Probleme installation des dépendances / websocket / sur une Atlas
J’ai installé le plugin gardena-husqvarna suite à l’acquisition d’une automower.
Je rencontre un problème à l’installation des dépendances (cf Log ci dessous).
Je précise que mon Jeedom tourne sur une Atlas, que tout est à jour, et qu’aucun autre plugin ne rencontre (pour le moment) de problème… Une petite idée ?
Merci d’avance !
== 11/03/2024 15:50:59 == Dependencies installation for gardena
[  5% ] : Clean apt...
[  9% ] : Clean apt : [  OK  ]
[ 10% ] : Update apt...
[ 19% ] : Update apt : [  OK  ]
[ 20% ] : Install apt packages...
[ 49% ] : Install apt packages : [  OK  ]
[ 50% ] : Creating python 3 virtual environment...
[ 59% ] : Creating python 3 virtual environment : [  OK  ]
[ 60% ] : Setting up virtual environment...
[ 69% ] : Setting up virtual environment : [  OK  ]
[ 70% ] : Install the required python packages...
[ 99% ] : Install the required python packages : ERROR
[100% ] : Finished !
== KO == Installation Error
== ANALYSING ERRORS...
== NO KNOWN ERROR DETECTED
== Error in step : Install the required python packages
== Line 158
== Command `/var/www/html/plugins/gardena/resources/venv/bin/python3 -m pip install --no-cache-dir -r requirements.txt' have an issue
== Return code is 1
== Error message :
Collecting requests>=2.20.0 (from -r requirements.txt (line 1))
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting oauthlib>=3.2.2 (from -r requirements.txt (line 2))
Downloading oauthlib-3.2.2-py3-none-any.whl.metadata (7.5 kB)
Collecting requests_oauthlib>=1.3.1 (from -r requirements.txt (line 3))
Downloading requests_oauthlib-1.4.0-py2.py3-none-any.whl.metadata (11 kB)
ERROR: Ignored the following versions that require a different python version: 1.6.2 Requires-Python >=3.8; 1.6.3 Requires-Python >=3.8; 1.6.4 Requires-Python >=3.8; 1.7.0 Requires-Python >=3.8
ERROR: Could not find a version that satisfies the requirement websocket-client~=1.7 (from versions: 0.3, 0.4, 0.4.1, 0.5.0a0, 0.5.0, 0.5.1, 0.6.0, 0.7.0, 0.8.0, 0.9.0, 0.10.0, 0.11.0, 0.12.0, 0.13.0, 0.14.0, 0.14.1, 0.15.0, 0.16.0a0, 0.16.0, 0.17.0, 0.18.0, 0.19.0, 0.20.0, 0.21.0, 0.22.0, 0.23.0, 0.24.0, 0.25.0, 0.26.0, 0.27.0, 0.28.0, 0.29.0, 0.30.0, 0.31.0, 0.32.0, 0.33.0, 0.34.0, 0.35.0, 0.36.0, 0.37.0, 0.39.0, 0.40.0, 0.42.0, 0.42.1, 0.43.0, 0.44.0, 0.45.0, 0.46.0, 0.47.0, 0.48.0, 0.49.0, 0.50.0, 0.51.0, 0.52.0, 0.53.0, 0.54.0, 0.55.0, 0.56.0, 0.57.0, 0.58.0, 0.59.0, 1.0.0, 1.0.1, 1.1.0, 1.1.1, 1.2.0, 1.2.1, 1.2.2, 1.2.3, 1.3.0, 1.3.1, 1.3.2, 1.3.3, 1.4.0, 1.4.1, 1.4.2, 1.5.0, 1.5.1, 1.5.2, 1.5.3, 1.6.0, 1.6.1)
ERROR: No matching distribution found for websocket-client~=1.7
veuillez fournir toutes les informations demandées dans la documentation du plugin
Bonjour @Mips,
Voici le complément:
Log Gardena (Mode Debug)
[2024-03-11 15:44:38]DEBUG : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php  plugin_id=gardena function=remove callInstallFunction=1
[2024-03-11 15:44:40]INFO : Début d'activation du plugin
[2024-03-11 15:44:41]INFO : Info sur le démon : {"log":"gardena","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2024-03-11 15:40:07"}
[2024-03-11 15:44:41]DEBUG : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php  plugin_id=gardena function=install callInstallFunction=1
[2024-03-11 15:50:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 15:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 15:50:52]ERROR : Impossible de lancer le démon
[2024-03-11 15:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 15:55:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:00:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:00:17]ERROR : Impossible de lancer le démon
[2024-03-11 16:05:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:05:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:10:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:10:15]ERROR : Impossible de lancer le démon
[2024-03-11 16:15:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:15:15]ERROR : Impossible de lancer le démon
[2024-03-11 16:20:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:20:15]ERROR : Impossible de lancer le démon
[2024-03-11 16:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:25:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:30:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:30:16]ERROR : Impossible de lancer le démon
[2024-03-11 16:35:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:35:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:40:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:40:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:45:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:45:14]ERROR : Impossible de lancer le démon
[2024-03-11 16:50:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 16:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 16:55:14]ERROR : Impossible de lancer le démon
