Problème d'installation conbee2
Je suis presque débutant sur Jeedom
Je viens de recevoir une clé Conbee2 et je n’arrive pas à installer Deconz
J ai un problème le démon est toujours NOK
Je pense avoir avoir bien suivi les explications d’installation, mais j’ai du rater quelque chose
Ci joint le log de l’install
  •         Installation deconz                      *
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
Reading package lists…
Building dependency tree…
Reading state information…
libqt5serialport5 is already the newest version.
libqt5websockets5 is already the newest version.
You might want to run ‹ apt-get -f install › to correct these:
The following packages have unmet dependencies:
deconz : Depends: libqt5widgets5 but it is not going to be installed
Depends: libqt5gui5 but it is not going to be installed
Depends: libqt5sql5 but it is not going to be installed
Depends: sqlite3 but it is not going to be installed
E: Unmet dependencies. Try ‹ apt-get -f install › with no packages (or specify a solution).
sqlite3 : Depends: libsqlite3-0 (= 3.16.2-3~bpo8+1) but 3.8.7.1-1+deb8u2 is to be installed
It’s arm64, RPI
converted ‹ https://images.jeedom.com/resources/deconz/arm64/deconz.deb › (ANSI_X3.4-1968) → ‹ https://images.jeedom.com/resources/deconz/arm64/deconz.deb › (UTF-8)
–2020-03-08 16:01:11-- https://images.jeedom.com/resources/deconz/arm64/deconz.deb
Resolving images.jeedom.com (images.jeedom.com)… 213.32.73.75
Connecting to images.jeedom.com (images.jeedom.com)|213.32.73.75|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 5171268 (4.9M) [application/x-debian-package]
Saving to: ‹ /tmp/deconz.deb ›
 0K .......... .......... .......... .......... ..........  0%  652K 8s
50K .......... .......... .......... .......... ..........  1% 1.28M 6s
100K … … … … … 2% 540K 7s
150K … … … … … 3% 795K 7s
200K … … … … … 4% 19.2M 5s
250K … … … … … 5% 20.8M 4s
300K … … … … … 6% 1.71M 4s
350K … … … … … 7% 1.27M 4s
400K … … … … … 8% 518K 4s
450K … … … … … 9% 2.67M 4s
500K … … … … … 10% 2.35M 4s
550K … … … … … 11% 1.86M 4s
600K … … … … … 12% 977K 4s
650K … … … … … 13% 1.29M 4s
700K … … … … … 14% 1.31M 4s
750K … … … … … 15% 1.28M 4s
800K … … … … … 16% 545K 4s
850K … … … … … 17% 8.03M 4s
900K … … … … … 18% 1.56M 3s
950K … … … … … 19% 1.28M 3s
1000K … … … … … 20% 1.31M 3s
1050K … … … … … 21% 1.28M 3s
1100K … … … … … 22% 1.20M 3s
1150K … … … … … 23% 835K 3s
1200K … … … … … 24% 1.29M 3s
1250K … … … … … 25% 1.32M 3s
1300K … … … … … 26% 1.13M 3s
1350K … … … … … 27% 1.30M 3s
1400K … … … … … 28% 1.12M 3s
1450K … … … … … 29% 1.34M 3s
1500K … … … … … 30% 1.32M 3s
1550K … … … … … 31% 1.15M 3s
1600K … … … … … 32% 1.32M 3s
1650K … … … … … 33% 1.14M 3s
1700K … … … … … 34% 1.33M 3s
1750K … … … … … 35% 1.31M 3s
1800K … … … … … 36% 1.15M 3s
1850K … … … … … 37% 1.32M 3s
1900K … … … … … 38% 1.11M 3s
1950K … … … … … 39% 1.37M 2s
2000K … … … … … 40% 1.29M 2s
2050K … … … … … 41% 1.14M 2s
2100K … … … … … 42% 1.36M 2s
2150K … … … … … 43% 1.12M 2s
2200K … … … … … 44% 1.31M 2s
2250K … … … … … 45% 1.35M 2s
2300K … … … … … 46% 1.14M 2s
2350K … … … … … 47% 1.10M 2s
