Probleme install dependance
J’avais une carte SD qui était H.S, j’ai réinstallé Jeedom sur une nouvelle carte SD et j’ai voulu remettre le plugin Zigbee2-MQTT
A chaque fois que je veux installer les dépendances il y a une erreur
Vous savez pourquoi ?
J’utilise une clé conbee 2,
je suis pas très à l’aise avec le texte en dessous
si quelqu’un a une idée ?
Bonne journée
#  INSTALL : Zigbee2MQTT + Client MQTT + Server MQTT  #
##### apt-get update in progress
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
Reading package lists...
##### Install Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u9).
make is already the newest version (4.2.1-1.2).
The following package was automatically installed and is no longer required:
raspi-gpio
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 187 not upgraded.
##### Install libsystemd-dev
libsystemd-dev is already the newest version (241-7~deb10u9+rpi1).
raspi-gpio
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
#####            Zigbee2MQTT 1/2                      #
##### Z2M VERSION to install : master
##### Z2M INSTALL DIR : /opt/zigbee2mqtt
##### Z2M DATA DIR : /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt
##### Remove Zigbee2mqtt service
##### Repare Zigbee2MQTT
node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
##### Supprime l'installation dans /opt/zigbee2mqtt
##### Download Zigbee2MQTT from git
Cloning into '/opt/zigbee2mqtt'...
##### Install or update NodeJs
e[38;5;79m2025-03-08 09:08:23 - Installing pre-requisitese[0m
apt-transport-https is already the newest version (1.8.2.3).
ca-certificates is already the newest version (20200601~deb10u2).
curl is already the newest version (7.64.0-4+deb10u9).
gnupg is already the newest version (2.2.12-1+rpi1+deb10u2).
raspi-gpio
e[1;34m2025-03-08 09:08:37 - Repository configured successfully.e[0m
e[38;5;79m2025-03-08 09:08:37 - To install Node.js, run: apt-get install nodejs -ye[0m
e[38;5;79m2025-03-08 09:08:37 - You can use N|solid Runtime as a node.js alternativee[0m
e[1;32m2025-03-08 09:08:37 - To install N|solid Runtime, run: apt-get install nsolid -y
e[0m
nodejs is already the newest version (20.18.3-1nodesource1).
raspi-gpio
##### WARNING : NodeJS 01 installed. This plugin need 20 minimal version
./install_nodejs.sh: line 44: jq: command not found
Impossible de recuperer la version de pnpm depuis /opt/zigbee2mqtt/package.json
####### Installation de pnpm@10.4.1
#    INSTALLING : Mosquitto (server)                  #
mosquitto is already the newest version (1.5.7-1+deb10u1).
raspi-gpio
#    INSTALLING : Mosquitto for Php                   #
Mosquitto for Php is already installed, nothing to do
#####            Zigbee2MQTT 2/2                      #
##### Compile Zigbee2MQTT                             #
sudo: pnpm: command not found
##### Configure Zigbee2MQTT
#                         END                         #
Votre système, debian 10, n’est pas à jour, il faut passer à debian 11.
Tonio16 tu es trop gentil !
temps de lecture < 1 minute.
Cordialement
Merci de votre retour rapide, je vais essayer de faire ça.
Pour passer sur debian 11 il faut se connecter directement sur la raspberry ?
Jein,
Cela passe par une réinstalle complète. Le moteur de recherche est votre ami.
Suivez ce tutoriel :
Si vous n’avez pas de disque externe, pas de problème, le tutoriel s’applique aussi pour une carte MicroSD.
Bonjour Fabrice, super merci
Je vais essayer de le faire
Bonne journée a vous
