J’ai voulu réinstaller les dépendances après la dernière mise à jour du plugin (j’aurais pas du!!!) tout et bloqué à 15%…
Si quelqu’un a la solution …
Lis les annonces officielles tu auras peut être la solution qui sait …
Salut Loic ,
J’ai déjà bien cherché avant de poster et comme je suis pas un habitué du forum je sais même plus comment partager les logs
+ touch /tmp/jeedom_install_in_progress_zigbee
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/pre-install.sh
Launch pre-install of zigbee dependancy
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python-rpi.gpio' is not installed, so not removed
Package 'python-rpi.gpio-dbgsym' is not installed, so not removed
Package 'python3-rpi.gpio' is not installed, so not removed
Package 'python3-rpi.gpio-dbgsym' is not installed, so not removed
Package 'rpi.gpio-common' is not installed, so not removed
The following packages were automatically installed and are no longer required:
chromium-common chromium-sandbox libimobiledevice6 libjpeg8 libjsoncpp1
libminizip1 libplist3 libre2-5 libu2f-udev libupower-glib3 libusbmuxd4
upower usbmuxd
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 31 not upgraded.
chromium-common chromium-sandbox libhttp-parser2.8 libimobiledevice6
libjpeg8 libjsoncpp1 libllvm7 libminizip1 libplist3 libre2-5
libstd-rust-1.41 libstd-rust-dev libu2f-udev libupower-glib3 libusbmuxd4
rust-gdb upower usbmuxd
The following packages will be REMOVED:
cargo rustc
0 upgraded, 0 newly installed, 2 to remove and 31 not upgraded.
After this operation, 13.4 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 76999 files and directories currently installed.)
Removing cargo (0.43.1-3~deb10u1+rpi1) ...
Removing rustc (1.41.1+dfsg1-1~deb10u1+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Package 'cargo' is not installed, so not removed
info: downloading installer
info: profile set to 'default'
info: default host triple is armv7-unknown-linux-gnueabihf
info: syncing channel updates for 'stable-armv7-unknown-linux-gnueabihf'
info: latest update on 2022-08-11, rust version 1.63.0 (4b91a6ea7 2022-08-08)
info: downloading component 'cargo'
info: downloading component 'clippy'
info: downloading component 'rust-docs'
info: downloading component 'rust-std'
info: downloading component 'rustc'
info: downloading component 'rustfmt'
info: installing component 'cargo'
info: installing component 'clippy'
info: installing component 'rust-docs'
info: installing component 'rust-std'
info: installing component 'rustc'
info: installing component 'rustfmt'
info: default toolchain set to 'stable-armv7-unknown-linux-gnueabihf'
stable-armv7-unknown-linux-gnueabihf installed - rustc 1.63.0 (4b91a6ea7 2022-08-08)
Rust is installed now. Great!
To get started you may need to restart your current shell.
This would reload your PATH environment variable to include
Cargo's bin directory ($HOME/.cargo/bin).
To configure your current shell, run:
source "$HOME/.cargo/env"
+ echo 3
++ find /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 4
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (22.2.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade six
Collecting six
Downloading six-1.16.0-py2.py3-none-any.whl (11 kB)
Installing collected packages: six
Attempting uninstall: six
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Successfully installed six-1.16.0
+ echo 6
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading pyudev-0.24.0-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.8/61.8 kB 2.8 MB/s eta 0:00:00
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.24.0
Uninstalling pyudev-0.24.0:
Successfully uninstalled pyudev-0.24.0
Successfully installed pyudev-0.24.0
+ echo 7
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade requests
Collecting requests
Downloading requests-2.28.1-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.8/62.8 kB 2.3 MB/s eta 0:00:00
Collecting certifi>=2017.4.17
Downloading certifi-2022.6.15.1-py3-none-any.whl (160 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 160.4/160.4 kB 2.6 MB/s eta 0:00:00
Collecting charset-normalizer<3,>=2
Downloading charset_normalizer-2.1.1-py3-none-any.whl (39 kB)
Collecting idna<4,>=2.5
Downloading idna-3.3-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.2/61.2 kB 3.7 MB/s eta 0:00:00
Collecting urllib3<1.27,>=1.21.1
Downloading urllib3-1.26.12-py2.py3-none-any.whl (140 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 140.4/140.4 kB 2.3 MB/s eta 0:00:00
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 1.26.12
Uninstalling urllib3-1.26.12:
Successfully uninstalled urllib3-1.26.12
Attempting uninstall: idna
Found existing installation: idna 3.3
Uninstalling idna-3.3:
Successfully uninstalled idna-3.3
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 2.0.12
Uninstalling charset-normalizer-2.0.12:
Successfully uninstalled charset-normalizer-2.0.12
Attempting uninstall: certifi
