J’utilisais l’ancien plugin qui fonctionnait bien
J’ai fait la MAJ et depuis, impossible de faire fonctionner mon roomba
Installation du plugin, installation des dependances qui installe MQTT, installation de mosquitto. Malgre tout ca…rien
Ci-dessous la fin du LOG
[2022-11-24 21:34:54]INFO : configuring Roomba from file /var/www/html/plugins/kroomba/data/config.ini
[2022-11-24 21:34:54]INFO : reading/writing info from config file /var/www/html/plugins/kroomba/data/config.ini
[2022-11-24 21:34:54]INFO : 1 Roombas Found
[2022-11-24 21:34:54]INFO : Try to connect to iRobot Roomba with ip 192.168.0.85
[2022-11-24 21:34:54]INFO : Start listening
[2022-11-24 21:34:54]INFO : Connecting...
[2022-11-24 21:34:54]INFO : Setting TLS
[2022-11-24 21:34:54]INFO : Setting TLS - OK
[2022-11-24 21:34:54]DEBUG : Broker Connected with result code 0
[2022-11-24 21:34:54]INFO : subscribed to iRobot/command/Roomba/#, iRobot/setting/Roomba/#
[2022-11-24 21:34:59]ERROR : Connection Error: timed out
[2022-11-24 21:35:00]ERROR : Attempting retry Connection# 0
[2022-11-24 21:35:00]INFO : Attempting to Reconnect...
[2022-11-24 21:35:05]ERROR : Connection Error: timed out
[2022-11-24 21:35:06]ERROR : Attempting retry Connection# 1
[2022-11-24 21:35:06]INFO : Attempting to Reconnect...
[2022-11-24 21:35:11]ERROR : Connection Error: timed out
[2022-11-24 21:35:12]ERROR : Attempting retry Connection# 2
[2022-11-24 21:35:12]INFO : Attempting to Reconnect...
[2022-11-24 21:35:17]ERROR : Connection Error: timed out
[2022-11-24 21:36:17]ERROR : Attempting retry Connection# 3
[2022-11-24 21:36:17]INFO : Attempting to Reconnect...
[2022-11-24 21:36:22]ERROR : Connection Error: timed out
[2022-11-24 21:37:22]ERROR : Attempting retry Connection# 4
[2022-11-24 21:37:22]INFO : Attempting to Reconnect...
[2022-11-24 21:37:27]ERROR : Connection Error: timed out
