Depuis la dernière mise a jour du plug in en beta je me retrouve avec cette erreur et je n’ai rien touché ni rien changé
File "/var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py", line 9, in <module>
import aiohttp
ModuleNotFoundError: No module named 'aiohttp'
Exception in thread Thread-4:
File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner
self.run()
File "/usr/lib/python3.9/threading.py", line 892, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3591, in _thread_main
self.loop_forever(retry_first_connection=True)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1756, in loop_forever
rc = self._loop(timeout)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1164, in _loop
rc = self.loop_read()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1556, in loop_read
rc = self._packet_read()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 2439, in _packet_read
rc = self._packet_handle()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3033, in _packet_handle
return self._handle_publish()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3327, in _handle_publish
self._handle_on_message(message)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3570, in _handle_on_message
on_message(self, self._userdata, message)
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/utils/mqtt.py", line 148, in _forward_on_message
self._on_update(msg)
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/__init__.py", line 316, in _on_update
self._decode_data(device)
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/__init__.py", line 344, in _decode_data
device.status.update(data["dat"]["ls"])
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/utils/state.py", line 71, in update
self["description"] = self.__descriptor[self["id"]]
KeyError: 13
Exception in thread Thread-22:
self.run()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3330, in _handle_publish
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/__init__.py", line 305, in _on_update
mower = self.get_mower(data["cfg"]["sn"])
KeyError: 'sn'
Exception in thread Thread-1:
self.run()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1185, in _loop
return self.loop_misc()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1610, in loop_misc
self._check_keepalive()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 2560, in _check_keepalive
self._do_on_disconnect(rc)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3475, in _do_on_disconnect
on_disconnect(self, self._userdata, rc)
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/utils/mqtt.py", line 215, in _on_disconnect
self.client.reconnect()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/lib/python3.9/socket.py", line 822, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/lib/python3.9/socket.py", line 953, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
Exception in thread Thread-209:
self.run()
Exception in thread Thread-210:
self.run()
Exception in thread Thread-56:
self.run()
KeyError: 13
Exception in thread Thread-134:
self.run()
KeyError: 13
Exception in thread Thread-35:
self.run()
KeyError: 13
[2023-07-08 20:34:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 20:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 20:40:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 20:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 20:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 20:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:00:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:05:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:20:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:30:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:40:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 21:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:00:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:05:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:30:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:40:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:50:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 22:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:00:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:05:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:10:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:15:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:30:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:40:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-08 23:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:00:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:05:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:30:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:35:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:40:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 00:55:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:00:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:05:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:20:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:25:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:30:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:35:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:40:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 01:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:00:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:05:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:30:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:40:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 02:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:00:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:05:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:10:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:15:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:25:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:30:07][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:35:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:40:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:45:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:50:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 03:55:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 04:00:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 04:05:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 04:10:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 04:15:05][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
[2023-07-09 04:20:06][ERROR] : Fatal error: 'last_status'(<class 'KeyError'>) in /var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py on line 264
