Probleme dépendence installation Yarn
depuis la MAJ 9.5.1 Z-Wave JS et MAJ jeedom 4.3.21 je n’arrive plus a faire fonctionner le plugins.
Voici les éléments de configuration et de santé :
Santé de Jeedom :
Voici l’installe des dépendances :
+ touch /tmp/jeedom_install_in_progress_zwavejs
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ echo 'Pre installation de l'\''installation/mise à jour des dépendances zwavejs'
Pre installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
++ cd /var/www/html/core/class/../../plugins/zwavejs/resources
++ pwd
+ BASEDIR=/var/www/html/plugins/zwavejs/resources
+ cd /var/www/html/plugins/zwavejs/resources
+ source ../core/config/zwavejs.config.ini
+ echo 'Wanted Version: 9.5.1'
+ rm -R zwave-js-ui
+ git clone --branch v9.5.1 --depth 1 https://github.com/zwave-js/zwave-js-ui
Cloning into 'zwave-js-ui'...
Note: checking out 'e4c1eb598a53f90153058272d4306df784e76ecb'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b
+ echo 'Pre install finished'
+ echo 3
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ echo 'Post installation de l'\''installation/mise à jour des dépendances zwavejs'
Post installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
++ pwd
+ cd zwave-js-ui
+ sudo yarn install
yarn install v1.22.21
info No lockfile found.
warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
[1/5] Validating package.json...
[2/5] Resolving packages...
warning csurf@1.11.0: Please use another csrf package
warning native-url > querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
warning @types/extract-zip@2.0.1: This is a stub types definition. extract-zip provides its own type definitions, so you do not need this installed.
warning vite-plugin-pwa > workbox-build > rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
warning vite-plugin-pwa > workbox-build > @surma/rollup-plugin-off-main-thread > magic-string > sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
[3/5] Fetching packages...
error SyntaxError: /usr/local/share/.cache/yarn/v6/npm-ajv-8.12.0-d1a0527323e22f53562c567c00991577dfbe19d1-integrity/node_modules/ajv/.yarn-metadata.json: Unexpected end of JSON input
at JSON.parse ()
at /usr/lib/node_modules/yarn/lib/cli.js:1629:59
at Generator.next ()
at step (/usr/lib/node_modules/yarn/lib/cli.js:310:30)
at /usr/lib/node_modules/yarn/lib/cli.js:321:13
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
+ sudo yarn run build
yarn run v1.22.21
$ npm-run-all 'build:*'
/bin/sh: 1: npm-run-all: not found
error Command failed with exit code 127.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
+ chown -R www-data:www-data CHANGELOG.md LICENSE README.md SECURITY.md api certs docker docs esbuild-register.js genereteDocs.ts index.html kubernetes kustomization.yaml nodemon.json package-lock.json package.json package.sh pkg public server_config.js snippets src store test tsconfig.eslint.json tsconfig.json vite.config.js wallaby.js
+ '[' -e /dev/ttyAMA0 ']'
+ sudo sed -i 's/console=ttyAMA0,115200//; s/kgdboc=ttyAMA0,115200//' /boot/cmdline.txt
+ sudo sed -i 's|[^:]*:[^:]*:respawn:/sbin/getty[^:]*ttyAMA0[^:]*||' /etc/inittab
sed: can't read /etc/inittab: No such file or directory
+ '[' -e /dev/ttymxc0 ']'
+ sudo systemctl mask serial-getty@ttyAMA0.service
+ sudo systemctl stop serial-getty@ttyAMA0.service
++ tr -d ' '
++ grep Revision /proc/cpuinfo
++ cut -d: -f2
+ RPI_BOARD_REVISION=c03114
+ [[ c03114 == a\8 ]]
+ [[ c03114 == a\d ]]
+ echo 'Everything is successfully installed!'
+ echo 4
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zwavejs
+ rm /tmp/jeedom_install_in_progress_zwavejs
On peut voir qu’aprés le sudo yarn install tout se passe pas trés bien.
J’ai essayé de réinstaller les dépendances plusieurs fois, remettre a jour jeedom…
Si vous avez une idée je vous remercie.