2400K … … … … … 48% 1.31M 2s
2450K … … … … … 49% 1.36M 2s
2500K … … … … … 50% 1.11M 2s
2550K … … … … … 51% 701K 2s
2600K … … … … … 52% 5.24M 2s
2650K … … … … … 53% 1.22M 2s
2700K … … … … … 54% 1.32M 2s
2750K … … … … … 55% 1.15M 2s
2800K … … … … … 56% 1.34M 2s
2850K … … … … … 57% 1.14M 2s
2900K … … … … … 58% 1.32M 2s
2950K … … … … … 59% 1.31M 2s
3000K … … … … … 60% 1.14M 2s
3050K … … … … … 61% 1.31M 2s
3100K … … … … … 62% 1.13M 2s
3150K … … … … … 63% 1.34M 1s
3200K … … … … … 64% 1.32M 1s
3250K … … … … … 65% 1.14M 1s
3300K … … … … … 66% 1.35M 1s
3350K … … … … … 67% 1.15M 1s
3400K … … … … … 68% 1.36M 1s
3450K … … … … … 69% 1.30M 1s
3500K … … … … … 70% 1.16M 1s
3550K … … … … … 71% 1.23M 1s
3600K … … … … … 72% 1.31M 1s
3650K … … … … … 73% 1.32M 1s
3700K … … … … … 74% 1.13M 1s
3750K … … … … … 75% 1.34M 1s
3800K … … … … … 76% 1.15M 1s
3850K … … … … … 77% 1.31M 1s
3900K … … … … … 78% 1.36M 1s
3950K … … … … … 79% 1.14M 1s
4000K … … … … … 80% 1.32M 1s
4050K … … … … … 81% 1.14M 1s
4100K … … … … … 82% 1.33M 1s
4150K … … … … … 83% 1.33M 1s
4200K … … … … … 84% 1.15M 1s
4250K … … … … … 85% 1.36M 1s
4300K … … … … … 86% 1.12M 1s
4350K … … … … … 87% 1.32M 1s
4400K … … … … … 88% 1.36M 0s
4450K … … … … … 89% 1.15M 0s
4500K … … … … … 90% 1.32M 0s
4550K … … … … … 91% 1.15M 0s
4600K … … … … … 92% 1.35M 0s
4650K … … … … … 93% 1.30M 0s
4700K … … … … … 94% 1.15M 0s
4750K … … … … … 95% 1.24M 0s
4800K … … … … … 96% 1.31M 0s
4850K … … … … … 97% 1.37M 0s
4900K … … … … … 98% 1.15M 0s
4950K … … … … … 99% 683K 0s
5000K … … … … … 99% 17.6M 0s
5050K 100% 127G=4.0s
2020-03-08 16:01:15 (1.22 MB/s) - ‹ /tmp/deconz.deb › saved [5171268/5171268]
dpkg: error: dpkg status database is locked by another process
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Ign http://ftp.debian.org jessie-backports InRelease
Ign http://ftp.debian.org jessie-proposed-updates InRelease
Hit http://security.debian.org jessie/updates InRelease
Hit http://ftp.debian.org jessie Release.gpg
Ign http://ftp.debian.org jessie-backports Release.gpg
Hit http://ftp.debian.org jessie-updates/main Sources
Hit http://ftp.debian.org jessie-updates/contrib Sources
Get:1 http://security.debian.org jessie/updates/main Sources [341 kB]
Hit http://ftp.debian.org jessie-updates/non-free Sources
Ign http://ftp.debian.org jessie-proposed-updates Release.gpg
Get:2 http://security.debian.org jessie/updates/contrib Sources [1439 B]
Get:3 http://security.debian.org jessie/updates/non-free Sources [1637 B]
Ign http://ftp.debian.org jessie-backports/main Sources/DiffIndex
Ign http://ftp.debian.org jessie-backports/contrib Sources/DiffIndex
Hit http://oph.mdrjr.net all InRelease
Ign http://ftp.debian.org jessie-backports/non-free Sources/DiffIndex
Hit http://repo.jeedom.com stable InRelease
Ign http://ftp.debian.org jessie-backports/main arm64 Packages/DiffIndex
Ign http://ftp.debian.org jessie-backports/contrib arm64 Packages/DiffIndex
Hit http://oph.mdrjr.net jessie InRelease
Ign http://ftp.debian.org jessie-backports/non-free arm64 Packages/DiffIndex
Get:4 http://oph.mdrjr.net all/c2 arm64 Packages
