Tout d’abord je m’excuse si j’expose mon sujet au mauvais endroit.
Ayant installé Deconz je rencontre un problème, à priori de mise à jour de certains paquets, à cause de debian bullseye. L’erreur empêche ou pose problème lors de la mise à jour des autres plugins.
ci-dessous le log des dépendances Deconz.
Merci de votre aide précieuse.
* Installation des dépendances *
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Ign:4 http://phoscon.de/apt/deconz bullseye InRelease
Err:5 http://phoscon.de/apt/deconz bullseye Release
404 Not Found [IP: 144.76.96.194 80]
E: The repository 'http://phoscon.de/apt/deconz bullseye Release' does not have a Release file.
python3-pip is already the newest version (20.3.4-4).
python3-setuptools is already the newest version (52.0.0-4).
Found existing installation: websocket-client 1.2.1
Uninstalling websocket-client-1.2.1:
Successfully uninstalled websocket-client-1.2.1
WARNING: Skipping websocket as it is not installed.
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (52.0.0)
Requirement already satisfied: wheel in /usr/lib/python3/dist-packages (0.34.2)
Requirement already satisfied: serial in /usr/local/lib/python3.9/dist-packages (0.0.97)
Requirement already satisfied: future>=0.17.1 in /usr/local/lib/python3.9/dist-packages (from serial) (0.18.2)
Requirement already satisfied: iso8601>=0.1.12 in /usr/local/lib/python3.9/dist-packages (from serial) (0.1.16)
Requirement already satisfied: pyyaml>=3.13 in /usr/local/lib/python3.9/dist-packages (from serial) (6.0)
Requirement already satisfied: pyudev in /usr/local/lib/python3.9/dist-packages (0.22.0)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from pyudev) (1.16.0)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.25.1)
Collecting websocket-client
Using cached websocket_client-1.2.1-py2.py3-none-any.whl (52 kB)
Installing collected packages: websocket-client
Successfully installed websocket-client-1.2.1
* Installation terminée *
