Bonjour à tous
suite à une restauration, le plugin me dit que les dépendances sont KO
alors que tout était fonctionnelle sur la sauvegarde
et quand je relance l’installation des dépendances cela n’aboutie pas
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 9.4 (stretch)
-- Updating repo...
Hit:1 http://security.debian.org stretch/updates InRelease
Hit:2 http://www.deb-multimedia.org stretch InRelease
Ign:4 http://ftp.debian.org/debian stretch InRelease
Hit:5 http://ftp.debian.org/debian stretch-updates InRelease
Hit:6 http://ftp.debian.org/debian stretch-backports InRelease
Hit:7 http://ftp.debian.org/debian stretch-proposed-updates InRelease
Hit:8 http://ftp.debian.org/debian stretch Release
Hit:9 https://deb.nodesource.com/node_12.x stretch InRelease
Hit:10 https://oph.mdrjr.net/meveric all InRelease
Hit:11 https://oph.mdrjr.net/meveric stretch InRelease
Ign:3 https://repo.jeedom.com/odroid stable InRelease
Get:13 https://repo.jeedom.com/odroid stable Release [932 B]
Get:14 https://repo.jeedom.com/odroid stable Release.gpg [659 B]
Fetched 1591 B in 5s (278 B/s)
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
python-dev is already the newest version (2.7.13-2).
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 149 not upgraded.
-- Installed version of Python :
Python 3.5.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (9.0.1-2+deb9u1).
python3-dev is already the newest version (3.5.3-1).
python-requests is already the newest version (2.12.4-1).
-- Installation of audio sox library
sox is already the newest version (14.4.1-5+deb9u2).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-5).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:3.2.14-1~deb9u1).
-- Upgrade setuptools with command pip3.7 if not up to date
File "/usr/local/bin/pip3.7", line 6, in <module>
from pip._internal import main
File "/usr/local/lib/python3.7/site-packages/pip/_internal/__init__.py", line 40, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/local/lib/python3.7/site-packages/pip/_internal/cli/autocompletion.py", line 8, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/local/lib/python3.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/local/lib/python3.7/site-packages/pip/_internal/cli/cmdoptions.py", line 24, in <module>
from pip._internal.models.search_scope import SearchScope
File "/usr/local/lib/python3.7/site-packages/pip/_internal/models/search_scope.py", line 11, in <module>
from pip._internal.utils.misc import normalize_path, redact_password_from_url
File "/usr/local/lib/python3.7/site-packages/pip/_internal/utils/misc.py", line 21, in <module>
from pip._vendor import pkg_resources
File "/usr/local/lib/python3.7/site-packages/pip/_vendor/pkg_resources/__init__.py", line 84, in <module>
__import__('pip._vendor.packaging.requirements')
File "/usr/local/lib/python3.7/site-packages/pip/_vendor/packaging/requirements.py", line 9, in <module>
from pip._vendor.pyparsing import stringStart, stringEnd, originalTextFor, ParseException
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 857, in get_code
File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
EOFError: marshal data too short
-- Installed version of pip :
-- Installation of python library 'requests' with command pip3.7
-- Installation of python library 'protobuf' with command pip3.7
-- Installation of python library 'zeroconf' with command pip3.7
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.7
-- Installation of python library 'tqdm, websocket-client' for plex with command pip3.7
-- Installation of dependencies is done !