Ign http://ftp.debian.org jessie-proposed-updates/contrib Sources/DiffIndex
Hit http://oph.mdrjr.net all/c2 arm64 Packages
Ign http://ftp.debian.org jessie-proposed-updates/non-free Sources/DiffIndex
Ign http://ftp.debian.org jessie-proposed-updates/main Sources/DiffIndex
Ign http://ftp.debian.org jessie-proposed-updates/contrib arm64 Packages/DiffIndex
Get:5 http://oph.mdrjr.net all/main arm64 Packages
Ign http://ftp.debian.org jessie-proposed-updates/non-free arm64 Packages/DiffIndex
Ign http://ftp.debian.org jessie-proposed-updates/main arm64 Packages/DiffIndex
Get:6 http://oph.mdrjr.net all/testing arm64 Packages
Get:7 http://oph.mdrjr.net all/c2 Translation-en [321 B]
Hit http://ftp.debian.org jessie/main Sources
Hit http://oph.mdrjr.net all/main arm64 Packages
Hit http://ftp.debian.org jessie/contrib Sources
Hit http://ftp.debian.org jessie/non-free Sources
Get:8 http://oph.mdrjr.net all/main Translation-en [323 B]
Hit http://oph.mdrjr.net all/testing arm64 Packages
Get:9 http://oph.mdrjr.net all/testing Translation-en [326 B]
Get:10 http://oph.mdrjr.net jessie/backports arm64 Packages
Get:11 http://oph.mdrjr.net jessie/main arm64 Packages
Get:12 http://oph.mdrjr.net jessie/backports Translation-en [331 B]
Get:13 http://oph.mdrjr.net jessie/main Translation-en [326 B]
Get:14 http://oph.mdrjr.net all/c2 Translation-en [321 B]
Hit http://oph.mdrjr.net jessie/backports arm64 Packages
Get:15 http://oph.mdrjr.net all/main Translation-en [323 B]
Hit http://oph.mdrjr.net jessie/main arm64 Packages
Hit http://repo.jeedom.com stable/main arm64 Packages
Get:16 http://oph.mdrjr.net all/testing Translation-en [326 B]
Get:17 http://oph.mdrjr.net jessie/backports Translation-en [331 B]
Get:18 http://oph.mdrjr.net jessie/main Translation-en [326 B]
Get:19 http://oph.mdrjr.net all/c2 Translation-en [321 B]
Get:20 http://oph.mdrjr.net all/main Translation-en [323 B]
Get:21 http://oph.mdrjr.net all/testing Translation-en [326 B]
Get:22 http://oph.mdrjr.net jessie/backports Translation-en [331 B]
Get:23 http://oph.mdrjr.net jessie/main Translation-en [326 B]
Get:24 http://oph.mdrjr.net all/c2 Translation-en [321 B]
Get:25 http://oph.mdrjr.net all/main Translation-en [323 B]
Get:26 http://oph.mdrjr.net all/testing Translation-en [326 B]
Get:27 http://oph.mdrjr.net jessie/backports Translation-en [331 B]
Ign http://ftp.debian.org jessie-backports/contrib Translation-en
Ign http://ftp.debian.org jessie-backports/main Translation-en
Ign http://ftp.debian.org jessie-backports/non-free Translation-en
Get:28 http://oph.mdrjr.net jessie/main Translation-en [326 B]
Ign http://ftp.debian.org jessie-proposed-updates/contrib Translation-en
Ign http://ftp.debian.org jessie-proposed-updates/main Translation-en
Ign http://ftp.debian.org jessie-proposed-updates/non-free Translation-en
Err http://ftp.debian.org jessie-backports/main Sources
404 Not Found [IP: 130.89.148.12 80]
Err http://ftp.debian.org jessie-backports/contrib Sources
Err http://ftp.debian.org jessie-backports/non-free Sources
Err http://ftp.debian.org jessie-backports/main arm64 Packages
Err http://ftp.debian.org jessie-backports/contrib arm64 Packages
