Bonjour, je rencontre un problème lors de l’installation des dépendances du plugin Docker, si quelqu’un sait comment le solutionner…ci-joint les logs :
+ touch /tmp/jeedom_install_in_progress_docker2
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/docker2/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/docker2/resources/pre-install.sh
Docker arch found : arm64
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:3 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:4 https://download.docker.com/linux/debian buster InRelease
Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
Hit:6 https://oph.mdrjr.net/meveric all InRelease
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Get:8 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
+ echo 3
+ sudo apt update
Get:3 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Get:6 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y docker-ce
Building dependency tree...
Reading state information...
docker-ce is already the newest version (5:24.0.2-1~debian.10~buster).
0 upgraded, 0 newly installed, 0 to remove and 257 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up docker-ce (5:24.0.2-1~debian.10~buster) ...
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (e]8;;file://Jeedom/lib/systemd/system/docker.servicea/lib/systemd/system/docker.servicee]8;;a; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2023-06-11 05:55:32 UTC; 21ms ago
Docs: e]8;;https://docs.docker.comahttps://docs.docker.come]8;;a
Process: 14069 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock e[0;1;31m(code=exited, status=1/FAILURE)e[0m
Main PID: 14069 (code=exited, status=1/FAILURE)
Jun 11 05:55:32 Jeedom systemd[1]: e[0;1;31me[0;1;39me[0;1;31mFailed to start Docker Application Container Engine.e[0m
dpkg: error processing package docker-ce (--configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
+ echo 5
+ sudo chmod +x /var/www/html/core/class/../../plugins/docker2/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/docker2/resources/post-install.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
1 22.8M 1 399k 0 0 454k 0 0:00:51 --:--:-- 0:00:51 454k
6 22.8M 6 1549k 0 0 824k 0 0:00:28 0:00:01 0:00:27 1149k
11 22.8M 11 2685k 0 0 932k 0 0:00:25 0:00:02 0:00:23 1143k
16 22.8M 16 3827k 0 0 986k 0 0:00:23 0:00:03 0:00:20 1142k
21 22.8M 21 4974k 0 0 1019k 0 0:00:22 0:00:04 0:00:18 1143k
26 22.8M 26 6121k 0 0 1041k 0 0:00:22 0:00:05 0:00:17 1144k
31 22.8M 31 7269k 0 0 1056k 0 0:00:22 0:00:06 0:00:16 1143k
35 22.8M 35 8402k 0 0 1066k 0 0:00:21 0:00:07 0:00:14 1143k
40 22.8M 40 9552k 0 0 1075k 0 0:00:21 0:00:08 0:00:13 1144k
45 22.8M 45 10.4M 0 0 1081k 0 0:00:21 0:00:09 0:00:12 1142k
50 22.8M 50 11.5M 0 0 1087k 0 0:00:21 0:00:10 0:00:11 1142k
55 22.8M 55 12.6M 0 0 1091k 0 0:00:21 0:00:11 0:00:10 1140k
60 22.8M 60 13.7M 0 0 1096k 0 0:00:21 0:00:12 0:00:09 1143k
65 22.8M 65 14.9M 0 0 1100k 0 0:00:21 0:00:13 0:00:08 1143k
70 22.8M 70 16.0M 0 0 1102k 0 0:00:21 0:00:14 0:00:07 1143k
75 22.8M 75 17.1M 0 0 1105k 0 0:00:21 0:00:15 0:00:06 1143k
79 22.8M 79 18.2M 0 0 1106k 0 0:00:21 0:00:16 0:00:05 1142k
84 22.8M 84 19.3M 0 0 1109k 0 0:00:21 0:00:17 0:00:04 1142k
89 22.8M 89 20.4M 0 0 1110k 0 0:00:21 0:00:18 0:00:03 1140k
94 22.8M 94 21.6M 0 0 1112k 0 0:00:20 0:00:19 0:00:01 1143k
99 22.8M 99 22.7M 0 0 1114k 0 0:00:20 0:00:20 --:--:-- 1143k
100 22.8M 100 22.8M 0 0 1114k 0 0:00:20 0:00:20 --:--:-- 1146k
+ echo 6
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end docker2
+ rm /tmp/jeedom_install_in_progress_docker2