Rodinrott
Essaye de rebooter. Puis immédiatement après de lancer les dépendances. Et insiste :wink:
Bonjour Madcow,
Merci pour ta réponse, j’ai essayé a l’instant , sans succés.
Rodinrott
Là je sèche.
Les cas précédents c’étaient soit pas assez de RAM (mais tu as redémarré et ta taille de RAM est confortable) soit pas assez de swap (mais les retours avec 1024 comme tu as étaient OK).
A tester…
En SSH, faite :
su -
Pour être root
Puis, exécutez cette commande :
yarn cache clean
Et relancez l’installation des dépendances.
jeedom@jeedom:~ $ sudo yarn cache clean
[sudo] Mot de passe de jeedom :
yarn cache v1.22.21
success Cleared cache.
Done in 17.78s.
voici le résultat :
+ echo 1
+ echo 2
++ pwd
+ rm -R zwave-js-ui
git checkout -b
+ echo 3
++ pwd
+ cd zwave-js-ui
+ sudo yarn install
warning vite-plugin-pwa > workbox-build > @rollup/plugin-replace > magic-string > sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
info There appears to be trouble with your network connection. Retrying...
error Error: https://registry.yarnpkg.com/@zwave-js/config/-/config-12.4.1.tgz: ESOCKETTIMEDOUT
at ClientRequest. (/usr/lib/node_modules/yarn/lib/cli.js:141501:19)
at Object.onceWrapper (node:events:631:28)
at ClientRequest.emit (node:events:517:28)
at TLSSocket.emitRequestTimeout (node:_http_client:847:9)
at TLSSocket.emit (node:events:529:35)
at Socket._onTimeout (node:net:598:8)
at listOnTimeout (node:internal/timers:569:17)
at process.processTimers (node:internal/timers:512:7)
yarn run v1.22.21
++ cut -d: -f2
++ tr -d ' '
+ echo 4
ça ne fonctionne toujours pas.
Aprés relance deux fois des dépendances ça fonctionne!!!
+ echo 1
+ echo 2
++ pwd
+ rm -R zwave-js-ui
git checkout -b
+ echo 3
++ pwd
+ cd zwave-js-ui
+ sudo yarn install
[4/5] Linking dependencies...
warning " > vis-data@7.1.9" has unmet peer dependency "uuid@^3.4.0 || ^7.0.0 || ^8.0.0 || ^9.0.0".
warning " > vis-data@7.1.9" has unmet peer dependency "vis-util@^5.0.1".
warning " > vis-network@9.1.9" has unmet peer dependency "@egjs/hammerjs@^2.0.0".
warning " > vis-network@9.1.9" has unmet peer dependency "component-emitter@^1.3.0".
warning " > vis-network@9.1.9" has unmet peer dependency "keycharm@^0.2.0 || ^0.3.0 || ^0.4.0".
warning " > vis-network@9.1.9" has unmet peer dependency "uuid@^3.4.0 || ^7.0.0 || ^8.0.0 || ^9.0.0".
warning " > vis-network@9.1.9" has unmet peer dependency "vis-util@^5.0.1".
warning " > @babel/register@7.22.15" has unmet peer dependency "@babel/core@^7.0.0-0".
warning " > esbuild-register@3.5.0" has unmet peer dependency "esbuild@>=0.12 <1".
warning " > vite-plugin-pwa@0.16.7" has unmet peer dependency "workbox-build@^7.0.0".
warning " > vite-plugin-pwa@0.16.7" has unmet peer dependency "workbox-window@^7.0.0".
[5/5] Building fresh packages...
success Saved lockfile.
Done in 285.38s.
yarn run v1.22.21
$ tsc
$ vite build
vite v4.5.1 building for production...
transforming...
