-8+deb11u1 [865 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython2.7-dev armhf 2.7.18-8+deb11u1 [1966 kB]
Get:11 http://distrib-coffee.ipsl.jussieu.fr/pub/linux/raspbian/raspbian bullseye/main armhf python-is-python2 all 2.7.18-9 [2940 B]
Get:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2-dev armhf 2.7.18-3 [1216 B]
Get:12 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2.7-dev armhf 2.7.18-8+deb11u1 [292 kB]
Get:10 http://mirrors.ircam.fr/pub/raspbian/raspbian bullseye/main armhf libpython2-dev armhf 2.7.18-3 [21.3 kB]
Get:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python-dev-is-python2 all 2.7.18-9 [1528 B]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 6815 kB in 2s (3045 kB/s)
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 74638 files and directories currently installed.)
Removing python-is-python3 (3.9.2-1) ...
Selecting previously unselected package libpython2.7-minimal:armhf.
(Reading database ... 74633 files and directories currently installed.)
Preparing to unpack .../0-libpython2.7-minimal_2.7.18-8+deb11u1_armhf.deb ...
Selecting previously unselected package python2.7-minimal.
Preparing to unpack .../1-python2.7-minimal_2.7.18-8+deb11u1_armhf.deb ...
Unpacking python2.7-minimal (2.7.18-8+deb11u1) ...
Selecting previously unselected package python2-minimal.
Preparing to unpack .../2-python2-minimal_2.7.18-3_armhf.deb ...
Unpacking python2-minimal (2.7.18-3) ...
Selecting previously unselected package libpython2.7-stdlib:armhf.
Preparing to unpack .../3-libpython2.7-stdlib_2.7.18-8+deb11u1_armhf.deb ...
Unpacking libpython2.7-stdlib:armhf (2.7.18-8+deb11u1) ...
Selecting previously unselected package python2.7.
Preparing to unpack .../4-python2.7_2.7.18-8+deb11u1_armhf.deb ...
Unpacking python2.7 (2.7.18-8+deb11u1) ...
Selecting previously unselected package libpython2-stdlib:armhf.
Preparing to unpack .../5-libpython2-stdlib_2.7.18-3_armhf.deb ...
Unpacking libpython2-stdlib:armhf (2.7.18-3) ...
Setting up libpython2.7-minimal:armhf (2.7.18-8+deb11u1) ...
Setting up python2.7-minimal (2.7.18-8+deb11u1) ...
Linking and byte-compiling packages for runtime python2.7...
Setting up python2-minimal (2.7.18-3) ...
(Reading database ... 75379 files and directories currently installed.)
Preparing to unpack .../0-python2_2.7.18-3_armhf.deb ...
Unpacking python2 (2.7.18-3) ...
Selecting previously unselected package libpython2.7:armhf.
Preparing to unpack .../1-libpython2.7_2.7.18-8+deb11u1_armhf.deb ...
Unpacking libpython2.7:armhf (2.7.18-8+deb11u1) ...
Selecting previously unselected package libpython2.7-dev:armhf.
Preparing to unpack .../2-libpython2.7-dev_2.7.18-8+deb11u1_armhf.deb ...
Unpacking libpython2.7-dev:armhf (2.7.18-8+deb11u1) ...
Selecting previously unselected package libpython2-dev:armhf.
Preparing to unpack .../3-libpython2-dev_2.7.18-3_armhf.deb ...
Unpacking libpython2-dev:armhf (2.7.18-3) ...
Selecting previously unselected package python-is-python2.
Preparing to unpack .../4-python-is-python2_2.7.18-9_all.deb ...
Unpacking python-is-python2 (2.7.18-9) ...
Selecting previously unselected package python2.7-dev.
Preparing to unpack .../5-python2.7-dev_2.7.18-8+deb11u1_armhf.deb ...
Unpacking python2.7-dev (2.7.18-8+deb11u1) ...
Selecting previously unselected package python2-dev.
Preparing to unpack .../6-python2-dev_2.7.18-3_armhf.deb ...
Unpacking python2-dev (2.7.18-3) ...
Selecting previously unselected package python-dev-is-python2.
Preparing to unpack .../7-python-dev-is-python2_2.7.18-9_all.deb ...
Unpacking python-dev-is-python2 (2.7.18-9) ...
Setting up libpython2.7-stdlib:armhf (2.7.18-8+deb11u1) ...
Setting up libpython2.7:armhf (2.7.18-8+deb11u1) ...
Setting up libpython2.7-dev:armhf (2.7.18-8+deb11u1) ...
Setting up python2.7 (2.7.18-8+deb11u1) ...
Setting up libpython2-stdlib:armhf (2.7.18-3) ...
Setting up python2 (2.7.18-3) ...
Setting up libpython2-dev:armhf (2.7.18-3) ...
Setting up python-is-python2 (2.7.18-9) ...
Setting up python2.7-dev (2.7.18-8+deb11u1) ...
Setting up python2-dev (2.7.18-3) ...
Setting up python-dev-is-python2 (2.7.18-9) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for mailcap (3.69) ...
-- Installed version of Python :
Python 3.9.2
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
Package python-requests is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-requests' has no installation candidate
-- Installation of chromium
chromium is already the newest version (106.0.5249.119-1~deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
-- Installed version of pip :
pip 20.3.4 from /usr/lib/python3/dist-packages/pip (python 3.9)
-- Installation of python library 'selenium' with command pip3
cat: /tmp/jeedom/noip/dependancy_noip: No such file or directory
-- Installation of dependencies is done !
Merci pour toutes aides fournis
