Problème index table ‘cache’ suite mise à jour 4.4.14
Bonjour.
Je viens de passer ma prod en 4.4.14 et il y a un petit souci sur la partie BD au niveau de la table « cache »
Si j’essaie de corriger, l’erreur est toujours là.
Log de la mise à jour de jeedom
[START UPDATE]
[PROGRESS][1]
****Update from 4.4.13 (2024-08-26 08:14:06)****
Parameters : {"preUpdate":"0","backup::before":"1","core":"1","force":"0","plugins":"0","update::reapply":""}
Send begin of update event...OK
[PROGRESS][5]
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2024-08-26 08:14:08***************
Send begin backup event...OK
Checking files rights...
OK
Checking  database...
jeedom.event
note     : The storage engine for the table doesn't support check
OK
Backing up database...
OK
Cache persistence:
OK
Creating archive...
OK
Cleaning old backup...OK
Limiting backup size to 1000 Mb...
Delete: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_PROD-4.4.13-2024-08-22-03h32.tar.gz
OK
Backup name: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_PROD-4.4.13-2024-08-26-08h14.tar.gz
OK
Send end backup event...OK
Backup operation duration: 33s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
[PROGRESS][10]
[PROGRESS][15]
Download url : https://github.com/jeedom/core/archive/master.zip
Download in progress...--2024-08-26 08:14:41--  https://github.com/jeedom/core/archive/master.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response...
302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/master [following]
--2024-08-26 08:14:42--  https://codeload.github.com/jeedom/core/zip/refs/heads/master
Resolving codeload.github.com (codeload.github.com)... 140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 88164315 (84M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
     0K ........ ........ ........ ........ ........ ........  3% 18.0M 5s
  3072K ........ ........ ........ ........ ........ ........  7% 31.6M 3s
  6144K ........ ........ ........ ........ ........ ........ 10% 18.0M 4s
  9216K ........ ........ ........ ........ ........ ........ 14% 19.1M 4s
 12288K ........ ........ ........ ........ ........ ........ 17% 18.1M 3s
 15360K ..
...... ........ ........ ........ ........ ........ 21% 18.3M 3s
 18432K ........ ........ ........ ........ ........ ........ 24% 18.7M 3s
 21504K ........ ........ ........ ........ ........ ........ 28% 19.0M 3s
 24576K ........ ........ ........ ........ ........ ........ 32% 19.4M 3s
 27648K ........ ........ ........ ........ ........ ........ 35% 20.2M 3s
 30720K ........ ........ ........ ........ ........ ........ 39% 20.3M 3s
 33792K ........ ........ ........ ........ ..
...... ........ 42% 20.8M 2s
 36864K ........ ........ ........ ........ ........ ........ 46% 19.9M 2s
 39936K ........ ........ ........ ........ ........ ........ 49% 14.5M 2s
 43008K ........ ........ ........ ........ ........ ........ 53% 11.0M 2s
 46080K ........ ........ ........ ........ ........ ........ 57% 11.4M 2s
 49152K ........ ........ .....
... ........ ........ ........ 60% 12.2M 2s
 52224K ........ ........ ........ ........ ........ ........ 64% 9.66M 2s
 55296K ........ ........ ........ ........ ........ ........ 67% 9.75M 2s
 58368K ........ ........ ........ ........ ........ ........ 71% 10.4M 2s
 61440K ..
...... ........ ........ ........ ........ ........ 74% 11.3M 1s
 64512K ........ ........ ........ ........ ........ ........ 78% 11.9M 1s
 67584K ........ ........ ........ ........ ........ ........ 82% 12.4M 1s
 70656K ........ ........ ........ ........ ........ ........ 85% 10.7M 1s
 73728K ....
.... ........ ........ ........ ........ ........ 89% 9.80M 1s
 76800K ........ ........ ........ ........ ........ ........ 92% 8.39M 0s
 79872K ........ ........ ........ ........ ........ ........ 96% 8.41M 0s
 82944K .....
