Suite à la dernière mise de la version stable, le démon ne démarre plus à cause des lib urllib3 + requests
Jeedom stable : 4.3.17
Matériel : RPi 4B+ Buster
Installation des dépendances :
0000|*************************************
0001|* Launch install of dependencies *
0002|*************************************
0003|Tue May 16 09:08:38 CEST 2023
0004|Hit:1 http://archive.raspberrypi.org/debian buster InRelease
0005|Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
0006|Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
0007|Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
0008|Fetched 13.0 MB in 24s (546 kB/s)
0009|Reading package lists...
0010|*****************************
0011|Install modules using apt-get
0012|*****************************
0013|Reading package lists...
0014|Building dependency tree...
0015|Reading state information...
0016|python3 is already the newest version (3.7.3-1).
0017|python3-requests is already the newest version (2.21.0-1).
0018|python3-setuptools is already the newest version (40.8.0-1).
0019|python3-pip is already the newest version (18.1-5+rpt1).
0020|0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
0021|Reading package lists...
0022|Building dependency tree...
0023|Reading state information...
0024|ffmpeg is already the newest version (7:4.1.10-0+deb10u1+rpt1).
0025|0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
0026|*************************************
0027|Install the required python libraries
0028|*************************************
0029|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0030|Requirement already satisfied: monotonic>=1.5 in /usr/local/lib/python3.7/dist-packages (1.5)
0031|Collecting urllib3>=1.26
0032|Downloading https://files.pythonhosted.org/packages/4b/1d/f8383ef593114755429c307449e7717b87044b3bcd5f7860b89b1f759e34/urllib3-2.0.2-py3-none-any.whl (123kB)
0033|Collecting requests>=2.30
0034|Downloading https://files.pythonhosted.org/packages/96/80/034ffeca15c0f4e01b7b9c6ad0fb704b44e190cde4e757edbd60be404c41/requests-2.30.0-py3-none-any.whl (62kB)
0035|Requirement already satisfied: sseclient==0.0.18 in /usr/local/lib/python3.7/dist-packages (0.0.18)
0036|Collecting cloudscraper>=1.2.70
0037|Downloading https://files.pythonhosted.org/packages/81/97/fc88803a451029688dffd7eb446dc1b529657577aec13aceff1cc9628c5d/cloudscraper-1.2.71-py2.py3-none-any.whl (99kB)
0038|Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3/dist-packages (from requests>=2.30) (2.6)
0039|Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests>=2.30) (2021.10.8)
0040|Collecting charset-normalizer<4,>=2 (from requests>=2.30)
0041|Downloading https://files.pythonhosted.org/packages/ef/81/14b3b8f01ddaddad6cdec97f2f599aa2fa466bd5ee9af99b08b7713ccd29/charset_normalizer-3.1.0-py3-none-any.whl (46kB)
0042|Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from sseclient==0.0.18) (1.16.0)
0043|Requirement already satisfied: pyparsing>=2.4.7 in /usr/local/lib/python3.7/dist-packages (from cloudscraper>=1.2.70) (2.4.7)
0044|Requirement already satisfied: requests-toolbelt>=0.9.1 in /usr/local/lib/python3.7/dist-packages (from cloudscraper>=1.2.70) (0.9.1)
0045|Installing collected packages: urllib3, charset-normalizer, requests, cloudscraper
0046|Found existing installation: urllib3 1.24.1
0047|Not uninstalling urllib3 at /usr/lib/python3/dist-packages, outside environment /usr
0048|Can't uninstall 'urllib3'. No files were found to uninstall.
0049|Found existing installation: requests 2.21.0
0050|Not uninstalling requests at /usr/lib/python3/dist-packages, outside environment /usr
0051|Can't uninstall 'requests'. No files were found to uninstall.
0052|Found existing installation: cloudscraper 1.2.58
0053|Uninstalling cloudscraper-1.2.58:
0054|Successfully uninstalled cloudscraper-1.2.58
0055|Successfully installed charset-normalizer-3.1.0 cloudscraper-1.2.71 requests-2.30.0 urllib3-2.0.2
0056|ffmpeg version 4.1.10-0+deb10u1+rpt1 Copyright (c) 2000-2022 the FFmpeg developers
0057|built with gcc 8 (Raspbian 8.3.0-6+rpi1)
0058|configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
0059|libavutil 56. 22.100 / 56. 22.100
0060|libavcodec 58. 35.100 / 58. 35.100
0061|libavformat 58. 20.100 / 58. 20.100
0062|libavdevice 58. 5.100 / 58. 5.100
0063|libavfilter 7. 40.101 / 7. 40.101
0064|libavresample 4. 0. 0 / 4. 0. 0
0065|libswscale 5. 3.100 / 5. 3.100
0066|libswresample 3. 3.100 / 3. 3.100
0067|libpostproc 55. 3.100 / 55. 3.100
0068|Tue May 16 09:09:21 CEST 2023
0069|***************************
0070|* Install ended *
0071|***************************
Démon :
4303|[2023-05-16 09:08:26][INFO] : MainThread : Logout Arlo
4304|Traceback (most recent call last):
4305|File "/usr/local/lib/python3.7/dist-packages/requests_toolbelt/_compat.py", line 48, in <module>
4306|from requests.packages.urllib3.contrib import appengine as gaecontrib
4307|ImportError: cannot import name 'appengine' from 'requests.packages.urllib3.contrib' (/usr/local/lib/python3.7/dist-packages/urllib3/contrib/__init__.py)
4308|During handling of the above exception, another exception occurred:
4309|Traceback (most recent call last):
4310|File "/var/www/html/plugins/arlo/resources/arlod/arlod.py", line 10, in <module>
4311|from arlo.backend import ArloBackend, ArloBackendException
4312|File "/var/www/html/plugins/arlo/resources/arlod/arlo/__init__.py", line 1, in <module>
4313|from .backend import ArloBackend, ArloBackendException
4314|File "/var/www/html/plugins/arlo/resources/arlod/arlo/backend.py", line 10, in <module>
4315|from .clientApi.arlo import Arlo
4316|File "/var/www/html/plugins/arlo/resources/arlod/arlo/clientApi/arlo.py", line 2, in <module>
4317|from .request import ArloRequest
4318|File "/var/www/html/plugins/arlo/resources/arlod/arlo/clientApi/request.py", line 1, in <module>
4319|import cloudscraper
4320|File "/usr/local/lib/python3.7/dist-packages/cloudscraper/__init__.py", line 10, in <module>
4321|from requests_toolbelt.utils import dump
4322|File "/usr/local/lib/python3.7/dist-packages/requests_toolbelt/__init__.py", line 12, in <module>
4323|from .adapters import SSLAdapter, SourceAddressAdapter
4324|File "/usr/local/lib/python3.7/dist-packages/requests_toolbelt/adapters/__init__.py", line 12, in <module>
4325|from .ssl import SSLAdapter
4326|File "/usr/local/lib/python3.7/dist-packages/requests_toolbelt/adapters/ssl.py", line 16, in <module>
4327|from .._compat import poolmanager
4328|File "/usr/local/lib/python3.7/dist-packages/requests_toolbelt/_compat.py", line 50, in <module>
4329|from urllib3.contrib import appengine as gaecontrib
4330|ImportError: cannot import name 'appengine' from 'urllib3.contrib' (/usr/local/lib/python3.7/dist-packages/urllib3/contrib/__init__.py)
Xav
