Problème dépendances RFXCOM
Je viens d’installer et d’activer le plugin RFXCOM mais impossible de lancer les dépendances et donc le demon.
Je suis novices en informatique et je ne vois pas trop d’où peut venir le problème.
Ci dessous le log :
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_rfxcom
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0006|+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0007|Launch pre-install of rfxcom dependancy
0008|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0009|Reading package lists...
0010|Building dependency tree...
0011|Reading state information...
0012|Package 'python3-serial' is not installed, so not removed
0013|0 upgraded, 0 newly installed, 0 to remove and 263 not upgraded.
0014|+ echo 3
0015|++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
0016|++ awk '$1 <= 4'
0017|++ cut -f 2-
0018|+ RESULTTODELETE=
0019|++ echo ''
0020|++ sed 's, ,\ ,g'
0021|+ RESULTTODELETE2=
0022|+ echo ''
0023|+ xargs rm -rf
0024|+ echo 4
0025|+ sudo pip3 cache purge
0026|+ echo 5
0027|+ sudo pip3 install --upgrade pip
0028|+ echo 6
0029|+ sudo pip3 install --force-reinstall --upgrade six
0030|+ echo 7
0031|+ sudo pip3 install --force-reinstall --upgrade requests
0032|+ echo 8
0033|+ sudo pip3 install --force-reinstall --upgrade setuptools
0034|+ echo 9
0035|+ sudo pip3 install --force-reinstall --upgrade pyudev
0036|+ echo 10
0037|+ sudo pip3 install --force-reinstall --upgrade pyserial
0038|+ echo 11
0039|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
0040|+ echo 12
0041|+ rm /tmp/jeedom_install_in_progress_rfxcom
0042|+ echo '*******************End of package installation******************'
0043|*******************End of package installation******************
Merci d’avance pour votre aide,
Informations Jeedom Atlas
Core : 4.4.6 (V4-stable)
DNS Jeedom Atlas : non
Plugin : RFXcom
Version : 2024-01-04 01:02:50 (stable)
Statut Démon : Stoppé - (Inconnue)
La page Santé de cette Altas, indique que vous êtes sur Debian 10 ou 11 ? Si c’est 10, il faut la migrer vers Debian 11. Une procédure existe dans les documentations en ligne de Jeedom;
ou sur le forum ici :
:boom: Installer Debian 11 sur box Atlas - Matériel Jeedom - Hardware / La Box JEEDOM ATLAS - Communauté Jeedom
Merci, tout refonctionne normalement !