... ........ ........ ........ ........ ........ 99% 9.28M 0s
 86016K .                                                    100% 6.28M=6.3s
2024-08-26 08:14:48 (13.4 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [88164315/88164315]
[PROGRESS][25]
OK
Cleaning folders...OK
[PROGRESS][30]
Create temporary folder...OK
[PROGRESS][35]
Unzip in progress...
OK
[PROGRESS][40]
Clean temporary files (tmp)...OK
Disable all task
kill: (2013766): No such process
kill: (87896): No such process
kill: (2013825): No such process
kill: (2013818): No such process
. OK
Disable all scenario............................
kill: (2405410): No such process
................... OK
[PROGRESS][45]
Update modification date of unzip file...OK
[PROGRESS][47]
Moving files...
Ignore file /tmp/jeedom_unzip/core-master///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/pt_PT/noteVersion.md because size is 0
OK
[PROGRESS][50]
Remove temporary files...OK
[PROGRESS][52]
Remove useless files...
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
OK
[PROGRESS][53]
Update jeedom information date...
OK
[PROGRESS][59]
[PROGRESS][60]
Check jeedom consistency...
[START CONSISTENCY]
[START CHECK AND FIX DB]
Fix : ALTER TABLE `cache` MODIFY COLUMN `datetime`  int(11) NULL
Fix : ALTER TABLE `cache` MODIFY COLUMN `datetime`  int(11) NULL***ERROR*** [MySQL] Error code : 22003 (1264). Out of range value for column 'datetime' at row 1  : ALTER TABLE `cache` MODIFY COLUMN `datetime`  int(11) NULL
[END CHECK AND FIX DB]
Check jeedom package...OK
Check jeedom database...
Check crons...
Check filesystem right...
OK
Check jeedom object...
OK
Check jeedom cmd... OK
Set cache hour...OK
Check composer...OK
Check nodejs...
Hit:1 http://deb.debian.org/debian bullseye InRelease
Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Fetched 92.4 kB in 1s (63.7 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (2.2.4).
git is already the newest version (1:2.30.2-1+deb11u2).
lsb-release is already the newest version (11.1.0).
0 upgraded, 0 newly installed, 0 to remove and 195 not upgraded.
[Check Version NodeJS actuelle : v18.17.1 : [  OK  ]
OK
[END CONSISTENCY]
OK
Check update...OK
***************Jeedom is up to date in 4.4.14***************
[PROGRESS][75]
[PROGRESS][90]
Check update
OK
[PROGRESS][95]
Enable scenario : OK
Enable task : OK
Check Network Conf : OK
[PROGRESS][100]
Launch cron dependancy plugins...OK
Send end of update event...OK
Update duration : 68s
[END UPDATE SUCCESS]
Quelle procédure à suivre pour corriger cette erreur ?
Il faut vider le cache avant
Je viens de vider le cache via ‘vider toutes les données du cache’ et j’ai toujours le souci.
C’est le cache mysql, il faut changer le moteur de cache vider le cache et normalement ca devrait rentrer dans l’ordre.
Est-ce qu’un truncate de la table sql ‘cache’ est suffisant. Car changer de moteur de cache implique pas mal de chose dont un redémarrage
Oui ça marche aussi le truncate
Bonjour Loic
J’ai le même problème que Blablatus, C’est quoi le le truncate , et comment faire
peut tu m’expliquer la marche à suivre, pour régler le problème.
OK merci @Loic
Après y a une chose que je ne comprends pas, sur mes 3 box jeedom qui sont toutes sur la dernière version stable de jeedom, y en a une pour laquelle la table ‘cache’ n’était pas vide. Pourtant, je n’ai jamais changé le moteur de cache.
Bonjour.
Voilà ce que j’ai fait :
Aller dans OS/DB
Choisir administration base de données
Taper la commande
TRUNCATE TABLE ‘cache’
et faire exécuter
ça va vider la table sans toucher à sa structure. Après tu pourras corriger dans ‘vérification de la base de données’
Pour info cette table ne sert a rien si vous n’utilisez pas le cache mysql donc l’erreur n’est pas genante.
Coucou, j’ai fai la manip , mais le resultat est le suivant
La requete est pas bonne c’est
truncate table cache
Merci Loic, c’est OK
