bonsoir,
j’ai un soucis concernant l’installation de la dépendance pour cet app, ESPeasy elle n’arrive pas a s’installer.
je copie un rapports si cela peu aider.
Début de l'installation
--2020-04-12 23:13:35-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1491 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 5.29M=0s
2020-04-12 23:13:35 (5.29 MB/s) - 'dependencies.sh' saved [1491/1491]
dependencies.sh: 3: [: espeasy: unexpected operator
Nodejs non installé
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Hit:4 http://ftp.debian.org/debian buster InRelease
Get:5 http://ftp.debian.org/debian buster-updates InRelease [49.3 kB]
Fetched 49.3 kB in 31s (1566 B/s)
Reading package lists...
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
dependencies.sh: 37: [: i686: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:5 http://ftp.debian.org/debian buster-updates InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 59: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
merci