Found existing installation: certifi 2022.6.15.1
Uninstalling certifi-2022.6.15.1:
Successfully uninstalled certifi-2022.6.15.1
Attempting uninstall: requests
Found existing installation: requests 2.28.1
Uninstalling requests-2.28.1:
Successfully uninstalled requests-2.28.1
Successfully installed certifi-2022.6.15.1 charset-normalizer-2.1.1 idna-3.3 requests-2.28.1 urllib3-1.26.12
+ echo 8
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade setuptools
Collecting setuptools
Downloading setuptools-65.3.0-py3-none-any.whl (1.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 2.7 MB/s eta 0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 65.3.0
Uninstalling setuptools-65.3.0:
Successfully uninstalled setuptools-65.3.0
Successfully installed setuptools-65.3.0
+ echo 9
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade wheel
Collecting wheel
Downloading wheel-0.37.1-py2.py3-none-any.whl (35 kB)
Installing collected packages: wheel
Attempting uninstall: wheel
Found existing installation: wheel 0.37.1
Uninstalling wheel-0.37.1:
Successfully uninstalled wheel-0.37.1
Successfully installed wheel-0.37.1
+ echo 10
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 90.6/90.6 kB 2.3 MB/s eta 0:00:00
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 11
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade tornado
Collecting tornado
Downloading tornado-6.2.tar.gz (504 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 504.8/504.8 kB 2.6 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Building wheels for collected packages: tornado
Building wheel for tornado (pyproject.toml): started
Building wheel for tornado (pyproject.toml): finished with status 'done'
Created wheel for tornado: filename=tornado-6.2-cp37-abi3-linux_armv7l.whl size=424779 sha256=02a31f0f262b128f7a1696df44126528213c9e56cdd3d44117ed857e582a3798
Stored in directory: /tmp/pip-ephem-wheel-cache-r72wd_4v/wheels/b8/0e/d8/18f1dc68a5de90daa4706d7f1d6222747b443fca224b7b94e8
Successfully built tornado
Installing collected packages: tornado
Attempting uninstall: tornado
Found existing installation: tornado 6.2
Uninstalling tornado-6.2:
Successfully uninstalled tornado-6.2
Successfully installed tornado-6.2
+ echo 12
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade zha-quirks
Collecting zha-quirks
Downloading zha_quirks-0.0.79-py3-none-any.whl (314 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 314.2/314.2 kB 2.6 MB/s eta 0:00:00
Collecting zigpy>=0.45.1
Downloading zigpy-0.50.2-py3-none-any.whl (155 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 155.6/155.6 kB 2.5 MB/s eta 0:00:00
Collecting voluptuous
Downloading voluptuous-0.13.1-py3-none-any.whl (29 kB)
Collecting aiohttp
Downloading aiohttp-3.8.1.tar.gz (7.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.3/7.3 MB 2.5 MB/s eta 0:00:00
Installing backend dependencies: started
Installing backend dependencies: finished with status 'done'
Collecting cryptography
Downloading cryptography-38.0.1.tar.gz (599 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 599.4/599.4 kB 2.8 MB/s eta 0:00:00
Collecting aiosqlite>=0.16.0
Downloading aiosqlite-0.17.0-py3-none-any.whl (15 kB)
Collecting crccheck
Downloading crccheck-1.1-py3-none-any.whl (29 kB)
Collecting typing_extensions>=3.7.2
Downloading typing_extensions-4.3.0-py3-none-any.whl (25 kB)
Collecting asynctest==0.13.0
Downloading asynctest-0.13.0-py3-none-any.whl (26 kB)
Collecting charset-normalizer<3.0,>=2.0
Collecting yarl<2.0,>=1.0
Downloading yarl-1.8.1.tar.gz (172 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 172.3/172.3 kB 3.1 MB/s eta 0:00:00
Collecting frozenlist>=1.1.1
Downloading frozenlist-1.3.1.tar.gz (66 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.4/66.4 kB 5.9 MB/s eta 0:00:00
Collecting attrs>=17.3.0
Downloading attrs-22.1.0-py2.py3-none-any.whl (58 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.8/58.8 kB 5.1 MB/s eta 0:00:00
Collecting aiosignal>=1.1.2
Downloading aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting async-timeout<5.0,>=4.0.0a3
Downloading async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting multidict<7.0,>=4.5
Downloading multidict-6.0.2.tar.gz (50 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 50.3/50.3 kB 8.1 MB/s eta 0:00:00
Collecting cffi>=1.12
Downloading cffi-1.15.1.tar.gz (508 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 508.5/508.5 kB 2.5 MB/s eta 0:00:00
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting pycparser
Downloading pycparser-2.21-py2.py3-none-any.whl (118 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 118.7/118.7 kB 3.1 MB/s eta 0:00:00
Collecting idna>=2.0
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.2/61.2 kB 5.7 MB/s eta 0:00:00
Building wheels for collected packages: aiohttp, cryptography, cffi, frozenlist, multidict, yarl
Building wheel for aiohttp (pyproject.toml): started
Building wheel for aiohttp (pyproject.toml): still running...
