Je n’arrive plus a récupérer les données d’hydro-Québec.
Je suis sur un RPi4 avec Debian 10.
Ca à déjà fonctionner et les dernières données récupérées sont en date du 2024-01-09 09:00:24
Voici le log.
File "/var/www/html/plugins/hydroQuebec/resources/hydroqc/../hydro.py", line 492, in <module>
loop.run_until_complete(close_fut)
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/local/lib/python3.11/asyncio/tasks.py", line 415, in wait
raise TypeError("Passing coroutines is forbidden, use tasks explicitly.")
TypeError: Passing coroutines is forbidden, use tasks explicitly.
Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0xb59c40f0>
Unclosed connector
connections: ['[(<aiohttp.client_proto.ResponseHandler object at 0xb5954500>, 12996.583740067)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb5954fb8>, 12997.505123456)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb5954f10>, 12997.78314627)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb596fed8>, 12997.963510381)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb5954f80>, 12998.147785289)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb597b7d8>, 12998.464786048)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb596f8b8>, 12999.267789992)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb597bae8>, 12999.400267269)]', '[(<aiohttp.client_proto.ResponseHandler object at 0xb597b880>, 12999.78841988)]']
connector: <aiohttp.connector.TCPConnector object at 0xb59c41f0>
sys:1: RuntimeWarning: coroutine 'WebUser.close_session' was never awaited
