J’ai une box Luna avec les plugins zwave-js et zigbee officiels qui fonctionnent correctement.
Ne pouvant pas configurer les timers de mes arrosages tuya, je voudrai tenter ce nouveau plugin.
Je sais que les deux plugins zigbee ne peuvent pas fonctionner en même temps mais je but déjà sur l’installation des dépendances:
+ touch /tmp/jeedom_install_in_progress_z2m
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
Launch pre-install of z2m dependancy
+ echo 3
+ sudo apt update
Hit:1 https://deb.nodesource.com/node_16.x bullseye InRelease
Hit:2 https://deb.debian.org/debian bullseye InRelease
Hit:3 https://deb.debian.org/debian-security bullseye-security InRelease
Hit:4 https://deb.debian.org/debian bullseye-updates InRelease
Hit:5 https://deb.debian.org/debian bullseye-backports InRelease
Reading package lists...
Building dependency tree...
Reading state information...
22 packages can be upgraded. Run 'apt list --upgradable' to see them.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
chromium : Depends: chromium-common (= 113.0.5672.126-1~deb11u1) but 114.0.5735.90-2~deb11u1 is to be installed
chromium-common : Breaks: chromium (< 114.0.5735.90-2~deb11u1) but 113.0.5672.126-1~deb11u1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
+ echo 5
+ sudo systemctl restart apache2
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ echo 'Launch post-install of z2m dependancy'
+++ dirname /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
++ cd /var/www/html/core/class/../../plugins/z2m/resources
++ pwd
+ BASEDIR=/var/www/html/plugins/z2m/resources
+ '[' -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ']'
+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 'Backup configuration'
+ cp -R data data-backup
+ echo 'Update z2m (git)'
Update z2m (git)
+ git config --global --add safe.directory /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ git reset --hard HEAD
HEAD is now at 21f5125 chore: release 1.31.2
+ git pull
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
Already up to date.
+ npm ci
added 795 packages, and audited 796 packages in 1m
82 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
+ npm run build
> zigbee2mqtt@1.31.2 build
> tsc && node index.js writehash
+ echo 'Restore configuration'
+ cp -R data-backup/configuration.yaml data
+ rm -rf data-backup
+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 7
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
+ rm /tmp/jeedom_install_in_progress_z2m
Du coup, j’ai aussi des erreurs avec le démarrage du plugin:
[2023-06-16 16:15:08]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2023-06-16 16:15:09]ERROR : Erreur sur la fonction deamon_start du plugin : Call to undefined function yaml_parse_file()
J’ai suivi le post par rapport à l’installation et j’ai bien le plugin MQTT Manager utilisé par le plugin zwave.
J’ai testé avec la version officielle et la version beta du plugin.
Une idée ?
Paul.