Err http://ftp.debian.org jessie-backports/non-free arm64 Packages
Err http://ftp.debian.org jessie-proposed-updates/contrib Sources
Err http://ftp.debian.org jessie-proposed-updates/non-free Sources
Err http://ftp.debian.org jessie-proposed-updates/main Sources
Err http://ftp.debian.org jessie-proposed-updates/contrib arm64 Packages
Err http://ftp.debian.org jessie-proposed-updates/non-free arm64 Packages
Get:29 http://oph.mdrjr.net all/c2 Translation-en [321 B]
Err http://ftp.debian.org jessie-proposed-updates/main arm64 Packages
Ign http://oph.mdrjr.net all/c2 Translation-en
Get:30 http://oph.mdrjr.net all/main Translation-en [323 B]
Ign http://oph.mdrjr.net all/main Translation-en
Get:31 http://oph.mdrjr.net all/testing Translation-en [326 B]
Ign http://oph.mdrjr.net all/testing Translation-en
Get:32 http://oph.mdrjr.net jessie/backports Translation-en [331 B]
Ign http://oph.mdrjr.net jessie/backports Translation-en
Get:33 http://oph.mdrjr.net jessie/main Translation-en [326 B]
Ign http://oph.mdrjr.net jessie/main Translation-en
Get:34 http://repo.jeedom.com stable/main Translation-en [277 B]
Get:35 http://repo.jeedom.com stable/main Translation-en [277 B]
Get:36 http://repo.jeedom.com stable/main Translation-en [277 B]
Get:37 http://repo.jeedom.com stable/main Translation-en [277 B]
Get:38 http://repo.jeedom.com stable/main Translation-en [277 B]
Ign http://repo.jeedom.com stable/main Translation-en
W: There is no public key available for the following key IDs:
AA8E81B4331F7F50
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-updates/InRelease Unable to find expected entry ‹ main/binary-arm64/Packages › in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://security.debian.org/dists/jessie/updates/InRelease Unable to find expected entry ‹ main/binary-arm64/Packages › in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie/Release Unable to find expected entry ‹ main/binary-arm64/Packages › in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/main/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/contrib/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/non-free/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/main/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/contrib/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/non-free/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/contrib/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/non-free/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/main/source/Sources 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/contrib/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/non-free/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-proposed-updates/main/binary-arm64/Packages 404 Not Found [IP: 130.89.148.12 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
WARNING: apt does not have a stable CLI interface yet. Use with caution in scripts.
Correcting dependencies… Done
The following package was automatically installed and is no longer required:
linux-headers-3.14.29+
Use ‹ apt-get autoremove › to remove it.
