Bonjour, j’ai toujours des erreures dans les logs de Xiaomitalk :
Lancement de l'installation/mise à jour des dépendances xiaomiTalk
--20%
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
dialog is already the newest version (1.3-20190211-1).
libavcodec-extra is already the newest version (7:4.1.6-1~deb10u1).
lsb-release is already the newest version (10.2019051400).
apt-utils is already the newest version (1.8.2.2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installation de ffmpeg à la place de libav-tools
ffmpeg is already the newest version (7:4.1.6-1~deb10u1).
libttspico-utils is already the newest version (1.0+git20130326-9).
--30%
Version actuelle :
--40%
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
--45%
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Hit:5 http://deb.debian.org/debian buster-backports InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org buster/updates InRelease
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/17.6 MB of archives.
After this operation, 93.2 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 75539 files and directories currently installed.)
Preparing to unpack .../nodejs_12.20.0-1nodesource1_arm64.deb ...
Detected old npm client, removing...
Unpacking nodejs (12.20.0-1nodesource1) ...
Setting up nodejs (12.20.0-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
Version actuelle : v12.20.0
--50%
--60%
Installation de MIIO...
chown: cannot access 'node_modules': No such file or directory
+ miio@0.15.4
added 116 packages from 53 contributors and audited 116 packages in 18.145s
18 packages are looking for funding
run `npm fund` for details
found 2 low severity vulnerabilities
run `npm audit fix` to fix them, or `npm audit` for details
--95%
--100%
Installation des dépendances xiaomiTalk terminée, vérifiez qu'il n'y a pas d'erreur
Linux JeedomDelta 4.19.0-13-arm64 #1 SMP Debian 4.19.160-2 (2020-11-28) aarch64 GNU/Linux [10.7]
