Citation Launch install of googlecast dependancies
– Updating repo…
Hit:1 Index of /debian buster InRelease
Get:2 Index of /raspbian buster InRelease [15.0 kB]
Get:3 Index of /debian buster InRelease [25.2 kB]
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Get:5 Index of /debian buster/main armhf Packages [260 kB]
Fetched 300 kB in 2s (175 kB/s)
Reading package lists…
– Installation of python3 and dependancies
Building dependency tree…
Reading state information…
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
– Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
– Installation of pip for python3 and necessary libraries
python-requests is already the newest version (2.21.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5+rpt1).
– Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
– Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-9).
– Installation of libav/ffmpeg libraries
/var/www/html/plugins/googlecast/core/class/…/…/resources/install.sh: line 40: 4692 Segmentation fault sudo apt-get install -y ffmpeg
– Upgrade setuptools with command pip3 if not up to date
File « /usr/lib/python3/dist-packages/pip/_vendor/init.py », line 33, in vendored
import(vendored_name, globals(), locals(), level=0)
ModuleNotFoundError: No module named ‹ pip._vendor.cachecontrol ›
During handling of the above exception, another exception occurred:
File « /usr/bin/pip3 », line 9, in
from pip._internal import main
File « /usr/lib/python3/dist-packages/pip/_internal/init.py », line 19, in
from pip._vendor.urllib3.exceptions import DependencyWarning
File « /usr/lib/python3/dist-packages/pip/_vendor/init.py », line 64, in
vendored(« cachecontrol »)
File « /usr/lib/python3/dist-packages/pip/_vendor/init.py », line 36, in vendored
import(modulename, globals(), locals(), level=0)
File « », line 983, in _find_and_load
File « », line 967, in _find_and_load_unlocked
File « », line 668, in _load_unlocked
File « », line 638, in _load_backward_compatible
File « /usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/init.py », line 9, in
File « /usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py », line 1, in
File « /usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py », line 4, in
File « /usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/init.py », line 44, in
File « /usr/share/python-wheels/chardet-3.0.4-py2.py3-none-any.whl/chardet/init.py », line 20, in
File « /usr/share/python-wheels/chardet-3.0.4-py2.py3-none-any.whl/chardet/universaldetector.py », line 48, in
File « /usr/share/python-wheels/chardet-3.0.4-py2.py3-none-any.whl/chardet/sbcsgroupprober.py », line 40, in
SystemError: unhandled expr: 323
– Installed version of pip :
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
– Installation of python library ‹ requests › with command pip3
Looking in indexes: Simple index, piwheels - Simple index
Requirement already satisfied: requests>=2.21.0 in /usr/lib/python3/dist-packages (2.21.0)
– Installation of python library ‹ protobuf › with command pip3
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (3.11.2)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from protobuf>=3.11.0) (40.8.0)
Requirement already satisfied: six>=1.9 in /usr/lib/python3/dist-packages (from protobuf>=3.11.0) (1.12.0)
– Installation of python library ‹ zeroconf › with command pip3
Requirement already satisfied: zeroconf<0.24.4,>=0.22.0 in /usr/local/lib/python3.7/dist-packages (0.24.3)
Requirement already satisfied: ifaddr in /usr/local/lib/python3.7/dist-packages (from zeroconf<0.24.4,>=0.22.0) (0.1.6)
– Installation of python library ‹ click, bs4 and six › for TTS with command pip3
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (7.0)
Requirement already satisfied: bs4 in /usr/local/lib/python3.7/dist-packages (0.0.1)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (1.12.0)
– Installation of python library ‹ tqdm, websocket-client › for plex with command pip3
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.41.1)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (0.57.0)
– Installation of dependencies is done !
Voilà.