Building wheel for aiohttp (pyproject.toml): finished with status 'done'
Created wheel for aiohttp: filename=aiohttp-3.8.1-cp37-cp37m-linux_armv7l.whl size=700230 sha256=45665cd7e624d0fde75dd8d07e06bded04938a3a6a8f1f5f0e86b2fe9d89a8e5
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/1e/af/ee/a13202489533224c5759b6bce535ff77c36a6f81e14f1ce22f
Building wheel for cryptography (pyproject.toml): started
Building wheel for cryptography (pyproject.toml): still running...
Building wheel for cryptography (pyproject.toml): finished with status 'done'
Created wheel for cryptography: filename=cryptography-38.0.1-cp37-cp37m-linux_armv7l.whl size=1510123 sha256=845b71179b94612130542ea620c03d542db7c2c1eb8689ac0ae8c76d6203adf0
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/46/da/e6/ad849b0019fbd5452bb3a556435e342793f5c318eb1904463b
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): still running...
Building wheel for cffi (setup.py): finished with status 'done'
Created wheel for cffi: filename=cffi-1.15.1-cp37-cp37m-linux_armv7l.whl size=219926 sha256=bfabf0313534555071bfbefc51176518a55a712648029deda32f42c20d0107dd
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/04/6e/00/ce829dde11540887b1a7ce4905b5a63c36fa1d6ed8afeacf98
Building wheel for frozenlist (pyproject.toml): started
Building wheel for frozenlist (pyproject.toml): finished with status 'done'
Created wheel for frozenlist: filename=frozenlist-1.3.1-cp37-cp37m-linux_armv7l.whl size=66085 sha256=9b2a346cf91a191d8bfeac5cf85268826f6edc2e6e30e7f26fb7cc00ad185153
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/f0/9d/89/8e2638ce2a00b2b87c7fc90358f68bd47bab65d6d39c551702
Building wheel for multidict (pyproject.toml): started
Building wheel for multidict (pyproject.toml): finished with status 'done'
Created wheel for multidict: filename=multidict-6.0.2-cp37-cp37m-linux_armv7l.whl size=53838 sha256=e3a54b3bcf9ef7fbb41558de5a50b943dd796e98c2d2939ee0a302712af9599e
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/15/61/cc/d2c70368c0b1e2f98fc964d8f8071bea2cd98eb6642cc19939
Building wheel for yarl (pyproject.toml): started
Building wheel for yarl (pyproject.toml): finished with status 'done'
Created wheel for yarl: filename=yarl-1.8.1-cp37-cp37m-linux_armv7l.whl size=94578 sha256=107867b35871db5b23c8004dec4652f22be617109ce592320f79d412d45e4091
Stored in directory: /tmp/pip-ephem-wheel-cache-vvoei6ne/wheels/69/15/41/926bbadd69c537292261101b11de40a81fd63936164e035943
Successfully built aiohttp cryptography cffi frozenlist multidict yarl
Installing collected packages: voluptuous, crccheck, typing_extensions, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, asynctest, yarl, cffi, async-timeout, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zha-quirks
Attempting uninstall: voluptuous
Found existing installation: voluptuous 0.13.1
Uninstalling voluptuous-0.13.1:
Successfully uninstalled voluptuous-0.13.1
Attempting uninstall: crccheck
Found existing installation: crccheck 1.1
Uninstalling crccheck-1.1:
Successfully uninstalled crccheck-1.1
Attempting uninstall: typing_extensions
Found existing installation: typing_extensions 4.3.0
Uninstalling typing_extensions-4.3.0:
Successfully uninstalled typing_extensions-4.3.0
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: multidict
Found existing installation: multidict 6.0.2
Uninstalling multidict-6.0.2:
Successfully uninstalled multidict-6.0.2
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.3.0
Uninstalling frozenlist-1.3.0:
Successfully uninstalled frozenlist-1.3.0
Found existing installation: charset-normalizer 2.1.1
Uninstalling charset-normalizer-2.1.1:
Successfully uninstalled charset-normalizer-2.1.1
Attempting uninstall: attrs
Found existing installation: attrs 21.4.0
Uninstalling attrs-21.4.0:
Successfully uninstalled attrs-21.4.0
Attempting uninstall: asynctest
Found existing installation: asynctest 0.13.0
Uninstalling asynctest-0.13.0:
Successfully uninstalled asynctest-0.13.0
