Tout d’abord excellente année 2024 a tous.
Je suis novice dans la partie et lorsque je cherche a mettre a jour jeedom j’ai les erreurs ci dessous.
En python3 et Python2 (resumé du message d’erreur en python3 ci dessous)
La partie « Mettre a jour les packages OS » est désactivé.
Avez vous une info la dessus ? Pour Info j’utilise jeedom sur une freebox delta / version Jeedom 4.3.21
+ echo '*******************Begin of package upgrade type pip3******************'
+ sudo pip3 install --force-reinstall --upgrade blinker
sudo: unable to resolve host JeedomDelta: Name or service not known
Collecting blinker
Using cached blinker-1.6.3-py3-none-any.whl.metadata (1.9 kB)
Using cached blinker-1.6.3-py3-none-any.whl (13 kB)
Installing collected packages: blinker
Attempting uninstall: blinker
Found existing installation: blinker 1.4
ERROR: Cannot uninstall 'blinker'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ sudo pip3 install --force-reinstall --upgrade entrypoints
Collecting entrypoints
Using cached entrypoints-0.4-py3-none-any.whl (5.3 kB)
Installing collected packages: entrypoints
Attempting uninstall: entrypoints
Found existing installation: entrypoints 0.3
ERROR: Cannot uninstall 'entrypoints'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ sudo pip3 install --force-reinstall --upgrade psutil
Collecting psutil
Using cached psutil-5.9.7-cp37-abi3-linux_aarch64.whl
Installing collected packages: psutil
Attempting uninstall: psutil
Found existing installation: psutil 5.5.1
ERROR: Cannot uninstall 'psutil'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ sudo pip3 install --force-reinstall --upgrade pyxdg
Collecting pyxdg
Using cached pyxdg-0.28-py2.py3-none-any.whl (49 kB)
Installing collected packages: pyxdg
Attempting uninstall: pyxdg
Found existing installation: pyxdg 0.25
ERROR: Cannot uninstall 'pyxdg'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ sudo pip3 install --force-reinstall --upgrade PyYAML
C’est en allant ici que vous avez ces problèmes ?
« Mettre a jour les packages OS » ?
- Si c’est le cas, n’y allez pas, cela risque de casser votre Jeedom
Sinon, vous avez un problème avec le nom de votre machine, renommez la en SSH avec un nom contenant que des minuscules.
En SSH, faites les commandes suivantes : cat /etc/host
puis : cat /etc/hostname
Il doit y avoir une embrouille avec le nom de votre machine (mais ce n’est pas le sujet du problème des mises à jour).
1/ Vire ton numéro de mobile dans type de téléphone de ton profil !
2/ Il vaut mieux ne pas s’aventurer dans l’onglet de mise a jour des paquets sans maitrise.
La mise a jour de jeedom en restant sur l’onglet core et plugins et cliquer sur le bouton mise a jour orange en haut a droite suffit.
3/ Poste une copie de la page santé de Jeedom que l’on aie des infos
merci pour votre retour.
Lors des premières connexions et prise en main avec l’applicatif je suis allé dans la partie maj
j’avais remarqué que la partie « mettre a jour les packages OS » pouvez être mise a jour sans. actuellement cette option n’est pas accessible sur mon Jeedom (il a l’air grisé).
Mes messages d’erreurs viennent lorsque je souhaite mettre a jour les packages Python2 et Python3.
Sur la partie maj de jeedom il y a des modules à mettre a jour
exemple: pip2 blinker 1.4 vers 1.6.3 / pip3 PyYaml 3.13 vers 6.01
j’ai modifié le ficher /etc/hostname pour remplacer les majuscules par des minuscules
j’ai ensuite modifier le fichier /etc/hosts ( /etc/cloud/templates/hosts.debian.tmpl) en ajoutant la ligne 127.0.1.1 jeedomdelta
y a une amélioration puisque j’ai les messages ci dessous lors de l’exécution d’une mise à jour.
malheureusement blinker ne se met pas jour pour autant. il reste en sa version 1.4
Pour Pycurl j’ai un autre message
sudo pip2 install --force-reinstall --upgrade pycurl
Collecting pycurl
Using cached https://files.pythonhosted.org/packages/ef/05/4b773f74f830a90a326b06f9b24e65506302ab049e825a3c0b60b1a6e26a/pycurl-7.43.0.5.tar.gz
Complete output from command python setup.py egg_info:
File « », line 1, in
File « /tmp/pip-install-_s5ecG/pycurl/setup.py », line 961, in
ext = get_extension(sys.argv, split_extension_source=split_extension_source)
File « /tmp/pip-install-_s5ecG/pycurl/setup.py », line 623, in get_extension
ext_config = ExtensionConfiguration(argv)
File « /tmp/pip-install-_s5ecG/pycurl/setup.py », line 101, in init
self.configure()
File « /tmp/pip-install-_s5ecG/pycurl/setup.py », line 238, in configure_unix
raise ConfigurationError(msg) main.ConfigurationError: Could not run curl-config: [Errno 2] No such file or director
Est ce que l’instalation d’un github pourrais bloquer les maj ?
Actuellement mon jeedom est hebergé sur une freebox delta.
Jeedom est en version 4.3.21 j’ai vu sur votre site des versions supérieurs.
Est ce que les plateforme jeedom hebergé sur une freebox ont les mêmes maj ?
Merci pour ton retour.
je compte mettre jeedom sur sur un rapsberry, j’ai utilisé ma freebox comme test pour le moment le temp de voir et d’utiliser le produit, quand il sera en prod, je serai plus attentif a tout ca.
Bonne soirée