The following extra packages will be installed:
libatk1.0-0 libatk1.0-data libcairo2 libdatrie1 libdrm2 libegl1-mesa libgbm1
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgl1-mesa-glx libglapi-mesa
libgles2-mesa libgraphite2-3 libgtk2.0-0 libgtk2.0-common libharfbuzz0b
libjasper1 libmtdev1 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0
libqt5gui5 libqt5sql5 libqt5widgets5 libsqlite3-0 libthai-data libthai0
libwayland-client0 libwayland-server0 libxcb-icccm4 libxcb-image0
libxcb-keysyms1 libxcb-randr0 libxcb-render-util0 libxcb-render0
libxcb-shape0 libxcb-shm0 libxcb-util0 libxcb-xfixes0 libxcb-xkb1
libxcomposite1 libxcursor1 libxinerama1 libxkbcommon-x11-0 libxkbcommon0
libxrandr2 sqlite3
Suggested packages:
librsvg2-common gvfs libjasper-runtime sqlite3-doc
Recommended packages:
libgl1-mesa-dri hicolor-icon-theme libgtk2.0-bin libqt5sql5-sqlite
libqt5sql5-mysql libqt5sql5-odbc libqt5sql5-psql
libatk1.0-0 libatk1.0-data libcairo2 libdatrie1 libegl1-mesa libgbm1
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgles2-mesa libgraphite2-3
libgtk2.0-0 libgtk2.0-common libharfbuzz0b libjasper1 libmtdev1
libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libqt5gui5 libqt5sql5
libqt5widgets5 libthai-data libthai0 libwayland-client0 libwayland-server0
libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-randr0
libxcb-render-util0 libxcb-render0 libxcb-shape0 libxcb-shm0 libxcb-util0
libxcb-xfixes0 libxcb-xkb1 libxcomposite1 libxcursor1 libxinerama1
libxkbcommon-x11-0 libxkbcommon0 libxrandr2 sqlite3
The following packages will be upgraded:
libdrm2 libgl1-mesa-glx libglapi-mesa libsqlite3-0
4 upgraded, 43 newly installed, 0 to remove and 178 not upgraded.
1 not fully installed or removed.
Need to get 5835 kB/14.0 MB of archives.
After this operation, 54.2 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
libdrm2 libgl1-mesa-glx libglapi-mesa libgles2-mesa libgbm1 libegl1-mesa
libsqlite3-0 sqlite3
E: There are problems and -y was used without --force-yes
  •         Installation terminée                    *
et le log Deconz
[2020-03-08 16:57:44][ERROR] : Attention je pense qu’il y a un soucis avec le démon que j’ai relancé plus de 3 fois consecutivement
File « /var/www/html/plugins/deconz/resources/deconzd/deconzd.py », line 32, in
from websocket import create_connection
ImportError: No module named ‹ websocket ›
[2020-03-08 16:58:17][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
[2020-03-08 16:58:51][ERROR] : Attention je pense qu’il y a un soucis avec le démon que j’ai relancé plus de 3 fois consecutivement
[2020-03-08 16:59:25][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
[2020-03-08 17:00:23][ERROR] : Attention je pense qu’il y a un soucis avec le démon que j’ai relancé plus de 3 fois consecutivement
[2020-03-08 17:00:57][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
[2020-03-08 17:01:11][ERROR] : Attention je pense qu’il y a un soucis avec le démon que j’ai relancé plus de 3 fois consecutivement
[2020-03-08 17:01:44][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
[2020-03-08 17:05:04][ERROR] : Attention je pense qu’il y a un soucis avec le démon que j’ai relancé plus de 3 fois consecutivement
[2020-03-08 17:05:37][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
Hello
Je crois que deconz ne fonctionne. Que sur debian 9 et non sur debian Jessy comme chez toi
Il faut tu mettes à jour l os de ta box
Tu as quelle box ?
Une Smart, et c’est quoi la marche à suivre pour mettre à jour l’OS
Hello
Soit tu passes par le
Menu spécifique pour mettre à jour l os
Ou
Alors tu passes par le mode recovery
https://jeedom.github.io/documentation/howto/fr_FR/recovery_mode_jeedom_smart
Et tu remets ta sauvegarde apres la mise à jour
Ok merci pour la rapidité de ta réponse
J essaye demain
j’ai essayé la méthode recovery mode mais rien à faire ni avec une clé 16GB ni avec une clé neuve de 32GB
J’ai tenté une sauvegarde image , la apparemment ç’a a fonctionné, mais à la fin plus d’accès à ma smart
Je tape l’adresse (192.168.1.36)mais rien à faire , j’ai une page blanche