[2024-03-11 17:00:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:00:16]ERROR : Impossible de lancer le démon
[2024-03-11 17:05:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:05:14]ERROR : Impossible de lancer le démon
[2024-03-11 17:10:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:10:14]ERROR : Impossible de lancer le démon
[2024-03-11 17:15:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:15:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:20:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:20:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:25:14]ERROR : Impossible de lancer le démon
[2024-03-11 17:30:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:30:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:35:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:35:14]ERROR : Impossible de lancer le démon
[2024-03-11 17:40:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:40:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:45:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:45:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:50:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 17:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 17:55:14]ERROR : Impossible de lancer le démon
[2024-03-11 18:00:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:00:16]ERROR : Impossible de lancer le démon
[2024-03-11 18:05:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:05:14]ERROR : Impossible de lancer le démon
[2024-03-11 18:10:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:10:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:15:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:15:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:20:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:20:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:25:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:25:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:30:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:30:17]ERROR : Impossible de lancer le démon
[2024-03-11 18:35:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:35:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:40:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:40:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:45:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:45:14]ERROR : Impossible de lancer le démon
[2024-03-11 18:50:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 18:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 18:55:14]ERROR : Impossible de lancer le démon
[2024-03-11 19:00:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:00:16]ERROR : Impossible de lancer le démon
[2024-03-11 19:05:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:05:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:10:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:10:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:15:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:15:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:20:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:20:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:25:14]ERROR : Impossible de lancer le démon
[2024-03-11 19:30:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:30:16]ERROR : Impossible de lancer le démon
[2024-03-11 19:35:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:35:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:40:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:40:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:45:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:45:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:50:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 19:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 19:55:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:00:06]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:00:17]ERROR : Impossible de lancer le démon
[2024-03-11 20:05:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:05:14]ERROR : Impossible de lancer le démon
[2024-03-11 20:10:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:10:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:15:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:15:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:20:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:20:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:25:14]ERROR : Impossible de lancer le démon
[2024-03-11 20:30:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:30:16]ERROR : Impossible de lancer le démon
[2024-03-11 20:35:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:35:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:40:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:40:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:45:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:45:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:50:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:50:15]ERROR : Impossible de lancer le démon