✓ 560 modules transformed.
rendering chunks...
computing gzip size...
dist/registerSW.js                                    0.14 kB
dist/manifest.webmanifest                             0.50 kB
dist/index.html                                       1.68 kB │ gzip:   0.74 kB
dist/assets/MaterialIcons-Regular-5743ed3d.woff2    125.12 kB
dist/assets/MaterialIcons-Regular-e69d687a.eot      143.45 kB
dist/assets/MaterialIcons-Regular-11ec382a.woff     160.58 kB
dist/assets/MaterialIcons-Regular-29c11fa5.ttf      347.59 kB
dist/assets/DialogHealthCheck-2228ed6c.css            0.04 kB │ gzip:   0.06 kB
dist/assets/DialogGatewayValue-911dd212.css           0.06 kB │ gzip:   0.08 kB
dist/assets/NodeDetails-da00c417.css                  0.06 kB │ gzip:   0.08 kB
dist/assets/Settings-5ef4a95d.css                     0.08 kB │ gzip:   0.10 kB
dist/assets/QrReader-00dee3fb.css                     0.09 kB │ gzip:   0.10 kB
dist/assets/NodePanel-3639f227.css                    0.09 kB │ gzip:   0.10 kB
dist/assets/RichValue-3ea76a33.css                    0.13 kB │ gzip:   0.12 kB
dist/assets/Mesh-1b8d31eb.css                         0.26 kB │ gzip:   0.20 kB
dist/assets/ValueId-d2938c42.css                      0.31 kB │ gzip:   0.18 kB
dist/assets/ExpandedNode-9f727a42.css                 0.39 kB │ gzip:   0.26 kB
dist/assets/index-fe59274b.css                        0.39 kB │ gzip:   0.14 kB
dist/assets/DialogAdvanced-eaabda04.css               0.45 kB │ gzip:   0.23 kB
dist/assets/Store-a58f7130.css                        0.79 kB │ gzip:   0.33 kB
dist/assets/BgRssiChart-3e7d7555.css                  1.66 kB │ gzip:   0.71 kB
dist/assets/Login-1826b0a1.css                        5.43 kB │ gzip:   1.52 kB
dist/assets/ZwaveGraph-fe07d4ee.css                 220.27 kB │ gzip:  31.02 kB
dist/assets/index-137ff6cb.css                      645.26 kB │ gzip:  86.99 kB
dist/assets/items-236b321d.js                         0.15 kB │ gzip:   0.15 kB
dist/assets/ControllerChart-3ef3d40b.js               0.54 kB │ gzip:   0.34 kB
dist/assets/ColumnFilterBoolean-adb8f010.js           0.70 kB │ gzip:   0.43 kB
dist/assets/ReinterviewBadge-7fb371f8.js              0.77 kB │ gzip:   0.51 kB
dist/assets/BlinkIcon-a9a9bdab.js                     0.86 kB │ gzip:   0.42 kB
dist/assets/ColumnFilterDate-129d8af0.js              1.20 kB │ gzip:   0.57 kB
dist/assets/ColumnFilterString-278e4643.js            1.26 kB │ gzip:   0.62 kB
dist/assets/StatisticsArrows-84d97808.js              1.28 kB │ gzip:   0.71 kB
dist/assets/DialogAdvanced-070f6a4d.js                1.31 kB │ gzip:   0.68 kB
dist/assets/ErrorPage-1c6d161c.js                     1.54 kB │ gzip:   0.78 kB
dist/assets/ColumnFilterNumber-02a1f6d3.js            1.77 kB │ gzip:   0.75 kB
dist/assets/file-input-32b6e174.js                    1.84 kB │ gzip:   0.86 kB
dist/assets/RichValue-260d894d.js                     2.06 kB │ gzip:   0.87 kB
dist/assets/StatisticsCard-bbfd8378.js                2.56 kB │ gzip:   1.00 kB
dist/assets/Mesh-40a76275.js                          2.87 kB │ gzip:   1.19 kB
dist/assets/DialogSceneValue-9c465119.js              3.09 kB │ gzip:   1.19 kB
dist/assets/ColumnFilter-5f973385.js                  3.50 kB │ gzip:   1.21 kB
dist/assets/UserCodeTable-089997a4.js                 4.04 kB │ gzip:   1.59 kB