Attempting uninstall: yarl
Found existing installation: yarl 1.4.2
Uninstalling yarl-1.4.2:
Successfully uninstalled yarl-1.4.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.1
Uninstalling cffi-1.15.1:
Successfully uninstalled cffi-1.15.1
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.2
Uninstalling async-timeout-4.0.2:
Successfully uninstalled async-timeout-4.0.2
Attempting uninstall: aiosqlite
Found existing installation: aiosqlite 0.17.0
Uninstalling aiosqlite-0.17.0:
Successfully uninstalled aiosqlite-0.17.0
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.2.0
Uninstalling aiosignal-1.2.0:
Successfully uninstalled aiosignal-1.2.0
Attempting uninstall: cryptography
Found existing installation: cryptography 37.0.4
Uninstalling cryptography-37.0.4:
Successfully uninstalled cryptography-37.0.4
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.8.1
Uninstalling aiohttp-3.8.1:
Successfully uninstalled aiohttp-3.8.1
Attempting uninstall: zha-quirks
Found existing installation: zha-quirks 0.0.77
Uninstalling zha-quirks-0.0.77:
Successfully uninstalled zha-quirks-0.0.77
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
python-miio 0.5.11 requires importlib_metadata<2,>=1; python_version <= "3.7", but you have importlib-metadata 4.12.0 which is incompatible.
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 asynctest-0.13.0 attrs-22.1.0 cffi-1.15.1 charset-normalizer-2.1.1 crccheck-1.1 cryptography-38.0.1 frozenlist-1.3.1 idna-3.3 multidict-6.0.2 pycparser-2.21 typing_extensions-4.3.0 voluptuous-0.13.1 yarl-1.8.1 zha-quirks-0.0.79 zigpy-0.50.2
+ echo 13
+ sudo pip3 install --no-cache-dir --force-reinstall --upgrade zigpy-znp
Collecting zigpy-znp
Downloading zigpy_znp-0.8.2-py3-none-any.whl (122 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 122.8/122.8 kB 2.5 MB/s eta 0:00:00
Collecting jsonschema
Downloading jsonschema-4.16.0-py3-none-any.whl (83 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 83.1/83.1 kB 3.2 MB/s eta 0:00:00
Collecting pyserial-asyncio
Downloading pyserial_asyncio-0.6-py3-none-any.whl (7.6 kB)
Collecting coloredlogs
Downloading coloredlogs-15.0.1-py2.py3-none-any.whl (46 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 46.0/46.0 kB 6.7 MB/s eta 0:00:00
Collecting zigpy>=0.50.0
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 155.6/155.6 kB 2.4 MB/s eta 0:00:00
Collecting aiohttp
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.3/7.3 MB 2.7 MB/s eta 0:00:00
Tu dois être sur un pi ? Si oui la correction est en beta. Il faut accepter les beta (via son compte market, il y a une case a cocher), puis installer celle de zigbee en date de ce jour.
Je suis déjà en Beta
Comment savez vous que c’est bloque ? Au vu de vos logs c’est toujours en cours et l’installation des dépendances de ce plugin sont très longue. Elles ont été lancée quand ?
A 11 h ce matin , et j’ai eu des erreurs d’installation qui ont dépassé le timing
Donc c’est pas la dernière. Il y en a eu une autre depuis.
Loic,
J’ai vraiment besoin que tu m’aides , j’ai toute ma régul basé sur le zigbee
Et celle de 11h54 ne s’est pas installée?
se lancer dans une mise à jour alors que le support clame de ne pas toucher ^^
si c’est celle là
T’es gentil mais pourquoi ne pas la retirer cette mise à jour ?? Je maintiens juste mon système à jour … Sinon t’aurais pas une solution ?
Tu es toujours bloqué ? Tu as essayé de maj pip et python comme indiqué dans la doc en cas de pb avec les dépendances ?
oui tjrs bloqué et oui j’ai tout essayé
Tu es toujours a 11% ? Tu as tenté :
« Cela peut venir d’un soucis avec la version de pip3, pour corriger il faut aller dans la configuration de Jeedom, onglet OS/DB puis lancer la console OS et faire : sudo pip3 install --upgrade pip
puis relancer l’installation des dépendances. Si ca ne marche pas vous pouvez essayer de faire sudo apt remove -y python3-openssl;sudo pip3 install --upgrade pip
et relancer l’installation des dépendances. »
Ton log a pas avancé ?