[2024-03-11 20:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-11 20:55:15]ERROR : Impossible de lancer le démon
[2024-03-11 21:00:05]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:20:14]ERROR : Impossible de lancer le démon
[2024-03-12 07:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:25:15]ERROR : Impossible de lancer le démon
[2024-03-12 07:30:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:30:15]ERROR : Impossible de lancer le démon
[2024-03-12 07:35:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:35:14]ERROR : Impossible de lancer le démon
[2024-03-12 07:40:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:40:15]ERROR : Impossible de lancer le démon
[2024-03-12 07:45:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:45:15]ERROR : Impossible de lancer le démon
[2024-03-12 07:50:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:50:15]ERROR : Impossible de lancer le démon
[2024-03-12 07:55:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 07:55:14]ERROR : Impossible de lancer le démon
[2024-03-12 08:00:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:00:15]ERROR : Impossible de lancer le démon
[2024-03-12 08:05:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:05:14]ERROR : Impossible de lancer le démon
[2024-03-12 08:10:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:10:15]ERROR : Impossible de lancer le démon
[2024-03-12 08:15:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:15:15]ERROR : Impossible de lancer le démon
[2024-03-12 08:20:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:20:15]ERROR : Impossible de lancer le démon
[2024-03-12 08:25:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:25:14]ERROR : Impossible de lancer le démon
[2024-03-12 08:30:04]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-03-12 08:30:15]ERROR : Impossible de lancer le démon
Log Gardena_daemon (Mode Debug):
import requests
ModuleNotFoundError: No module named 'requests'
File "/var/www/html/plugins/gardena/resources/gardenad/gardenad.py", line 11, in <module>
from jeedom.jeedom import jeedom_utils, jeedom_com, jeedom_socket, JEEDOM_SOCKET_MESSAGE
File "/var/www/html/plugins/gardena/resources/gardenad/jeedom/jeedom.py", line 19, in <module>
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
import requests
Log Gardena_update (Mode debug):
== 12/03/2024 08:36:11 == Dependencies installation for gardena
[ 99% ] : Install the required python packages : [ERROR]
== Line 158
== Return code is 1
== Error message :
Votre atlas est encore sous buster (ce n’est pas de votre faute, c’est juste un fait);
le problème c’est que les librairies nécessaires sont de moins en moins disponible sous buster
  • soit vous installez la dernière image de l’atlas qui la passera sous bullseye et ensuite restauration d’un backup jeedom et réinstallation de toutes les dépendances
    il faudra le faire un jour quoi qu’il arrive car ce genre de problème ne va que se répéter à l’avenir
    mais vérifiez d’abord que tous vos plugins sont bien compatibles
  • soit j’essaie de descendre la version de websocket-client à 1.6.1 au lieu de 1.7 en beta mais je ne peux pas garantir à 100% que cela va fonctionner et surtout que je ne risque pas de devoir revenir à une version plus élevée un jour car je ne peux pas rester bloqué sur une ancienne version.
Pour mettre un peu d’eau à ton moulin
Le 30 juin 2024 Debian 10 ne sera plus maintenu.
Vu l’âge de cet OS être en v11 aujourd’hui me parait plus que nécessaire
Merci pour la réponse.
A mon sens, aucune logique à downgrader la version websocket-client utilisée, ça n’aurait pas de sens puisque le pb vient de l’OS sous jacent utilisé par l’Atlas.
Par contre, je suis surpris que Jeedom ne propose pas le suivi des versions et une solution de mise à jour "intégrée…
Je vais regarder ça quand j’aurai un peu de temps devant moi.
Merci pour votre réactivité en tout cas.
Bonne journée,
Thoto
si elle existe, la dernière image officielle est en bullseye, il n’y a juste pas eu de communication dessus
Ce que je veux dire c’est que pour un produit qui se veut clé en main avec hardware fourni (bon, certes, pour des utilisateurs « avertis »), il est dommage qu’il n’y ait pas de procédure semi automatique
Avec le plugin-atlas ce n’est pas le cas? je n’ai pas la box donc je ne suis pas sur mais j’avais cru comprendre qu’avec ce plugin l’installation d’une nouvelle image était assisté
@Mips Hélas ce n’est pas si clair. Le plugin Atlas peut effectivement être utilisé pour faire une mise a jour en passant par le recovery, mais c’est peu documenté…
Pour référence, pour les autres utilisateurs qui pourraient lire ce fil, voici un lien vers une procédure bien expliquée pour la mise à jour vers Debian 11, par @Furaxworld (Merci !)