dist/assets/Login-0180f6a7.js                         4.14 kB │ gzip:   1.64 kB
dist/assets/DialogAssociation-76bb7e69.js             4.19 kB │ gzip:   1.51 kB
dist/assets/AssociationGroups-6c613cb5.js             4.36 kB │ gzip:   1.58 kB
dist/assets/ListInput-ccf40f46.js                     4.39 kB │ gzip:   1.41 kB
dist/assets/OTAUpdates-4fcc99d1.js                    5.14 kB │ gzip:   2.12 kB
dist/assets/Scenes-3f734b6d.js                        5.75 kB │ gzip:   1.94 kB
dist/assets/HomeAssistant-e2582776.js                 7.57 kB │ gzip:   2.24 kB
dist/assets/prismeditor.esm-ba798da4.js               7.58 kB │ gzip:   2.70 kB
dist/assets/NodeScheduler-2002b725.js                 7.86 kB │ gzip:   2.60 kB
dist/assets/DialogGatewayValue-0cbdf0cf.js            8.29 kB │ gzip:   2.51 kB
dist/assets/SmartStart-ff7a4ff6.js                    8.46 kB │ gzip:   2.32 kB
dist/assets/SmartView-7ed74ee7.js                     8.87 kB │ gzip:   2.98 kB
dist/assets/mdi-4fe99e39.js                           9.43 kB │ gzip:   3.12 kB
dist/assets/ValueId-b7187d3c.js                      10.46 kB │ gzip:   2.94 kB
dist/assets/Store-cfbc706a.js                        10.91 kB │ gzip:   3.36 kB
dist/assets/NodeDetails-aca02514.js                  12.14 kB │ gzip:   3.36 kB
dist/assets/DialogHealthCheck-95ceed82.js            12.23 kB │ gzip:   3.52 kB
dist/assets/ExpandedNode-8a1595e6.js                 13.99 kB │ gzip:   4.80 kB
dist/assets/NodePanel-b0476e69.js                    14.96 kB │ gzip:   4.14 kB
dist/assets/Debug-b5a11026.js                        16.32 kB │ gzip:   4.18 kB
dist/assets/ControlPanel-166c16bc.js                 16.54 kB │ gzip:   5.88 kB
dist/assets/index-d348c912.js                        19.81 kB │ gzip:   5.82 kB
dist/assets/QrReader-bfce9e2b.js                     20.90 kB │ gzip:   7.30 kB
dist/assets/qr-scanner-worker.min-5f44a019.js        43.95 kB │ gzip:  10.46 kB
dist/assets/BgRssiChart-9e13613f.js                  53.01 kB │ gzip:  23.54 kB
dist/assets/vuedraggable.umd-1ac0c8cf.js             71.04 kB │ gzip:  24.90 kB
dist/assets/Settings-0823a402.js                     72.41 kB │ gzip:  18.34 kB
dist/assets/index-e171b0cc.js                       104.95 kB │ gzip:  43.04 kB
dist/assets/ZwaveGraph-86e2d168.js                  561.10 kB │ gzip: 166.33 kB
dist/assets/index-822e6be1.js                     1,151.67 kB │ gzip: 316.13 kB
(!) Some chunks are larger than 500 kBs after minification. Consider:
- Using dynamic import() to code-split the application
- Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
- Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
transforming...
✓ 65 modules transformed.
rendering chunks...
dist/sw.js  43.54 kB │ gzip: 12.25 kB
✓ built in 2.43s
PWA v0.16.7
mode      injectManifest
precache  72 entries (3142.95 KiB)
files generated
dist/sw.js
✓ built in 2m 6s
Done in 184.59s.
+ chown -R www-data:www-data CHANGELOG.md LICENSE README.md SECURITY.md api certs dist docker docs esbuild-register.js genereteDocs.ts index.html kubernetes kustomization.yaml node_modules nodemon.json package-lock.json package.json package.sh pkg public server server_config.js snippets src store test tsconfig.eslint.json tsconfig.json vite.config.js wallaby.js yarn.lock
++ tr -d ' '
++ cut -d: -f2
+ echo 4
Merci de votre aide!!
Rodinrott
